GenX2 and Genesis 2 AddOn released! [Commercial]
1181921232442
  • Knight22179Knight22179 Posts: 1,195
    dan.shive said:
    One fantastic side effect of this is the G2 Jaw morphs that get added to Genesis with this. They on their own allow for far wider open mouths than normal, and when combined with GenX transfered Aiko 4 mouth morphs, you can get some pretty cartoonish results.
    Awesome. :)
  • TimbalesTimbales Posts: 2,425
    Too bad GenX2 doesn't allow me to use BF2 textures on Genesis. :(
    what is BF2?
  • fixmypcmikefixmypcmike Posts: 19,701
    what is BF2?
    Knight22179 would rather refer to G2F as "Basic Female 2" than refer to it as Genesis.
    To answer the question, though, Map Transfer can do that.
    what is BF2?
    Hmm, I have Daz Studio 4.6 Pro but I have no Map Transfer function in the Edit tab. :down:
  • greysgreys Posts: 335
    what is BF2?
    It's in the flyout menu on the surfaces tab.
  • Mari-AnneMari-Anne Posts: 363
    what is BF2?
    It's under the Surfaces tab
    No wonder I couldn't find it when following a tutorial! He must have had an earlier version of D/S than I do :red:
    Thanks for the help. :D
  • KharmaKharma Posts: 3,214
    Simply scaling the eyes a little bit more down in the parameters tab should make them fit. Maybe also moving them a bit outwards. GenX transfers morphs, and for scaling, it is always a bit luck if the rigging is similar enough that using the same values will work.
    It is most common that the eye fix is included directly in the morph injection pose. You may want to uncheck to transfer "Morphs" in the Presets tab when translating an eye fix pose. Otherwise, the preset will also set morphs if they were transferred individually.
    Also, you may want to use the morphs under Eyes / Generation X / ** Fix ** to move the iris a bit forward and the pupil a bit backward to get the eyes correct. From the way the eyes are modelled in Genesis 2, it's not unlikely to get this kind of poke-through for iris or pupil with transferred morphs, that's why I included these fix morphs.
    Still not working, I have tried other Thorne characters and they too have the bulging eyes, with the previous version of GenX I successfully tranferred a thorne character, including the eyefix. I have tried with GF2 and Genesis. Has anyone else tried tranfering a thorne character successfully?
  • whispers65whispers65 Posts: 1,034
    whispers65: The mail address was correct and the mail wasn't returned. Have you checked your spam folder, short mails with attachments have a good chance to go there. Anyway, I just sent you the fix again, and a second mail without attachment to see if you at least get that one.
    I am sorry for the trouble. I have no idea why I am not getting it. As far as I know I haven't had any problems with emails. I get about 50 a day. My phone let's me know of new messages and I check both regular folder as well as spam folder. I have been doing tech support with Smith Micro and all of that comes in spam folder as well as Daz Ads so I am really aware of looking all over the place. I just can't tell you why I didn't get it. This is strange to me. I haven't had this happen before.
    I'll PM you with 2 alternate emails if you want to try one more time. I just hate that this is taking up your time. I value people's time greatly.
  • JuliKJuliK Posts: 0
    @Dimension3D, Thank you for answer and sorry my late reply!
    Busy day today.
  • CybersoxCybersox Posts: 9,315
    Fun with some oldies from the back of my digital closet - Valentin 3d's Kimiko V4 looks great transferred to G2F, but I was totally blown away by how well Grotto's amazing Insectoid for M4 converted to G2M.
    1214 x 1716 - 1001K
  • MBuschMBusch Posts: 547
    Oh, this is funny and wonderful! Nice render.
    Impressive!
    edited March 2014
    ok, just to make sure I get this right...if I want to transfer A3 morphs to Genesis (NOT genesis 2) I will also need this add on:
    http://www.daz3d.com/top-sellers/genx-addon-gen3-for-a3-and-h3
    Correct?
    I'm about to get the upgrade from the original program to the upgraded program....I will NEED to get the upgrade to use the A3 addon, is that correct? I can't use the A3 addon with the ORIGINAL version?
    edit: or is the upgrade to the original version only if you want to transfer morphs to GENESIS 2??
    Post edited by jakiblue on
    Correct?
