• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeo and Instance Groups
brainmuffinbrainmuffin Posts: 1,276
December 2020 in Blender Discussion
I'm using the preloads in Scifi Ship Building Blocks (https://www.daz3d.com/scifi-ship-building-blocks) and Diffeo to convert to Blender. The Preloads use Instance Groups for some of the portions. Diffeo doesn't convert all the portions when loaded in Blender. The first member of the group is there, but not the rest. How should I prepare the model in Studio for a better conversion?
  • AscaniaAscania Posts: 1,855
    December 2020
    You will probably need the Instances to Objects add-on without the ability to import actual instances.
  • brainmuffinbrainmuffin Posts: 1,276
    December 2020
    Is that a Studio or a Blender add on?
    December 2020
    https://www.daz3d.com/instances-to-objects
    December 2020
    yep, thanks.
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,260
    December 2020
    But one thing I didn't like is that it seemed as if Diffeo sees objects with the same name, it makes them into instances in Blender. That's not necessarily desirable.
    December 2020
    Ok, I'll have to keep that in mind. I may rename objects before I transfer. Thanks.
    December 2020
    I bought the Studio Add on and tried it out today on the Cargo ship. Converted without errors to Blender via Diffeo. Now to figure out if the Preload uses 3Delight or Iray in Studio. I'll post some test renders soon.
  • Raitan2008Raitan2008 Posts: 27
    December 2020
    I just duplicate the instances in blender...it's not so bad if the geometry isn't too high in number.
    December 2020
    My problem is items not appearing on the Blender side.
  • PadonePadone Posts: 4,033
    December 2020 edited December 2020
    @brainmuffin
    There is some instancing support in diffeo. That is, most instanced objects should convert to actual blender instances, this saves memory for large scenes. I know instances work better with the unmorphed options so you may try them to import scenes. Also be sure to have instances checked in the global options.
    Then to report issues to Thomas it may be better to use the diffeo repository.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/57/instances-issue
    https://diffeomorphic.blogspot.com/p/import-into-blender-version-15b_20.html
    245 x 269 - 16K
    239 x 149 - 12K
    Post edited by Padone on December 2020
    December 2020
    Some quick renders. Blender shader node generated background "nebula" with a single sun giving some light. Cycles render.
    1920 x 1080 - 2M
    1920 x 1080 - 2M
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
