CARRARA CHALLENGE 53: Cartoons & Comics - WIP
1356712
  • Bunyip02Bunyip02 Posts: 9,264
    cool stuff Bunyip yes
    Thanks !!
  • DiomedeDiomede Posts: 15,393
    Bunyip- -​Thanks for the very clear explanations.  Morpheus the adventurer!
  • StezzaStezza Posts: 8,783
    edited July 2020
    great info being posted yes
    Got a chance today for another render
    Used Catoon retextured with Carrara hair and morphed into a Racoon type of creature, also modeled the suit and the mozzie and Caroot
    I am not an Aphid!
    1508 x 812 - 200K
    900 x 675 - 752K
    Post edited by Stezza on
    I am not an Aphid!
    Love it !!!
    edited July 2020
    Scrappy & Elorn WIP-1 - Not an Entry
    WIP - Scene, used the SciFi Corridor A which had a load of instances in it
    Used a Plugin called DAZ Studio to fix the instances - Instances to Objects - https://www.daz3d.com/instances-to-objects
    Test Render
    Used Topaz Adjust
    Used PhotoDonut to get a Graphic Art look to the render
    2262 x 1039 - 2M
    2421 x 1031 - 476K
    1600 x 1200 - 2M
    1916 x 1035 - 1M
    1918 x 1042 - 3M
    Post edited by Bunyip02 on
    edited July 2020
    Scrappy & Elorn WIP-2 - Not an Entry
    Opened the PhotoDonut image as an extra layer with the render in PSP, adjusted the Opacity of the PhotoDonut image until I got enough detail showing
    Did the Speech Bubble in PSP and added an Alien Font Text, you will need a good imagination to work out what is being said !
    Test render - is a little dark
    Used a one-step fix in PSP
    Final image
    1925 x 1044 - 1M
    1914 x 1039 - 1M
    1600 x 1200 - 4M
    1919 x 1031 - 1M
    1600 x 1200 - 5M
    Stezza - Catoon the exterminator.  Hilarious.
    Bunyip - I've never tried instances to objects.  Thanks for the tip.  yes
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Bunyip, I apologize for not chipping in sooner.  I will get a WIP (or two) done eventually, but there is a major project that will take most of my forum time in the coming months.
    Maybe that is a good thing.  I get tired reading posts that tell me that I should be using Blender instead of Carrara. angry
    Another cartoon Challenge, eh?  In the previous one, it was a bit of a slog to get participants.  Hopefully you will have better luck. yes
    Then again, I would be happy doing toons for every Challenge.
    Thanks for the interesting tip regarding Instances to Objects.  I didn't even know that such a product existed.
    Instances To Objects - the more instances there are the more objects there will be and the greater the file size will be !
    I had to stop my major project for this challenge so I know how you feel !
    Would like to see Carrara posts in the Carrara Forum....
    After all the doom and gloom of the last 4 months I definately needed something a bit more enjoyable, hopefully everyone else feels the same way. The net is fairly wide from comics to cartoons, cover pages to Graphic novels, should be plenty of oppurtunities for everyone !
    Would also be happy doing toons, plenty of scope there.
    Instances to Objects is a very handy tool, just note that for very large Howie type scenes there is also a corresponding increase in size of the file that has been converted !
  • DartanbeckDartanbeck Posts: 21,967
    Wow!
    Wow!
    Hello Dart, have you got time to get away from that major project of yours and do a render or two ?
    edited July 2020
    How to train an Elephant for a Circus - EEEEK Mouse ! WIP-1
    Scene WIP
    Test render
    Topaz Adjust
    PSP PicToPainting Plugin
    2265 x 1033 - 725K
    1600 x 1200 - 2M
    1916 x 1039 - 944K
    1914 x 1026 - 2M
    edited July 2020
    How to train an Elephant for a Circus - EEEEK Mouse ! WIP-2
    PicToPainting image placed as second layer to render, adjuted Opacity to what I liked
    Added Speech Bubbles and Text
    Final Image
    1918 x 1042 - 1M
    1925 x 1044 - 1M
    1600 x 1200 - 5M
  • HeadwaxHeadwax Posts: 10,421
    edited July 2020
    Final Image
    wow you are really in your element here terrific image postork and storyline
    edit - just saw Dart's comment :)
    Post edited by Headwax on
    I am not an Aphid!
