Adding to Cart…
...so where are the hay stacks?
It's interesting to see how these turn out in IRay, been converting some of those old props to aweSurface not long ago. Often they don't have proper height maps, only the diffuse plopped into the bump channel. Makes it a real challenge to get a descent result. I can imagine it's even harder with IRay, with the lack of micro displacement?
https://www.daz3d.com/forums/uploads/FileUpload/c4/47057f288cb08aa6013aae3dd3f5ce.png
If there isn't a bump or displacement map I just try the diffuse map and see how it works, usually it turns out not too terrible
@Sven DullahLike this you mean?
Bring Home The Hay
2020-04-24 22:09:27.638 Total Rendering Time: 1 minutes 32.90 seconds
Click on image for full size.
728
Sweet, I feel better already
Another Iray conversion
Steam Carriage.
2020-04-22 10:23:02.917 Total Rendering Time: 16.65 seconds
2020-04-22 19:07:32.734 Total Rendering Time: 18.18 seconds
759
A few more old ones Iray updated.
Steam Bike Pro
2020-04-23 20:11:10.445 Total Rendering Time: 19.64 seconds
2020-04-23 20:17:36.853 Total Rendering Time: 17.20 seconds
782
The Knights Tower
885
Not something I do much of is Animation, this is the latest effort. Done in Iray and edited in Vegas Pro 16.
(Best viewed in HD)
936
I have done a bit more to Warg and this is iteration two. The render of the Lycan didn't want to play well with the Warg render and, because it is separate from the grass in the Warg render when put together in Vegas he looks as if he is running on top of it
Back to the grind.
Warg 2
968
Maisie for Victoria 8 and the Orangery with the interior. Just to be aware when the Interior is added the lights are all on by default.
2020-06-06 14:26:08.016 Total Rendering Time: 7 hours 2 minutes 44.75 seconds
2020-06-06 22:57:32.137 Total Rendering Time: 35 minutes 31.16 seconds
057
Anyone tried the new Matte Fog function, bottom of the Environment pane?
I fired up an old render and tried it out. The one thing I can't figure out is how to move it back and forward. As you can see the top of the two sails at the front are sticking out of it.
Out of the Mist
2020-06-11 21:48:16.679 Total Rendering Time: 4 minutes 33.36 seconds
I tried a few different settings but all they did was change the Opacity or Brightness.
Click on image for full size..
074
Genesis 3 Female, Bethany skin and Radiant Jaguar Hair, dForced Boho Dress, all with Iray tweaks :)
2020-06-15 13:54:28.615 Total Rendering Time: 16 minutes 43.83 seconds
Really?
Trying out some odds and ends from my Runtime.
Willow Creek and Mouse with Catalyzer Fur
Now, what did I come up here for?
2020-06-13 13:21:52.097 Total Rendering Time: 23 minutes 10.91 seconds
926
A quick one trying out HD Volumetric Clouds with Terradome 3 and CS Dimetrodon. Lighting is Sun and Sky Only.
Everything has been tweaked in Iray as I just can't leave things as they are :)
Catching the Rays
2020-06-19 01:53:21.408 Total Rendering Time: 3 hours 21 minutes 18.40 seconds
135
Just carrying on with some quick setups using things from my Runtime.
This is Planet Teros, for the rocks, Rigged water Iray 2 for the stream, water volume 03, and the small waterfall, pour 03, and Panthers. The lighting and background is an HDRI.
Stop for a Drink
2020-06-19 18:58:35.526 Total Rendering Time: 20 minutes 16.92 seconds
140
This started off redoing the shaders on The Old Railway and the Thumper to change them to Iray and it grew into something else.
The Old Railway and Thumper.
2020-06-19 22:29:06.925 Total Rendering Time: 3 minutes 41.20 seconds
Zombie Train Crash
2020-06-20 21:56:45.417 Total Rendering Time: 2 minutes 17.67 seconds
148
Another SandIrayed render. Everything that wasn't Iray when loaded is now
Used The Dead Forest for the Environment with the Matte Fog function.
Who's Stalking Who?
2020-06-21 10:10:22.094 Total Rendering Time: 2 minutes 14.57 seconds
160
v#
Very nice it is too.
Snow Leopard Catalyzer
2020-06-24 10:28:54.144 Total Rendering Time: 4 minutes 59.13 seconds
203
I got the lions at the same time as the Snow Leopard.
Leo the Lion and Friend.
2020-06-24 18:37:55.592 Total Rendering Time: 32 minutes 9.41 seconds
Dforce hair on left, Catalyzer hair on right.
215
Messing about with the surface settings in Iray for Breaking Waves.
Breaking Waves.
2020-06-23 16:52:03.859 Total Rendering Time: 4 hours 31 minutes 33.90 seconds
Stopped at 93% done.
224
This is Mace for Genesis 3 or it was until I got tampering with his surfaces
Mace Original
2020-06-29 08:57:34.700 Total Rendering Time: 19.20 seconds
Mace with my changes.
2020-06-29 09:48:26.145 Total Rendering Time: 24.14 seconds
I lost the render settings after that one but here are some new ones
2020-06-29 16:44:29.121 Total Rendering Time: 47.20 seconds
2020-06-29 17:15:51.326 Total Rendering Time: 44.7 seconds
242
I found this hair in my Runtime and Sandirayed it. It looks really good. It come up as Antonia Flo Hair and loads as flo-app but it isn't in the store. I did this short Animation to show it.
https://www.ftscotland.co.uk/gallery/piwigo/galleries/Videos/DAZ 3D Animations/flo-hair-001.mp4
261
Moving on I have rendered everything at the same time instead of compositing each figure so the Lycan is no longer running on the grass. I also changed it to night.
Warg
311
Very cool! Can't imagine the amount of work that went into that!!!
I think roughly a week of rendering as it was done with three different camera angles although I only used two in the end :)
Dinner Time
2020-07-06 20:06:45.998 Total Rendering Time: 57 minutes 27.75 seconds
CPU Only
355
Fun at the Fair
2020-07-15 20:52:08.181 Total Rendering Time: 30 minutes 12.84 seconds
398
Playing around with the Old Station and old Railway Line I noticed something that should have been picked up before publishing. It looks to me like a UK station and line and yet the signals and signs are on the wrong sides :) Standing on the platform with your left side towards the line and looking along it then the train will be coming towards you which means the signalling and signs for that train should be on the same side facing it so the driver can see it. If it is in fact a US of A station then they are obviously correct. :) I'll have to go and change all the signs and signals and re-render the images :)
2020-07-22 09:15:45.168 Total Rendering Time: 1 hours 32 minutes 52.18 seconds
407
Yeti in the snow.
408
Through the Tunnel
2020-07-22 19:38:42.575 Total Rendering Time: 1 hours 5 minutes 38.66 seconds
CPU
Before adding DOF
2020-07-22 18:29:29.854 Total Rendering Time: 1 hours 21 minutes 57.84 seconds
CPU
With DOF
415
