[Released] Props & Poses Converter from Genesis 3 Female to Genesis 8 Female [Commercial]
124»
    I've run into a bit of a problem, trying to convert some G3F rings to G8F.
    It's this product here if that helps:
    https://www.daz3d.com/es-sphaerae-jewelry-vol-1-for-genesis-3-female-s
    It converts the bracelets, necklace and earrings properly, but it's not working on the rings and I can't figure out why. I watch the process and with the rings, G8F doesn't move into the G3 default position, like it does with the necklace, and earrings and bracelets, so I don't know if that means anything? But when it's finished, the rings load up in the air, where G3F's hands usually are (the T pose), and not on G8F's hand, even tho they are parented when I load them.
    Anyone have any ideas?
    I don't have that one, but it does sound like the issue is not moving the pose (or it is the symptom more likely).  I can try and look at the log to see if something is showing up there.  My questions is what body part do the rings load on?
  • Running into this error:
    2020-10-06 17:22:11.015 DEBUG: Found: D:/Program Files/My DAZ 3D Library/data/RiverSoft Art/Common/RSPropConversionFunctions.dse
    2020-10-06 17:22:11.021 DEBUG: From Figure Genesis 3 Male
    2020-10-06 17:22:11.021 DEBUG: To Figure Genesis 8 Male
    2020-10-06 17:22:11.022 DEBUG: Objects in scene
    2020-10-06 17:22:11.022 DEBUG:      Genesis3Male
    2020-10-06 17:22:11.022 DEBUG:      Genesis8Male
    2020-10-06 17:22:11.022 WARNING: Script Error: Line 255
    2020-10-06 17:22:11.022 WARNING: ReferenceError: Can't find variable: TurnLimits
    2020-10-06 17:22:11.022 WARNING: Stack Trace:
        <anonymous>()@(removed for security):/Program Files/My DAZ 3D Library/scripts/riversoft art/props & poses converter/props & poses converter g3m to g8m.dse:255
    2020-10-06 17:22:11.023 Error in script execution: D:/Program Files/My DAZ 3D Library/scripts/riversoft art/props & poses converter/props & poses converter g3m to g8m.dse
    TurnLimits is in RS2019HelperFunctions.dse.  Does that file exist in data/RiverSoft Art/Common?  When did you install G3M to G8M?
    Yep, it does. I've been trying to re-install g3m to g8m multiples times to correct this mistake, going from manually installing to resetting the entire database. It still throws that error and when I try to check its Smart Content folder, it doesn't show it.
    Smart Content will not show RS2019HelperFunctions.dse.  Was that the complete log for the run?  If so, PM me your email address and I will send you a special version that gives me more info.
  • EboshijaanaEboshijaana Posts: 576
    edited October 2020
    No, it doesn't. But if I can't access the cloud files from the 'browse to folder location' option, there is something wrong regardless.
    PM sent.
    Post edited by Eboshijaana on
  • JamieMJamieM Posts: 356
    edited April 2021
    I've just got https://www.daz3d.com/props--poses-converter-from-genesis-3-female-to-genesis-8-female ; by https://www.daz3d.com/forums/profile/RiverSoftArt ;
    It seems to convert OK. The poses appear in the designated output folder and work if I open them directly from their folder - but nothing gets added to Smart Content. I can't work out what I'm doing wrong.
    I've tried converting to: D:\Daz 3D\Studio\DazContentDriveD\People\Genesis 8 Female\Poses   (DazContentDriveD is where all my content is)
    I've tried making a new folder: D:\Daz 3D\Studio\DazContentDriveD\Poses Converted from Genesis 3 Female
    (I've tried a few other less likely options too)
    Any advice as to what I'm doing wrong would be great! Why is there no output in Smart Content  (which is the main thing I want from this product)?
    Thanks
    Post edited by JamieM on
  • RiverSoft ArtRiverSoft Art Posts: 6,971
    Thanks
    Are you sure they are not showing up in Smart Content (Files tab)?  The converted items will not show up in Smart Content Products tab as they are not part of a product.
