• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz3d to Blender Workflow
«1…45678910»
  • SnowSultanSnowSultan Posts: 3,820
    May 2020
    Thank you for confirming that. Since it took 17 years for the Blender devs to give it a decent interface, I guess I can wait another four or five until that gets fixed.  ;)
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,329
    May 2020
    I feel you... there was a similar argument for right-click-to-select as well. That's what happens when you let the programmers design the interface.
  • mindsongmindsong Posts: 1,761
    May 2020
    clearly not just a blender thing
    --ms
  • PadonePadone Posts: 4,179
    May 2020 edited May 2020
    @SnowSultan Not sure if this may help. If you go to edit mode you can select geometry based on materials that's some sort of "surface selection". I agree the material manager in blender is to be improved and personally I can't understand why they missed it in 2.8 that was everything about workflow so materials are a key point there.
    Then as usual Thomas comes to the rescue and provides some better tools.
    https://diffeomorphic.blogspot.com/2020/04/mini-material-editor-revisited.html
    718 x 217 - 52K
    Post edited by Padone on May 2020
    May 2020
    Yes indeed, every project needs those who think like programmers and those who think like artists because you'll have to look high and low for someone who can do both.
    Thanks for those links Padone, good stuff to know. I've decided not to make a full switch to Blender for now, but if have a moment, could you perhaps share the proper import and export settings for getting a prop or figure out of Studio, into Blender for morphing, and back to Studio? I pretty much know what has to be done (export as OBJ at base resolution, don't add or subtract any polygons or resize, export back as OBJ, then use Morph Loader Pro to apply it), but I'm reading different directions for which options to leave checked and some settings are different or added in 2.8x. Sorry to bother you with that, hope it's not too much trouble.
  • nicsttnicstt Posts: 11,715
    May 2020
    SnowSultan said:
    Can someone tell me if there is a way to lock the names of surfaces in Blender so they do not get renamed when a different material is applied to them? For example, when I import a DAZ figure, "Slot 1" is technically the Torso surface, but it is named "Torso" based on what it was called in Studio - all of that is fine. However, if I accidentally apply the Arms or Cornea material to it, the name changes and if you don't remember that "Slot 1" is the actual Torso surface, it can be incredibly frustrating to find that misnamed surface again. What I basically want to do is either rename the Slot values to actual surface names, or have something like the Surface Selection tool in Studio that lets me directly select a surface.
    Thanks in advance for any help.
    Ha, yeh over the years it's caught me out a time or two.
    @SnowSultan Technically to make a morph it is enough to export and import back the geometry information without changing the vertex order. Everything else is not needed. Pay attention to G8 figures since the eyelashes are extra figures so they need to be exported separately. That's what the "ignore invisible nodes" option is for. Then I prefer to work in blender with blender units so I export and import back with the blender scale, but that's optional.
    Below the settings, I included polylines just in case: daz export, blender import, blender export, daz import.
    367 x 511 - 54K
    212 x 387 - 21K
    210 x 660 - 34K
    469 x 433 - 58K
  • andya_b341b7c5f5andya_b341b7c5f5 Posts: 694
    May 2020
    Maybe I am misunderstanding your difficulty, but you could create a vertex group named after each material ('surface').  For this purpose, they are roughly equivalent to a selection set in DS.  You can then select any vertex group and (re-)apply any material you want.  A bit tedious to set them up, but it could be done with a Python script.
    Blender 2.83 is due for release in a few days, and I've been looking at the render speeds.
    I'd done some tests in 2.82 between my 980ti and Threadripper 1950x
    Blender 2.82a
    980ti
    512 x 512-    3:32.07, 3:27.98, 3:28.58, 3:28.59
    256 x 256-    3:59.65, 3:56.46
    Threadripper 1950x
    16 x 16        3:45.01, 3:44.03, 3:47.64
    32 x 32        3:40.43, 3:37.69, 3:27.44, 3:34.30, 3:39.22, 3:35.86, 3:37.06, 3:38.85, 3:35.22, 3:36.28, 3:35.46
    64 x 64        3:39.01, 3:34.61, 3:33.08, 3:34.83, 3:33.27, 3:32.45, 3:33.89, 3:34.80, 3:32.60, 3:35.44, 3:36.85
    128 x 128    3:40.50, 3:37.64, 3:38.46, 3:38.69
    I was surprised that the threadripper actually beat the 980ti once, but am wondering if I misread as no other renders have come that close; although the difference certainly isn't that great.
