• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Show us your Blender Renders
«1…6789101112…26»
  • mal3Imagerymal3Imagery Posts: 714
    August 2020 edited August 2020
    Made tweaks to the wearable for issue 1 and 2 and adjusted the belt now :)  Thanks for the feed back :D
    700 x 910 - 221K
    Post edited by mal3Imagery on August 2020
  • CinusCinus Posts: 118
    August 2020
    Singular3D said:
    Cinus said:
    And now for some more Iray and cycles renders of "early 20's,ideal BMI white Girl,portraits" in a completely empty universe. Yes, I used several third party plug-ins (and my own) during the creation of the character and it took "alot of labor" tweaking nodes. etc. laugh
    The character has P3D Libby's skin. Just for fun I tried to get the skin to look similar to what it looks like in Iray. I'm a big fan of Iray but I like the cycles render more in this case. To be fair, I spent no time on the Iray settings so the Iray render can certainly be improved.
    The Iray render took 16 minutes 23 seconds. The cycles render took just over 5 minutes. If I decrease the roughness of the skin a bit (and thus the reflections that the render engine has to deal with), the cycles render time is just over 3 minutes.
    The character was significantly changed after I imported it into blender.
    I really like the hair in the Cycles render. The eyes do look better in Iray and the skin looks different but ok in both render engines. Good job!
    @Singular3D Thanks! Completely agree about the eyes. The irises look OK to me, but I have not figured out how to get the sclera to look right yet.
    August 2020
    Sorry but I see problems with both. Skin looks like plastic in both. Eyes are much better in the IRay render. Hair looks unrealistic in both - not sure which is worse. Brows better in cycles but still not convincing. Really sorry to be critical but I'm assuming that's why people are posting renders in this thread?
    You assume incorrectly @Marble. Don't know about others, but I just post to show my renders. You are also assuming that I was going for photo realism, which I was not. Criticism is welcome though :)
    I agree about the skin, it looks somewhat waxy. The goal was to see if I could get my skin materials to look similar to the way they look in Iray (for this particular skin). Making the skin a tad less shiny does help to make it look more realistic.
    I disagree about the hair. The hair styling can certainly be improved, I still have a lot to learn about hair grooming in blender, but the hair itself looks realistic to me except for the area around her left temple. That area can definitely be improved, but even with that issue it still looks a great deal more realistic than the Iray render.
    I agree about the brows. They need to be thicker. I started with too few hairs, but I was too lazy to redo them.
    August 2020
    What did you use to import into Blender, and how did you then do the hair?
    @rkrusty I imported the character with the original (Mitchy) version of the DazToBlender8 plugin. I completely changed the material nodes though. The hair was created in Blender using particle hair. The brows are also particle hair.
  • j cadej cade Posts: 2,310
    My general rules: Treat contiguous meshes as a unit > so in G8 cornea and eye surface should hare identical materials as should the iris and sclera (This one isn't limited to Iray).
    For the Cornea and eye surface use a glass node. mix a glas node with its ior to 1.377 with a transparent node. Blend them via a mix node with the factor a light path node > is shadow  This will make the eye have proper refraction without casting shadows. also provifed the bump or normal map your using on the sclera doesn;t have a weird seam where the cornea transitions to the cornea (a lot of textures do and it annoys me greatly) plug it in to the glass node at low strength
    for the iris and sclera I like loottts of sss for the sclera. make it so theres less sss on the iris with a map (most characters will have a black and white map that you can use for this)
    It has some major advantages over iray as you can get proper refraction without weird shadowing. However I will say in irays favor it does caustic effects much better which can help make the eyes look less flat
    and the actual nodes for the cornea.eye surface as describing nodes is hard to do
    1588 x 1008 - 691K
    Post edited by j cade on August 2020
    August 2020
    Thanks j cade! Will definitely give that a try. May I ask which characters eye textures you were using in that render?
  • nicsttnicstt Posts: 11,715
    August 2020
    mal3Imagery said:
    Thanks guy!  I appreciate the honesty.  Especially since I can't make edits to clothing after it sims in Daz.  So I won't be able to get the results I would like if it were from MD and modified in Blender.
    You're welcome.
    My original first comment: Bloody Hell, still applies.
  • TheKDTheKD Posts: 2,711
    August 2020
    Padone said:
    What figure is that ?
    I think that one started using dayton loaded for the base, then I dial spun in some other stuff.