  • robertswwwrobertswww Posts: 806
    edited April 2021
    For my examples below, I am using Props and Poses Converter from Genesis 8 Female to Genesis 3 Female but all the RiverSoftArt Props & Poses converters should work in a similar fashion.
    Please note that the manual says that items without metadata will not show up in Smart Content. If the items you would like to convert do show in smart content, then follow along here...
    @JamieM First, make sure your "Output Directory" location is correct. For example, I also use an external drive and my poses ouput directory is:
    My DAZ EXT Library --> People --> Genesis 3 Female -->  Poses --> G8F-to-G3F_Converted-Poses
     - and -
    My props output directory is:
    My DAZ EXT Library --> People --> Props --> G8F-to-G3F_Converted-Props
    In other words, you should add a converted folder inside the Poses folder or inside the Props folder if you are converting props, as smart content will pull from these folders, since your external library is mapped in Daz Studio preferences.
    NOTE: After I converted some props, I thought they did not show up in Smart Content, but upon closer inspeciton, I noticed that they did show up, but the character version name (ex. G8F)  did not change (apparently the conversion script saves the new file with the exact same name).
    For example, in my Smart-Content-01 attachment, the highlighted image, Z POL 33 G8F Handcuffs.duf is actually the converted G3F version, but the name did not update. You will notice this converted pose says, "Pose" in the top-right corner, while the next pose in my smart content folder has the exact same product name, but says, "H.Pose" in the top-right corner (that is the original G8F pose).
    To fix the name in Smart Content...
    Right-Click on the converted Pose with the wrong name and select Show Asset in --> Content Library --> Mapped Folder
    Now in the content library with the product selected, if you hover over it, the pop-up will show File Path, which should point to your output directory (G8F-to-G3F_Converted-Poses in my case)
    Now, right-click on the thumbnail and choose: Rename
    Simply change G8F to G3F (or vice-versa if you were converting G3F to G8F).
    Go back to your Smart Content tab and the converted thumbnail name still hasn't changed.
    Right-Click on the Poses category and choose: Refresh
    You will see the thumbnail Pose in smart content now has the new name, G3F in my case.
    I hope that helps you and others.
    647 x 192 - 14K
    526 x 1116 - 187K
    759 x 1114 - 201K
    526 x 1116 - 70K
    613 x 405 - 53K
    529 x 534 - 48K
    529 x 402 - 35K
    525 x 1114 - 187K
    528 x 1114 - 187K
    Post edited by robertswww on
    Thanks
    Thanks very much for the fast reply and the solution. I had only been looking in Smart Content products.  But, as you guessed, they are in Smart Content Files.
    edited April 2021
    Thank you very much for your detailed walkthrough. RiversoftArt's response solved my immediate problem but your explanation will help a lot with future content sorting.
     - and -
    Thank you @Robertswww for sharing that detailed tutorial smiley
    @RiverSoftArt I love your Daz utility products... they are some of the most useful!
    @JamieM Glad to hear you were able to get a solution!
    The only weird thing that happened one-time was when I tried to convert a pose after creating a new empty scene with the 2 base characters. The script ran but did not convert the pose. I then selected both characters in the scene tab and ran the script again and it worked. I guess it was a fluke, since it only happened once.
    By the way, is there a way that your script could save the converted prop or pose with a revised name (changing G8F to G3F or vice-versa), or is it best to Rename the converted item as I did in the above image steps?
    For example: changing the original pose: Z POL 33 G8F Handcuffs.duf
    To the converted pose: Z POL 33 G3F Handcuffs.duf
    For now, you will have to rename them yourself.  I had that renaming feature in other conversion products, but somehow it did not make it into this one.  I will have to look into it.
    @RiverSoftArt OK, thanks for looking into it... for now, Renaming the converted poses is not a problem. Thanks again for creating all of your wondeful conversion utilites!