    I did a larger number of tests for tile size 32 and 64 due to the closeness of the results. 64 just edges it, but it is scene dependant so may actually be better to use 32 at first. On the 980ti, 512 was easily the best
    Blender 2.83 nightly build
    980ti
    512 x 512    2:31.21, 2:31.13, 2:27.25, 2:27.98
    256 x 256    2:56.71
    Threadripper 1950x
    32 x 32        2:07.48, 2:07.45, 2:08.10, 2:04.80
    64 x 64        2:06.42, 2:05.64, 2:07.81, 2:09.05
    512 x 512    6:24.25
    BMW Test
    980ti        1:44.85, 1:45.36, 145.39
    1950x        1:07.87, 1:08.52, 109.30, 1:10.30, 1:10.32
    Yes, the threadripper was faster than the 980ti; I suspect that this will vary, depending on the scene makeup, which is why I decided to run the long-standing MikePan BMW test. The only change I made to the Mike Pan test was to enable Adaptive Sampling, new in 2.83; the image is taken from my personal scene I was rendering. I'm putting together a scene I can try and compare between Iray and Cycles.
    345 x 437 - 30K
    Post edited by nicstt on May 2020
    May 2020
    All a matter of opinion.
    I liked 2.5 onwards, although am fully on board with thinking 2.49 and prior sucked.
    May 2020
    Padone said:
    @TheMysteryIsThePoint You can also convert the standard daz transmapped hair to particles with diffeomorphic. Now it works with 2.8 too.
    http://diffeomorphic.blogspot.com/p/hair.html
    What version of Diffeomorphic does the hair now work in?
    May 2020
    Thank you very much for those examples Padone. 10000% percent import on the morph? Wow, didn't expect that.
    Of course nicstt, every interface is a matter of opinion. If I'd been using Blender longer, I probably wouldn't have minded pre-2.8 that much. Right-click to select was insane though.  ;)
    May 2020
    @nicstt Particles hair should work both in the stable and development version in blender 2.79 and 2.82a. It was fixed gen 9 2020.
    https://bitbucket.org/Diffeomorphic/import-daz/issues/8/hair-to-particles-still-broken-in-28x
  • marblemarble Posts: 7,500
    May 2020
    There's been a suggestion for a dedicated forum for the Diffeomporphic plugin - Thomas seems to agree that it would be a good idea. I think that would help a lot for those of us who would like to find out more but are not at the advanced level of someome like @Padone. I hope it happens.
    May 2020
    Thomas's remark in the forum is funny: "I don’t really understand how this depsgraph thing works,"
    My god, how many times I have said that, verbatim.
  • j cadej cade Posts: 2,310
    May 2020
    Oh God, I remember unsuccessfully trying to learn blender 2.49. and while I definitely like the new changes, 2.8 is definitely closer to the UI of 2.5 than 2.5 was to 2.49
    2.8:
    is still very much in the same univers as 2.5:
    ...and then  theres 2.49 and before...
    who thoght that giant horizontal panel was okay? and this isnt even as cluttered and terrifying as it could get
    looking at whatever this is makes me want to cry a little
    2.8:
    yeh
    it never made sense; i struggled to do anything. 2.5 turned up and it was just easy. Of course, I like shortcuts, but they were there in 2.49, they just were only part of the story.
    I remember trying out milkshape because of how 2.49 irritated me.
    ok, I'll give it a try tomorrow - later today.
    June 2020
    @marble Not a dedicated forum but there's an official discussion at blenderartists that's maintained by Thomas. Then of course the repository that's for bugs but also used for technical help. Here on daz I'm maintaining a little discussion where I update the new features in the first post but I've not much time to help.
    https://bitbucket.org/Diffeomorphic/import-daz/issues?status=new&status=open
    https://blenderartists.org/t/daz-importer/684697/617
    https://www.daz3d.com/forums/discussion/389931/true-iray-skins-for-blender-are-on-the-way/p1
    June 2020
    I was reading some of the comments in the Issues section and happened across this one:
    https://bitbucket.org/Diffeomorphic/import-daz/issues/90/faq-or-forum-for-the-plugin
    Quote:
    Thomas Larsson repo owner
    But I agree that a more structured forum would be very nice. This plug-in was originally meant to be my private tool for importing Daz characters into Blender, but recently I feel that it is starting to grow beyond what I can handle myself.
    June 2020
    I may have missed it, but is there a way of matching camera views between studio and blender - other than the mark one eyeball.
    June 2020
    @nicstt The plugin already imports cameras. This is also recently improved.
    https://bitbucket.org/Diffeomorphic/import-daz/issues/75/better-cameras
    June 2020 edited June 2020
    Ha, thanks; I've not bothered trying.
    Could I just import a camera then; just wanting the same camera angle.
    No matter; after looking at your link, I'll see manually changing the Studio camera to matched Blender's works.
    (I'm setting up scenes in Blender, but atm I'm comparing as much as possible the speed of the two render engines.
