Shader-mixer: Double sided materials? YES! (SOLVED)
13»
  • Richard HaseltineRichard Haseltine Posts: 111,715
    It is not always clear, but judging by recent updates DAZ is standardising on Shader Presets as the user folder at least, even if the preset is for applying a new custom shader. However I would regard a Shader Mixer network as a shader (with presets), not just a set of presets.
  • marcuswilmmarcuswilm Posts: 23
    edited May 2014
    Post edited by marcuswilm on
    edited May 2014
  • GuptatsgGuptatsg Posts: 52
    Is there any way to view postings or comments of "maruswilm" comments and his postings - all his postings in 'youtube' , 'sharecg' and 'marvelous designer forum' and in DAZ3D forum also are deleted are vanished - his postings and work are very good reference in all respcts.
    thanks
  • Nathy DesignNathy Design Posts: 1,178
    With Iray, it is different ?
    I'm not sure of the answer Nathy Design...it's been a while since I played in ShaderMixer.
    Iray has it's own blocks(MDL) whether they have the right blocks to create this network I'm unsure but I would imagine it's doable but it may involve different blocks...maybe Richard or MJC1016 would know.
  • 3Diva3Diva Posts: 12,058
    Oso3D has a double-sided shader for Iray that's also a Merchant Resource: https://www.daz3d.com/oso-janus-double-sided-shader-merchant-resource-for-iray
  • Faux2DFaux2D Posts: 462
    Is there a way to make one side transparent and the other opaque?
