New DS Filament Render Engine
12425262830
  • N-RArtsN-RArts Posts: 1,609
    Luciel said:
    There was a minor update which was mostly bug fixes I think.
    However, Filament supports shadows from the first 6 lights and i'm kind of pretty sure it was first 3 before (maybe). Though maybe not.
    Ah. Okay. Thanks for the info, and replying.
    For such a small update, it's totally messed up my installation, and content library. :/
  • However, as it is clear here, there is a certain amount of demand and expectation for filaments in terms of drawing speed.
    First of all, the problem of hair penetration and the problem of not reflecting emissive should be solved. It's a draw style so it's not a problem to give up.
    That means we've entered a stage where Daz can't afford to make excuses.
    Again, it's an urgent task for Daz to solve this problem. Draw style
  • LucielLuciel Posts: 475
    It might just be my imagination.. but hair does seem a little better looking (less flickery anyway).
    But gah, installation issues are always a pain.
    edited December 2020
    The filament preview window consistently crashes my DAZ Studio Pro Public Beta 4.14.1.22 for the scene I have used to make my avatar. It's actually done so pretty consistently on prior versions although I did manage to get it to filament render a few times on the 2nd released of the 4.14.x public betas that have filament.
    Post edited by nonesuch00 on
  • onixonix Posts: 282
    Looks like this filament introduced a lot of new crashes into Daz.
      Most of them happen when you try o switch rendering engines, and typically attempt to use iray and filament at the same time will  need badly so if you are trying to do final rendering or want to use iRay viewport preview you can have a filament running or open at the same time
    although it is quite strange that filament manages to run faster than opengl for some reason
  • Officialy IS a Render Engine:
    The advanced openGL is slower to render on my PC than an iRay render.
    I am getting my Filament crashes just switching from whatever viewstyle in the ViewPort to Filament. It also doesn't matter what I have the actual renderer set to either: 'Viewport', iRay. 3DL, switching to Filament in the Viewport crashes DAZ Studio PB 4.14.1.22
  • SevrinSevrin Posts: 6,314
    This isn't universal.  I've no issues switching to the Filament draw-style in the latest public build, at least with the simple scenes I've tried it with.  My DS is pretty vanilla, though.  No Octane, or anything.
  • yeah the only issue I have faced is trying to render in iray with Filament viewport, simply run out of VRAM
    I usually switch to bounding box anyway if rendering in iray, the lowest viewport setting to tax my card the least as even openGL textured uses a fair bit of VRAM so not really an issue
  • Could someone explain the steps in doing a render in filament
    That's the whole idea. there are no problems with simple scenes
    1) Go to the right hand corner of your viewport in 4.14 and choose the icon next to the camera selection, and from the drop down choose filament PBR
    2) Profit
    Post edited by Paintbox on
  • grinch2901grinch2901 Posts: 1,247
    2) Profit
    Step 3: If you want it to render outside the viewport so you can make it bigger or save it or whatever: Under Render Settings there is a dropdown named 'Engine'.  Select 'Viewport'.  Now when you do a render it will render to whatever you selected in step 1 above, in this cas filament. Now when you push the render button you get a filament render.
    Whatever you do though, don't skip step 2!
    Post edited by grinch2901 on
  • thanks. profit?
    ALLIEKATBLUE said:
    thanks. profit?
    LOL, same as Enjoy but weird way to say it
    Post edited by Sevrin on
    The hair is looking better. It also seems to be handling transparent clothing a little better too (but that's only going by one scene that I'm working on).
    I've never had to deal with these issues before. I can't work out if it's Daz Studio, or my external HDD that's the problem :/
    Is looking better on the official version or are improvements on the Beta of DS?, I have no Public Beta installed
     So much for that.  Lost about an hour's setup when I forgot that this was a thing.  Disabled the Filament plugin until I hear it's safe to go back to it.
  •  I haven't had this happen yet
    The official version. I don't have the Beta installed either.
  • TaozTaoz Posts: 10,355
    DS 4.14.0.10, latest 460.89 NVidia driver.  No crashes or other problems while working on it.
    1314 x 901 - 2M
    Post edited by Taoz on
  • Tried this out for the first time last night and am pleasantly surprised.
    The issue I noticed though was that it shares tone mapping values with iRay when they aren't cross compatible. Are they going to introduce individual values?
  • As for losing an hours work due to crashes, I've long ago gotten into the habit of frequently saving a scene I'm working on, because DS does have a tendancy to crash out from under me... tho fortunately it hasn't done it much lately.
    That said, I should probably start poking this Filiment thing with a stick.  :D
    You might want to upgrade to smacking it with a baseball bat
  • Hi. I believe I am setting up Filament correctly, but in my viewport anything I have there shows as solid white with no textures. The texures show up in Iray or Texture shaded, just not in Filament.
    Am I missing something to make this work?
    3829 x 2043 - 448K
    Filament is generlaly more reactive to light sources. You have to dial them down when you switch between Iray and Filament as your intended output.
    I'm guessing it's the default HDRI that is causing your trouble.
    Turning the Environment intensity down to like .15 or so should "fix" it.
  • Hi, thanks. I just tried that, and made no difference at all to the scene preview. Maybe should also mention I have the Render Settings to Engine Viewport, Active Viewport. And when I render, I just get a totally blank result.
  • If it comes out as white-"blank", then it's most likely overexposed. Too many lights for the camera's eye, and Filament's eye is more sensitive than Iray.
    (It's it's black-"blank", then you don't have enough lights... which tends to be more of an Iray condition rather than Filament. Transparent/grey blank also has its own look, of course.)
    What kind of scene are you using? Is it a pre-made Iray scene? Did you light it?
    I'm guessing it's a light issue, not a surface/texture issue. Filament is supposed to handle 3DL better, but it also treats Iray mostly fine. Things with translucency/transparent surfaces/opacity maps don't react the same way at all... so if your scene is all translucent surfaces, that could be a problem.
    I would just comb through the Surfaces, turn down any lights that you have, turn down all of the point lights & spotlights, and also turn off the Headlamp (if it's on by default).
  • no, it's not a ligting issue. I've added, removed lights, changed the lights. And when I try a viewport render, all I get is completely blank render.
    I've attached a scene with a sphere with a simple blue color, lit by a distant spotlight. The images are the Iray Rendered viewport, the Filament rendered viewport, and the result when I render the viewport.
    I am thinking something with my system? Windows 10, and twin Nvidia 980Ti video cards.
    3806 x 1907 - 249K
    3810 x 1942 - 337K
    3435 x 2106 - 1M
