X 300 Star Chaser [Commercial]
acharyapolina
X 300 Star Chaser is a realistly sized starship complete with a cockpit, a sleeping quarters, a shower room and engine room.
Inside cockpit the seats move back and forward, the shifters move up and down. All doors open and close.
The starship has a landing ramp that can be rotated open when the starship has landed and both the side wings can be rotated out of the way. Also includes a rotating communications disk on top.
Some renders of the current work.
Post edited by Chohole on
Any comments or criticues very much welcome. :)
Im happy you like it. :D
Looks awesome. Love the details and the style. One question, how many sleeping berths are there?
There are 4 sleeping births. each has a TV on the wall that can be changed to different channels depending on image used. :)
This is fantastic!
Thank you all :)
The renders look really good!
But I wonder, does this mean DAZ has to always load every single map for every render? Eg. If I'm doing an exterior render (like the first five of your examples) does DAZ also have to load all the interior maps?
If so, that seems unnecessarily resource heavy. There should be one-click options to load/unload all interrior and exterior maps. The interior could be further divided into several areas. I doubt there will be renders where the cockpit and shower area are visisble at the same time.
I created the starship to be an empty shell, so you can only render just the starship and no interior, as it would be too much processing power to render everything all at once. and If you want to render only the interior you can do that as well. Just load the interior prop and render away without the outer starship being in the way.
Here are three more renders of the outside without loading the inside prop.
Awesome
Epic, when is it out!?
Will be submitting it soon. :)
Unless the cockpit IS the shower area.
No there is a shower area in the bathroom section. you have a sink and mirror, a toilet and a shower all designed to be more futuristic ish.
You are not looking for surfaces, you are looking for parts - bones on a figure, but this is made of parented props so you need to expand the figure and seelct those. Unfortunately there are no helpful labels, and no limits set, but the ramp and ramp hinge need to rotate around the Z axis and the wings around the X
