Super Easy Question
QuietrobQuietrob Posts: 361
But not for me.
I'm turning my favorite Gen 3 characters into Genesis Characters. It's going well except one of my characters has quite large breasts.
How do I give my genesis character larger breasts? I can't find the control.
Thank you.
  • SickleYieldSickleYield Posts: 7,652
    Do you have the Evolution or Head and Body Morphs (Genesis 1 or 2)?
  • QuietrobQuietrob Posts: 361
    I see. If I don't have either one for Genesis than I have no control over her breasts. I guess it's my fault for being behind the curve.
    If I can't find a work around than I'll save up the needed and come back with my results.
    Thanks Sickleyield!
    Told you it was easy. :smirk:
    Do you have GenX and V4 + morphs?
    YES! I mean, Yes, I do!
    I am a Poser user (ducks) so just getting around in DAZ Studio isn't seamless but I want the future. I did think the whole transfer thing from D3D would allow me to use all of old morphs.
    I'm mixing Gen 3 with Gen 4 so I can advantage of all clothing from Gen 3 and up and getting new expressions for my ported favorite characters.
    edited June 2014
    Ah, you're not the only one. I use Poser mainly too and only use DS for Genesis/G2F.
    How about A3 XinXin's head on G2F's Fiends Forever body... on the original Genesis. :P
    700 x 700 - 40K
    Post edited by Lissa_xyz on
    Thats's amazing! I'm having a hard time just finding the character I saved so I can try and add the v4++ morphs! Where do I find them!?
    Find what? The GenX'd morphs on Genesis?
    My Bad. I want to find my V4++ morphs and the parameter dials to increase the breast size of my G3->Genesis figure. I've searched but I can't find any control. I thought I could add the morphs to genesis and get breast control that way. I'm saving up for the Christmas sale (okay rent) and blast me, I already spent my coupon this month.
    I may be speaking out of ignorance in thinking that DAZ works that similar to Poser.
    edited June 2014
    Oh! Open the GenX tab and drag V4 into that (content library > poser format > library > figures > daz people), now navigate to library > pose > daz's victoria 4 > morph injections > morphs++ folder. From here, drag over each inject you want to load (loading them through the single injects versus all morphs++ at once is easiest so there are less morphs to wade though in the GenX window). You can select multiple at once via shift-select or ctrl-select and drag them all over at once.
    Now, from here, in the morphs window, expand the CHEST region and place a checkmark into all of those breast morphs at the top. You'll also need to go 1 by 1 changing the value for these morphs to 1, otherwise GenX will ignore them and not transfer them (double click the 0 in the value column to change).
    Mode: Selected Morphs
    Shape: Victoria 4
    Target: Genesis
    There's another drop down there that I usually set to smooth.
    Hit Transfer.
    Next time you load Genesis, these morphs by default will appear in the Parameters tab under Actor > Generation X > Victoria 4 > Morphs++
    Now just remember, they may or may not look as intended. Since they're for V4, ideally you'd want to use them with a character based on the V4 shape.
    If Gen3 has breast morphs like morphs++ does, you may want to transfer those instead since your character is based on Gen3 (requires the Gen3 plugin for GenX from the store, which I'm assuming you have if you're transferring Gen3 characters in the first place).
    Opening DAZ I repeated step by step what you provided above. It worked like a charm! I was able to gain back control of Genesis Breasts using the V4++ Morphs. My ultimate goal is have a V4 body but with an A3 character face and Dimension3D GenX worked like a charm. The only things I was having trouble reproducing was a particular characters breasts and her skin texture and lip thickness. It was my first try and I didn't even know about smoothing or think to dress her here in DAZ and export the cr2 with clothing. Heck to be honest I couldn't find the dials cuz I'm not used to the layout.
    So I'm thinking I load my genesis and follow your directions however use the A3 Morphs, dial in her breast size, height, dress and then export.
    Here are the two side by side.
    992 x 824 - 36K
