X 300 Star Chaser [Commercial]
acharyapolinaacharyapolina Posts: 733
edited August 2020 in Daz PA Commercial Products
X 300 Star Chaser is a realistly sized starship complete with a cockpit, a sleeping quarters, a shower room and engine room.
Inside cockpit the seats move back and forward, the shifters move up and down. All doors open and close.
The starship has a landing ramp that can be rotated open when the starship has landed and both the side wings can be rotated out of the way. Also includes a rotating communications disk on top.
Some renders of the current work.
Post edited by Chohole on
  • Any comments or criticues very much welcome. :)
  • AnEye4ArtAnEye4Art Posts: 867
    I am drooling for this!! Beautiful.
  • Im happy you like it. :D
  • Looks awesome. Love the details and the style.  One question, how many sleeping berths are there?
  • There are 4 sleeping births. each has a TV on the wall that can be changed to different channels depending on image used. :)
  • WolfwoodWolfwood Posts: 979
    This is fantastic!
  • KA1KA1 Posts: 1,012
    This is EPIC! Just wow..
  • Thank you all :)
  • HylasHylas Posts: 5,287
    The renders look really good!
    But I wonder, does this mean DAZ has to always load every single map for every render? Eg. If I'm doing an exterior render (like the first five of your examples) does DAZ also have to load all the interior maps?
    If so, that seems unnecessarily resource heavy. There should be one-click options to load/unload all interrior and exterior maps. The interior could be further divided into several areas. I doubt there will be renders where the cockpit and shower area are visisble at the same time.
  • I created the starship to be an empty shell, so you can only render just the starship and no interior, as it would be too much processing power to render everything all at once. and If you want to render only the interior you can do that as well. Just load the interior prop and render away without the outer starship being in the way.
  • Here are three more renders of the outside without loading the inside prop.
    1000 x 1300 - 850K
    1000 x 1300 - 1M
    1000 x 1300 - 1016K
  • ErdehelErdehel Posts: 387
    Awesome laugh
  • LintonLinton Posts: 543
    Epic, when is it out!?
  • Will be submitting it soon. :)
  • GordigGordig Posts: 10,708
    Unless the cockpit IS the shower area.
  • No there is a shower area in the bathroom section. you have a sink and mirror, a toilet and a shower all designed to be more futuristic ish.
  • RtesianRtesian Posts: 12
    edited September 2024
    "The starship has a landing ramp that can be rotated open when the starship has landed and both the side wings can be rotated out of the way" I agree the purchased X 300 is one of Daz's better starship. Please provide more detail how the ship's ramp opens. Where is it and which wings need to be moved out of the way? The Surfaces panel does not refer to the wings/ramp or the Parameters panel.
    Post edited by Rtesian on
  • You are not looking for surfaces, you are looking for parts - bones on a figure, but this is made of parented props so you need to expand the figure and seelct those. Unfortunately there are no helpful labels, and no limits set, but the ramp and ramp hinge need to rotate around the Z axis and the wings around the X
