Novica & Forum Members Tips & Product Reviews Pt 13
13536384041100
  • NovicaNovica Posts: 23,925
    edited June 2020
    480 x 600 - 572K
    Post edited by Novica on
  • nonesuch00nonesuch00 Posts: 18,856
    Any advice for any DAZ Originals to pick up in the huge $1.99 sale? I've gotten the the male & female Centaur for Genesis 8, male & female Creature Creator HD for Genesis 2, Reptilian 6 HD, Minotaur 6 HD, These are components of the Genesis Supersuit Bundle: (Genesis Supersuit, Genesis Creature Creator, Build your Castle Bundle).
  • memcneil70memcneil70 Posts: 5,815
    edited June 2020
    @nonesuch00, double-check your cart and the selections. From what I just read in the sales error thread is there was a major glitch this morning in the $1.99 sale and a lot of those newer items have been removed. I am only seeing a few G2F, Genesis, V5, and a slew of V4/M4 items now. All really old stuff that has been picked over. Hairs, characters or morphs.
    Post edited by memcneil70 on
    edited June 2020
    OK, hmmm. Well I guess they'll be glad to know I was only interested in Genesis 2 or earlier and didn't buy much. At first I thought it was a glitch but then the specific items for $1.99 weren't fitting any particular pattern or genre so I thought it was legit. Especially when it was still active at 4:30 AM EST.
    Oops, I did buy the Genesis 8 Centaurs, male & female, so I'd have Greek mythology counterparts to the Minotaur 6 for Genesis 2 I bought. I guess that Minotaur 6 was a mistake too although I've seen it definately less than $10 before I think.
    Post edited by nonesuch00 on
  • sueyasueya Posts: 858
    I enjoy experimenting with Briar, Bramble and Bean. The character in the centre  here is either Keane or Dean because he has FW Denton's texture and is a cross between Kincaid and Bean's Morphs
  • FishtalesFishtales Posts: 6,228
    edited June 2020
    Another SandIrayed render. Everything that wasn't Iray when loaded is now smiley Used The Dead Forest for the Environment with the Matte Fog function.
    Who's Stalking Who?
    2020-06-21 10:10:22.094 Total Rendering Time: 2 minutes 14.57 seconds
    Click on image for full size.
    Post edited by Fishtales on
    Fishtales said:
    Etamin said:
    Fishtales said:
    Etamin said:
    @fishtales Your steam carriage images look great.  If I may, what environment are they set in?
    Thanks, Peter
    It is the HDRI from the Yosemite set Part 1 plugged into the Environment Map of the Iray Dome.
    Thank you.  I hadn't reallu looked at that set, as it predates iray, and I didn't think it would be of use.  Clearly it is/
    Just clicking on it to load wont work in Iray, well not without a lot of work, only 3delight, but if you load the HDRI into the Environment Dome of Iray that does.
    @Fishtales, I've got this as well (https://www.daz3d.com/hdr-prosets-yosemite-pack-one) but when I click on either TIF files in the textures of Dimension theory in the runtime (the ENV or HDR tif files) neither will illuminate the scene?  Any thoguhts?  (I asked FirstBastion as well in another thread, as they seemed to get it working with v2...but then I found you got it workijng with V1)
    3dOutlaw said:
    Fishtales said:
    Etamin said:
    First Double Click on the Prop to load it into studio.
    Open the Environment Tab and click on the Enviromemt Map and look for the YosemiteHDR.tiff image from the drop down and load it.
    Open the Scene Tab and delete the Yosemite item.
    You should now have the Image giving light in the scene, but it will be overall lighting. What I do is use a Distant Light as the sun and line up the shadows of whatever I am using in the scene with the burned in shadows in the image.
    I see a DT-YosemiteENV3.tif and a DT-YosemiteHDR3.tif, and neither seems to illuminate the scene at all.  I can load the JPG and it shows in the dome with some general overall light.  I suppose thats what you must be using.  I didn't realize you used a distant light as well.  Thanks for the info!
    edited June 2020
    @3dOutlaw
    I use the HDR*.tif. The ENV*. tif is just lighting without any background just colours.
    Here is a quick test image. I just added a Cylinder Primitive.
    2020-06-23 19:02:39.833 Total Rendering Time: 41.13 seconds
    1920 x 1080 - 2M
    OK, maybe Pack two and pack one operate differently (or were fixed).  Looks like that above is from Pack two, which I dont have.
    In pack one, the ENV's are small blurry and dark, and the HDR's are large and dark.  I am going to redownload in case they got updated ast some point.
    I just looked and that is Yosemite7 from Pack two.
    edited June 2020
    @3dOutlaw
    This is YosemiteHDR3.tif from Pack one.
    1920 x 1080 - 2M
    Yea thats an odd one, here is what I get with a new scene, cylinder and TIF in environment map
    1371 x 628 - 188K
    Did you delete the Yosemite item from the scene tab? There should only be the camera and distant light, if you added one although you should see something without it.
    I never loaded it, I just pointed straight to the TIF file, since I knew where it was.  There is a Cylinder and Camera.  (no distant light, since I did not cares about shadows at the moment)
    edited June 2020
    I just tried that with three of the HDR tif files and they all worked. I noticed the cylinder isn't at  the centre. Try setting all the parameters to zero then centre the camera on it and see what happens.