    What's surprising is that my Threadripper out performs the 980ti in 2.83; it is comparable in 2.82. In Studio, however, Iray renders in about 2/3 of the time of the CPU.)
    Post edited by nicstt on June 2020
    June 2020
    Hmm, sad to say not working so well, or certainly not as show in the docs.  Blender 2.82 (2.82.7) and dev version of DAZ Importer plugin as of 18 May 2020.
    1918 x 985 - 208K
    That's what I get andya.
    I've been looking at the beta 1.1.2; the new skin shader seems to be much harder to tone it down from a tanned look; I'd customised the previous one, but this is so far resisting my efforts.
    Edit:
    Hmm, I might be able to work with the mix shader with the factor set to 0.750
  • artworks3d_cf6b079083artworks3d_cf6b079083 Posts: 5
    June 2020
    Hello everyone,
    this is probably not the right place for this question so please forgive me, and feel free to point me to where I need to be for this information... I recently upgraded my Mac OS to Catalina (10.15.5) and my Carrara Pro 8.1 no longer works under this new OS. So, I'm debating on finding an alternative software -- whatever is the closest in interface & function to Carrara Pro. That being said, is Blender a good (and close) alternate, or should I consider something else? I've been a long-time Carrara user (even back to RayDream Studio) so I'm looking for the most painless transition possible.
    Again, apologies for asking here... if I need to ask somehere else in the forum, please let me know.
    Thanks!
    Keith
    June 2020
    I'd try asking in Carrara forum or Blender Artists; although I've been using Blender for years, I've never used Carrara.
    It's 3D software, painless it isn't going to be. :)
    I'd still take the trouble to learn the shortcuts if you decide to go to Blender; you definitely don't need them, but like any sortware, it can often speed up processes.
    I would guess that anything you can do in Carrera, Blender can do, and so can any other 3D software. One of Blender's strengths is its numerous and often brilliant add-ons; the vast majority are free, and it's rare to see expensive ones.
    June 2020
    artworks3d_cf6b079083 said:
    Hello everyone,
    Thanks!
    Keith
    can't dig it up now, but there's a 'carrara-izing blender' thread somewhere back in the carrara forums (2 years or so?)  that described how to re-map some of the blender functions to match your carrara habits. I think it's also mirrored/consolidated over at carrara-cafe.com.
    --ms
  • JClaveJClave Posts: 64
    Thanks for sharing your perf comparisons between CPU and GPU.
    I also saw a Cycles benchmark where Threadripper 3970x outperformed 2070. (but slightly slower than 2070 Super) - https://opendata.blender.org/
    This was pre 2.83. So Threadripper 3970x may even beat 2070 Super in 2.83.
    Makes me think that CPU rendering with Threadripper is the ultimate solution for large scenes that exceed VRAM limit.
    (if you are rendering in Blender Cycles, not in Iray)
    Also for those interested, I'm still working on adding Iray Uber Shader integration to a custom Blender build which is planned to be made public by the end of this year.
    Post edited by JClave on June 2020
    Nvidia guy was demonstating his workflow (etc?); he had 4 2080ti and a 3990x (I think), and it was about the same speed as one 2080ti and marginally better on occasions.
    I'm not sold on the graphics card is better scenario- especially as the folks wanting you to buy em are beating that drum.
    I'm not really interested in creating the Iray look; Im going for PBR, and then going for a look im happy with. All things being equal, a scene should look the same regardless of render engine - otherwise it isn't physically based. :)
    ... And yeh, even though it's faster in 2.83, I don't use the CPU unless I have to, but last night I had to as wouldn't fit on the card; (I'd rather wear out the GPU - arguably cheaper to replace as I'd be looking to upgrade to a 3000 series threadripper - oh the financial pain.)
    Now Cycles is supposed to have some version of our of core rendering I believe; I'm wondering if I can have it drop to CPU if required, otherwise just use GPU. I don't think so, as they have to be physically enabled in preferences.
    Oh and using the same scene as previously,
    Both (980ti & Threadripper)
    64 x 64        2:34.25, 2:30.27 - gives a 40% (approx) reduction in render time.
    Oh and I much prefer the Intel denoiser, performs way better (appearance-wise) than either Blender's default or the Iray one we have. The RTX one is supposed to be great, but that forces me to buy Nvidia, whereas the Intel denoiser (handled in post via compositin) is available for anyone.
  • starkadhstarkadh Posts: 52
    June 2020
    I have a question more... but it's more a curiosity.
    I am using the diffeomorphic tool now. It is satisfying, but there is a thing that I want to know just to completeness: is there a way to import the limits for the bones (or rigs)? You know... just to not having the character who bend his limbs as if they were broken.
    As I said, I can perfectly survive without knowing it... I am pretty good at posing, but... you know: just to knowing it
«1…45678910»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