    When you buy the A3/H3 addon you get both the GenX1 and GenX2 versions. The GenX2 version has improved algorithms -- it isn't just for Genesis 2. But the A3/H3 addon can be used with the original version if you do not get the new version.
    Correct?
    Thanks Mike! :D
    Having an issue with the transferred icons getting cut off. They're not being resized to fit 91x91like in the old version they're being cropped instead, which... makes it pretty hard to see what's going on, especially for expressions. This is i13's Animal Instinct expression pack. As you can see the resulting crop.... isn't very informative.
    500 x 300 - 73K
  • kyoto kidkyoto kid Posts: 41,957
    ...wow that looks great. I wonder how Dariofish's Alien morphs for Genesis would work with G2F/G2M.
  • Dimension3DDimension3D Posts: 464
    Kharma: I tried Mulberry myself to be sure. When transferring morphs as "Create single morph", it is highly recommended to set "Show in list" to "all controlled morphs" to prevent some morphs missing in transfer because they are not listed. In this particular case, the eyes have the realistic morph set, but because it is controlled by the body and head morph usually, it is not listed otherwise.
    Without these morphs, I get the same result as you. With these morphs included, it's much better (left image), but still requires a bit of adjustments (right image). First, I set "move pupils back" to 0.5 to get rid of the black circle in the eyes. Second, I scaled the eyes to 95% and set zTranlate to -0.1 and xTranslate to 0.7 (right eye) / -0.7 (left eye).
    whispers65: I sent the fix to both mail addresses. I hope its working this time.
    temporal.ranger: I'm pretty sure that this was the same in GenX1, but I'll change it to resize images if they are not in 91x91 format.
    600 x 424 - 44K
    @D3D: thank you so much for testing Mulberry, as soon as I can I will try your settings . I was getting close to what you did on the left, but was still missing something in my settings. Looks awesome! I knew it would be possible ... fantastic program!
    Sorry I can't find this, can you tell me where I should set this?
  • Cayman StudiosCayman Studios Posts: 1,138
    Once the morphs have been loaded, right-click in the transfer window and you will get a menu with the "Show in list" options.
    Thank you cayman, I found it now didn't know you could right click...I feel like such a dummy getting this morph transferred, altho others I did of thorne's did have the eye fix inj also.
    I'm not sure what the benefit would be, as Genesis is more versatile for alien-type stuff than the G2s. I'd try it just to see, but weirdly I can't seem to find the folder with the HFS morph poses. I moved all my runtimes a while back and apparently I put the Hellfish folder in some bizarre place where they're working as sliders but I can't see the stand-alone morphs... Very strange...
    That said, the Insectoid's more complex than any of the HFS shapes, so I'd think the transfer should work just as well if not better. Thus far the only real problems I've come across have been in applying Gen2 poses on some of the converted figures, as the hands tend to go a little wonky. Resetting with Slosh's Handy Dandy has fixed everything so far though.
  • LyoneLyone Posts: 139
    Hi Dimension 3D,
    I'm sure I missed something on transfering expressions from V4 to Genesis 2 Male/Female with GenX2 Preset. I tried to transfer some expressions from V4 to Genesis and they are working very well but didn't succeed on transfering V4 morphs to Genesis2 male/female. I see that the V4 expressions are transfered but when I click on them nothing is happening on the Genesis2 figure. I tried with both Genesis 2 Male and Female and none of them seems to work. I'm sure I missed something.
    By the way, thank you so much for your fantastic GenX2. I'm very very happy with it.
    Best regards.
    I didn´t know that we could transfer expressions too! Cool! :)
    I have a quick little question ... Apparently I have not installed the old genx in this computer. I installed daz studio to my new computer and forgot to install the old genx .. lol so it's like I never had the plugin. Probably a dumb question but I'll ask anyway. No need to delete anything and I can now install the new genx2, right? :) But I'll need to put the serial again, correct?
    The thread is long, so I'm sorry if I missed this.
    I bought the new GenX plus the X2 update, installed via DIM on this laptop, and activated using the code from my account. Now when I create a Gen X tab there is no Source button (like the one in the manual pictures) for choosing to transfer to G2. What's going on?
    Install just the GenX2 and GenX2add-ons. The GenX files are just for people that don't want to upgrade the product.
    Do I need to uninstall the Gen X files I already had, then?
    Yes! Uninstall GenX and GenX add-ons.