    Remember our huge Great White Shark who visited the Gulf of Mexico? Unama'ki is pretty far out in the Atlantic, across from New Hampshire / Maine. Here's her track.
    edited June 2020
    Oh what a deal I got on the Genesis 8 bundles. For once, I waited, and I was able to get Dasan 8 Pro Bundle FREE.  What did you folks pick up?
    Here's the ones I went for with the additional 50% off.
    These I got because they're the same style, and with DOF they'll make good backgrounds. I think the grass is sparse and I don't care for the ground materials, but they are good starting points to add other things to it. With having the same style, you can expand your storylines and keep the same "look" to the environment.
    • My Place
      My Place     $16.95     $3.43    80%
    • The Park Way
      The Park Way      $21.95       $4.45         80%
    A shout out to @nath   What a wonderful gallery image. Let's give it some love with likes!
    Take a GOOD LOOK at the promos. SO much you can do with this!!!! All mix and match!
    Who's Stalking Who?
    Very clever- and eerie.
    Novica said:
    Who's Stalking Who?
    Thank you.
  • firewardenfirewarden Posts: 1,488
    edited June 2020
    I was majorly bummed, as the only two Genesis 8 Pro Bundles I don't own are Angharad and Aubrey, and they weren't in the mix, so no Genesis 8 love for me. Mostly because I waffled on them until the discounts fell off. I had two lone Genesis 3 Pro bundles that I didn't own, Kimo and Darius, although I owned almost all of the content. I got those, as I have no real interest in the three Genesis 2 Pro bundles I didn't have. The 80% off of the artist sale was really nice, though.
    I only went for it because I like Ashan so, so much. Otherwise, he would have waited like Angharad and Aubrey. For the artist sale, I got:
    Sacrosanct: Poses and Expressions for Genesis 8 and Morningstar Wings
    Blasphemy: Poses and Props for Genesis 8 and Infernal Wings
    ExMachina Wings for Genesis 8 Female(s)
    Z Mountain Bicycle and Poses for Genesis 3 and 8
    iREAL Animated Butterflies and Wisps
    GHD StoryBook - Faces and Morphs for Sakura 8
    Alaric HD for Genesis 8 Male
    Mina for Posey and Petunia
    Clove and Wytch Accessories for Posey and Petunia
    Z Injury Recovery Props and Poses for Genesis 8
    Edited to fix links.
    Post edited by firewarden on
  • Charlie JudgeCharlie Judge Posts: 13,490
    edited June 2020
    I paid $39 for Ashan 8 Pro and 3 addons and got Alawa 8 Pro free. Since I had bought Alawa 8 Pro less than 30 days ago I got a refund of the $28 I originally paid; so, my effective price for Ashan 8 Pro and addons was only $11. Altogether here is what I purchased:
    Ashan 8 Pro Bundle 70057 1 $22.26
    dForce Cleric Outfit Textures 70811 1 $3.10
    dForce Insidious Monk Textures 70835 1 $3.08
    Ashan 8 HD Add-On 70051 1 $8.23
    Alawa 8 Pro Bundle 67327 1 $0.00
    Z Pin Up Mania Props and Poses for Genesis 8 Female 65425 1 $3.84
    Z Up For Drinks Props and Poses for Genesis 8 59969 1 $3.43
    dForce Trend Outfit for Genesis 8 Female(s) 66993 1 $3.84
    dForce Bridge Officer Outfit for Genesis 8 Male(s) 62221 1 $2.44
    dForce Desert Raider Outfit for Genesis 8 Male(s) 62997 1 $2.45
    Z Final Battle Count Poses for Genesis 3 and 8 65809 1 $3.23
    Z My Favourite Gadgets - Props and Poses for Genesis 8 56143 1 $3.63
    dForce Morphing Fantasy Armor Genesis 8 Male 67629 1 $5.06
    Foggy Forest 66567 1 $4.04
    CB Saltair Clothing Set for Genesis 3 and 8 Female(s) 47331 1 $5.05
    Subtotal $542.25
    Discount -$161.65
    Tax $4.98
    Store Credit -$78.66
    Grand Total $0.00
    Total price 78.66 less $28 refund = $50.66
    Post edited by Charlie Judge on
    Very nice it is too.
    Snow Leopard Catalyzer
    2020-06-24 10:28:54.144 Total Rendering Time: 4 minutes 59.13 seconds
    @Fishtales, Very Nice! And put my decision to wait or put in my cart over the edge. Now the kitty is in my cart. Thanks. Really. Mary
    You need the Lion and Addon too unfortunately so I had to buy all three :)
  • gitika1gitika1 Posts: 948
    Curious to know, did you get the bundle because he interests you or because of the accompanying deal?  If they had done a special like this when Valentino came out, I would have snapped it up then.
    @ Firewarden: The links are to your product library.
    I like supporting male products, but also the bundle had several of interest :)   He was also the only Pro Bundle in that offer who I didn't have though :)
  • L'AdairL'Adair Posts: 9,479
    I already had the lion and the addon… I had to buy them when Kimbo the lion cub was released, as I couldn't resist him! Sure made buying today's cat an easy decision. I got the Smilodon Populator while I was at it, even though I have no idea when I'll use that!
    I just really love AM's animals, especially the furry ones.
