My genesis can not close eyes
guangh69guangh69 Posts: 167
edited June 2014 in Daz Studio Discussion
My genesis can not close eyes as in the picture.I used the eyes closed morph in the eyes morph group. It did not close the eye even I dialed the parameter to 1 and seems weird.
I reinstalled the genesis starter essentials but this problem is not be fixed.
Post edited by guangh69 on
    When you have the 'Eyes Closed' morph dialled to '1', can you look under 'Currently Used' in the Parameters pane please, and tell me what you see in there?
  • guangh69guangh69 Posts: 167
    ty for your answer.Jimmy. I recaptured a image,and there is not other morphs used
    1653 x 683 - 152K
    This used to happen at the beginning when Genesis first came out.
    A copy which used some freebie morphs, became saved over the original Genesis, and led to all sorts of problems. I am baffled here. Mine works fine (of course) but that doesn't help you.
    When you load a fresh Genesis from your Content Library pane, are there any morphs used before you do anything to it at all? (Currently Used) Is it just this eyes closed morph that causes problems, or are there other abnormalities with other eye morphs?
    edited June 2014
    After I started DS the autoloaded genesis has this problem,then I delete it and reloaded genesis from content library, and it has the same problem.
    and there is not anything in Currently Used.
    I checked other morphs and they seems work well,It seems only this one has problem.
  • RenpatsuRenpatsu Posts: 828
    edited June 2014
    Perhaps a hidden corrective morph may be causing it (e.g. due to being wrongly set-up). See if you can load a base Genesis, close the eyes, and then enable "Show Hidden Properties" (via the small three lines icon menu top right at the tab). Go for "Currently Used" with the eyes closed and see if additional items show up.
    Post edited by Renpatsu on
    edited June 2014
    Oh My God!
    There are two morphs on the whole body which are cauing this problem. When I dial Eye Closed parameter to 1.These two morphs automatically changed to 100%. I need to dial them down to 0%, I do not know why
    Thank you very much! JimmyC_2009 and Renpatsu!
    1279 x 653 - 100K
    Glad you found the problem.
    Thanks Rempatsu, I forgot about Hidden dials, mine are usually unhidden all the time.
    guangh69, if you set the morphs to zero again, and save the Genesis.DUF to your People folder, it should overwrite the one with the morphs set, then it will always load correctly. You probably knew that anyway, but I just mentioned it to be sure.
    I have not save the genesis yet. I will try to save.
    edited June 2014
    Maybe it is different problem ,,,,
    because,, it seems applied only you use poze controll .
    I do not know which product have included the MCM,
    But the MCM need to be applied only when you use the character (Brute? ).
    most of character moprh need to add MCM then adjust shape,, when close eye,
    but it usually mutipled with the character morph (head and full shape)
    so that,, it only work when you apply the character morph. (0 to 1 multipled )
    I know some product which lost the mutliple formula,, then they cause problem with poze controll.
    we may not find , untiill use the poze controll.
    when daz find bug report, usually DAZ up-date these lost formula MCM.
    How you get the Brut morph? if the Brut character is for genesis, and you bougt from daz shop,,
    you may better send bug reprot.
    it should work about all character. then all character of your genesis can not close eyes clean
    I think.
    to remove the problem,,
    you may need uninstall the MCM from data/DAZ 3D/genesis/Base/Morphs/vendor name/Prouct name/
    you can see actuall MCM name,, by parameter setting tab, then serch it,,
    Or you need manually add mutliple formula, for the MCM with the character morph,, i think,,
    Post edited by kitakoredaz on
    edited June 2014
    I think.
    Yes. You are right!
    I installed the brute for genesis with the old installer in 2012 or so. I redownloaded the brute for genesis product a momment ago, I found the files are updated on 2/19/2013. I replaced the old files with the new ones. Then genesis works fine. The problem is fixed perfectly.
    I have many content installed with the old installer. The size is big. So I did not redownloaded them with the download manager which will remind you whether some products are updated.
    Now I think maybe I should redownload the products with DIM so that if there are some updates I would know.
    Thank you so much! kitakoredaz
    Yes,, I am sorry I forgot to recomend you to re-install products ^^;
    then for thosse Up-date,, I recommend you change to DIM (as you plan now)
    the best thing of DIM clear show us when up-date products.
    And It make me very easy to Uninstall or Install process,
    and we can easy check all files and the location in package,,
    It seems good time,, check old installers and replace them to new one ^^
    Once you installed by DIM,, it very work well,, but there is some caution,,
    the start preparing , and configuration correctly,, is very important,,
    without it DIM often change dump ^^;
    so that,, before download DIM,,,hope you check DAZ documets
    and you tube Video,,
    http://docs.daz3d.com/doku.php/public/software/install_manager/userguide/start
    http://www.daz3d.com/install-manager-info
    (untill download,, the middle seciton,, "Manage your 3D contents with Install Manager" videos
    make us easy to understand,,, i think,,)
