CC#54 WiPs ~ What is it that you truly desire? after party Chit Chat
2456711
  • StezzaStezza Posts: 8,818
    edited September 2020
    I wonder what Momo desires! eeeeek!!!
    800 x 600 - 706K
    Post edited by Stezza on
  • VyusurVyusur Posts: 2,235
    Stezza said:
    Vyusur said:
    Stezza said:
    smiley
    I recognized that outfit laugh
    it's the only piece of clothing I have for G8 F & M ~ dunno where it came from, maybe one of the sales or G8 download, didn't even know I had it till I went looking for clothes lol
    I used your transfer to get it onto Genesis wink
    Cool!yes
  • Whatever happened to WIP explanations?  Nice renders, but to me, this is starting to look like another "Post your renders in 2020" thread. frown
  • DiomedeDiomede Posts: 15,398
    Idea:  All I want for Christmas is my Two Front Teeth
    - see https://youtu.be/bVRLXMRVvpA
    default Leon test render
    after alpha on two front teeth test render
    WIP - Getting rid of Two of VYusur's Leon's Teeth - I haven't done anything with the default shaders, hair, etc, yet
    - In the free plugin called daz Studio, load VYusur's figure Leon.
    - With Leon selected, use the top menu
    - Edit Figure Rigging convert convert triax to general blended weight
    - Save Leon Blended weight as a scene subset
    Load the blended weight version of Leon in a new Carrara scene
    - select the model level of Leon in Carrara
    - use the wrench to enter modeling
    - select by face, lips and mouth shading domains
    - hide selected vertices
    - select a couple polygons on each of the two front teeth.  Use plus signs to select the rest of those two teeth
    - create a new shading domain and name Front Teeth
    - In texture room, set shading domain Front Teeth's alpha to zero or black
    640 x 480 - 16K
    640 x 480 - 16K
    1244 x 795 - 178K
    1337 x 799 - 155K
    1512 x 990 - 169K
    1596 x 985 - 298K
    Post edited by Diomede on
    Quick Shader Adjustments and default eyelashes and eybrows
    Shaders have to be tweaked when going from Daz Studio to Carrara.  Here I have added the razor cut hair for Carrara, converted the Leon eyelashes and eyebrows to blended weight, and done some quick adjustments to the face shader.
    640 x 480 - 22K
    Have to disagree with you there!
    all entries have WiPs and explanations those that don't, meaning mine are not entries.
    look forward to seeing what you have done so far wink
    All I Want is My Two Front Teeth
    straight render - to be updated
    Adjusted one of my skull caps and grew a new hair for Leon.
    Hair Freebie attached as zip file
    - free for any use, except don't resell it.
    1200 x 1600 - 1M
    zip
    zip
    Dio hair for Leon 2.zip
    54K
    All I Want for Christmas is My Two Front Teeth
    with some postwork
    1200 x 1600 - 682K
    awesome work @diomede and some free hair to go with it yes
    what I do with the teeth when not using a new shader domain is soft select them and shrink them out of the way...
    listening to spotify whilst posting 'all I need is the air that I breathe' .... hmmmm enlightened
  • Very skillful hair (and render), Diomede!  Way more cool-looking hair than your original choice.
  • DesertDudeDesertDude Posts: 1,239
    Cool theme Stezza, thank you for hosting and thank you to DAZ for continued sponsorship.
    Bunyip02 said:
    Okay First Bite - P-51 Mustang my all time favourite aircraft
    Cooll render, nice job on the airplane. Cloud looks nice as well. smiley
    Bunyip02 said:
    A Loyal 4 Legged Companion
    Am using that plugin called DAZ Studio to make Multiplane Cyclorama textures from Howie's Ultra Scenery to use in Carrara. After rendering the Ultra Scenery scene in Iray I use PSP to overlay segments of the render on a Multiplane Cyclorama template.
    Cool tips for using a cyclorama, thanks. I've never tried one before. Always cool there are so many ways to put together an image.
    Bunyip02 said:
    A Pet Dragon to play with your Pet Dog
    Adorable!
    Vyusur said:
    Aliens and Sci-Fi are my inspirations for now. Here is my first attempt:
    I used native render engine and my new creature which is avaliable at Rendo.
    Very nice Vyusur, your alien looks great. I also like the perspective, we can look up and down in the environment.
    Stezza said:
    the Supweme Weader is at it again! cool
    Ha ha Stezza, could you send this 'Supweme Weader' over to my place to take care of the weeds?
    Headwax said:
    great theme - lots of goodies already popped up in t his thread
    I'm off to render a million bucks....
    Brilliant!