    For the SSS settings, it was set at whatever diffeo defaults to. It was more of a one-off render I did on spur of the moment, after I rendered a few thumbnails I was redoing for a clothes set. So I didn't save a scene file or blend or anything. I assume that diffeo reads what the DS SSS settings are at, so it would probably be better if I remembered which random skin I slapped onto the mannequin before rendering it lol.
  • brainmuffinbrainmuffin Posts: 1,270
    September 2020
    This is quite a rough experiment using a green screen clip off of YouTube (link in the description) and I didn't key her movements to the camera (yet, that's next to learn). Urban Future 3 using Dreamlight's Iray add-on in macOS to Blender on Linux via Diffeomorphic. Cycles Render.
    September 2020
    That looks decent Brainmuffin; lighting doesn't quite match the figure or background - depending which you need.
    September 2020
    One for the thread :)
    September 2020 edited September 2020
    Yeah, I'm not sure why she looks so washed out. I'll work with it  some more. Took me 3 days to not have Cycles render it as a pink rectangle.
    I'm also not sure why she looks so close to the railing. The plane with the clip is set back under the overhang.
    Post edited by brainmuffin on September 2020
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,238
    @brainmuffin Please keep us (well, me at least) up to date on your progress! I'd be interested to know what is causing the image to wash out as well.
    Edit: Or, I could just subscribe to your channel, or to what I assume is your channel...
    Post edited by TheMysteryIsThePoint on September 2020
    September 2020
    @j cade
    I had no idea there was a light paths node :) Thanks for that.
    September 2020
    Yep, that's my channel. It is a mix of a bunch of things.
    September 2020
    Another test and learning render, this time with a different green screen clip and an added drone (https://www.daz3d.com/recon-drone). I do see a few issues. The Drone is clipping through the causeway and the green screen subject still isn't casting a shadow. The Urban Future 3 set is using an IBL, so I may have to add a spot off camera, not sure. Will do some more research. I have ordered more memory for this old Linux rig and that should let me start rendering with a bit more detail. I'm really pushing the 4 GB of the current spec.
    You'll likely need to add a shadow plane.
    Add a normal plane, scale it appropriate; apply the scale if you do it in object mode Ctrl A.
    Making sure the plane is selected, navigate to the Object Properties, and under Visibility, check Shadow Catcher.
    Although, as this is an environment and not an HDRI, maybe it's something else.
    Post edited by nicstt on September 2020
    September 2020
    Thanks, I'll look into that.
    I'm also trying to figure out why the green screen insert looks so washed out. I exported it as a series of TIFs, but they look darker.
    September 2020
    btw, is it eevee or cycles?
    This is Emma & Jordi Makenna; discovered the character whilst trying to find an image I dropped into a folder. :) I actually found four charactes like that, don't you just hate that!
    Just threw her into Blender for some testing; has some tattoos I'm going to treat as overlays - see how it works out with my materials; it should work ok.
    Was converting some items to tried those too.
    1920 x 2160 - 7M
    September 2020
    @brainmuffin
    Thanks for posting your milestones. This is really interesting what you are doing and one of the more innovative things that really shows that getting your content rendering well in Blender is the beginning of the journey, and not the end.
    September 2020
    @brainmuffin
    Thanks. I was wondering if I have clipped the black range on the green screen, but the TIFs still seem darker. I haven't quite figure out that yet. I'm also looking into Cycles and the settings that help.
  • mike_from_nzmike_from_nz Posts: 113
    Rendered using Cycles. Was really happy with the orc, but for the life of me could not get the female's hair looking right :(
    2133 x 1200 - 2M
    Post edited by mike_from_nz on September 2020
  • SadRobotSadRobot Posts: 116
    September 2020
    You need to raise transparency bounces. Try something like 48 or maybe higher.
  • Krys KryngleKrys Kryngle Posts: 313
    September 2020
    Can you post a screenshot of the node setup for the hair material?
    September 2020
    Aha, I will look at that today.
    September 2020
    I will try and pop on today :)
  • MendomanMendoman Posts: 404
    September 2020
    @mal3Imagenery Just wow! Your renders look really great, both characters and clothes. Well done. Can't wait until your clothes are available in the Daz store yes
    September 2020
    A little closer, but now she looks like she's floating about the ground a bit. I rekeyed the video in Final Cut and added a shader to the image plane. The shader is really the better change. I also increased the number of samples Cycles was making.
    September 2020
    that's a really cool composite there
«1…6789101112…26»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