    ha ha very excellent - havent seen one of those spray bottles for a while
    edited July 2020
    Bunyip02 said:
    Super Ribbet complete - eye fix
    In PSP, added a new layer eyes, copied the eyes from the render layer to the eyes layer.
    Edited the eyes with the eraser tool.
    Complete eye fixed render - thanks diomede !
    another classic @Bunyip02
    thanks @Diomede and @Bunyip02 for commenring on little johnny too
    looking forward to seeing how that hair turns out tooo Ted
    Final Image
    Thanks !
    Another Thanks ! Also Looking forward to see what renders Johnny and the Jetta Hair bring forth !!!
    for some reason it reminds me of Serat !
    edited July 2020
    sorry to be so slow, doing tax and crap
    "Boy finds spaceship in back yard." - as you do
    Took Luna lander and retxtured it with another spaceships texture no longer available here, used Shader Map 4 to extract a normal map of the new spaceship texture, combined old texture and new texture in shader room using Fenric's layer tool - you can select multiply overlay screen dissolve etc
    post work with affinity pro tone map, fotodonut, topaz simplify, for the sky I ran a photograph through Topaz Impression to make it look hand done
    used obj pass to isolate elements in the render
    then used an old landscape painters' trick where you make a horizontal foreground compositional elements quite dark to give  a sense of atmospheric depth
    prepostwork attached :) I used Carrara inbuilt Toon Pro thing as well and rendered out a shadow pass so I could add them back into the render if necessary
    will upload a b and w one as well
    2000 x 1907 - 3M
    2000 x 1907 - 2M
    edited July 2020
    here's two more variations
    Colour one tone mapped into b and w
    Second one is a colour layer placed over the b and w one. Which is my preference as the first colour one is too pastellly
    Pencil like texture is from fotodonut
    2000 x 1907 - 3M
    2000 x 1907 - 4M
    edited July 2020
    another panel in the spread - think I'll go with this style
    pre post
    2000 x 1907 - 3M
    2000 x 1907 - 2M
    Interesting - Georges Seurat - https://en.wikipedia.org/wiki/Georges_Seurat
    edited July 2020
    Better to be sure with your tax !
    Nice find in the backyard, would make a great Cubbyhouse !!
    With Fenric's layer tool I assume you are referring to the Layer Blending tool, have included a couple of screenshots for those who are unfamiliar with it.
    1. Click on your Color Channel
    2. Click on Fenric
    3. Click on Layer Blending
    4. Click on Layer Blending Mode - choose one.
    2247 x 1039 - 623K
    2260 x 1035 - 554K
    Like this colour one !
    pre post
    Anticipation is building up....!
    edited July 2020
    There's a Bear in there ! WIP-1 - Not an Entry
    WIP - Scene
    Test render
    Dynamic Auto Painter
    2265 x 1037 - 1M
    800 x 650 - 936K
    1921 x 1037 - 2M
    edited July 2020
    There's a Bear in there ! WIP-2 - Not an Entry
    Opened the DAP image above the render layer in PSP, adjusted Opacity to get some detail
    Wanted a frame around the image so into Filter Forge
    Finished image
    1925 x 1044 - 1M
    1535 x 1026 - 1M
    1600 x 1300 - 5M
    edited July 2020
    a bit of time for another render
    of that most fantastic crime fighter of all time
    the fantastic fowl
    striking terrific terror into the hearts of criminals everywhere!
    Chickenman
    modeled the chicken head, tail, bucket, feed holder, toilet roll and packet and the chicken feet laugh
    800 x 600 - 535K