    Mystiarra said:
    tee ee.  bad mitten mebbe?  muskle dudes swatting the shuttlecock
    Oh dear me Misty...blush laugh
    Stezza said:
    smiley
    I think kitty desires a tasty snack.
    Bunyip02 said:
    Miss Universe
    An actual Miss Universe contestant! Awesome!
    OMG Stezza, that is delightfully creepy. That smile!
    with some postwork
    Ha, great concept Diomede! And thanks for explanations, clever way to hide those teeth. The hair looks great. Whatever you did in post the coloring of his flesh looks more 'alive', nice.
    My Preciousss
    Thanks for the comments on two front teeth, Stezza, UnifiedBrain, and DesertDude.
    Here is another quickie.  This uses Misty's G8M in Carrara freebie character, and Josh Crocket's Glumgurgle for G8M.  I modeled a quick ring from a cylinder.  I modeled the eye using the pen tool.  Fire is simple Carrara fire object, duplicated. I rendered once against a red background and once against a blue background because I applied some transparency to the eye model and wanted the blue background but the red for the white of the eye.  Aided selection and substitution using a depth pass (attached).
    Postwork.  Mostly this is a mix of the photoreal render described above and the Filter Forge graphic novel filter.
    1856 x 984 - 293K
    1600 x 1200 - 1M
    1600 x 1200 - 1M
    1600 x 1200 - 82K
    1549 x 1179 - 1M
    Cool!
    Interesting use of the Depth pass - never thought to use it to create isolated selections.
  • ed3Ded3D Posts: 2,512
    Bunyip02 said:
    ed3D said:
    Vyusur said:
    Bunyip02 said:
    Vyusur - very nice Alien !
    Thank you so much Bunyip!
    +1 ~   _ and somehow reminds of MassEffect
    HFS Races: Talarian by DarioFish - Renderosity
    Freebie ME - HFS Shapes - ME Expansion - https://www.renderosity.com/mod/freestuff/hfs-shapes---me-expansion/70433
    _alright then Thanks Bunyip~
    Catching up on the thread. Lots of great stuff.  Keep up the great work everyone.
    Stezza - great theme, the examples you include are amazing.  Thanks.
    Bunyip - hard to know where to start.  seems like you truly want everything!  My favorite so far is probably the airplane.  Nice job on motion for the propeller. Excellent.  After that, then probably one of the dog pics. Keep them coming.
    Vyusur - your new creature is very impressive.  didn't realize you had one.  will check it out.  Alien looks great and I love how the render has such soft shadows in the knooks and crannies.  (EDIT: Veronika, you have been busy!  Several new items I was unaware of.  looks great).
    Dartanbeck - Yes, 45 entries.  I want to see 45 entries from you.  LOL.
    Mystiarra - As much as I want to see you do a badmitton render, priorities, priorities.  Get your BP down and your eyes taken care of.  We need you around here!
    DesertDude, ed3D, Namtar3D, UnifiedBrain, and Headwax, happy to see you dropping by the thread.  Looking forward to what everyone comes up with.
    I've got another idea that I started modeling on my laptop.  Will get back to it for finishing touches in the next day or so.  In the meantime I may try to crank out another quickie from here.
     Escape from 2020
    Just a basic scene render in Carrara and seperate png render of KenG wasp for a transparent background and added in PSE. Modeled the time machines and also the mummy wrap for Genesis, I converted the terrain to a vertexx model and shaded it with my sand texture.. Postwork in PSE2020
    1506 x 788 - 137K
    1246 x 786 - 155K
    800 x 600 - 621K
  • Bunyip02Bunyip02 Posts: 9,275
    Stezza - Momo is definately creepy, nice escape scene - I think most of us need to escape 2020 !!
    Diomede - two front teeth is a ripper, thanks for the details about workflow on Precious
    Vyusur - any more creative art from you ?
    UB - hope you have time for a render or three
    DesertDude - trust that those creative juices are flowing
    ed3D - are you able to join in again ?
    Misty - hope you get that BP sorted so you can get those eyes done !
    Lurkers - hurry up and join in the fun !!!
    A little shack to call home !
    Loaded in a nice Gothic Castle by Luca Rodolfi - rodluc2001 - www.rodluc.com (https://rodluc2001.blogspot.com/)
    Used a Terrain texture by Flinks (Renderosity), Triplanar used in the Shader setup to scale.
    2260 x 1037 - 559K
    2269 x 1033 - 417K
    Post edited by Bunyip02 on
    Thank you very much for your nice comment!
    Thank you so much, Ted, for your kind words and for your interest!
    ~ happy to be dropping by~ thanx_
