My WIPS, renders and animations :)
1202123252628
    edited April 2020
    ...so where are the hay stacks? devil
    It's interesting to see how these turn out in IRay, been converting some of those old props to aweSurface not long ago. Often they don't have proper height maps, only the diffuse plopped into the bump channel. Makes it a real challenge to get a descent result. I can imagine it's even harder with IRay, with the lack of micro displacement?
    https://www.daz3d.com/forums/uploads/FileUpload/c4/47057f288cb08aa6013aae3dd3f5ce.png
    Post edited by Sven Dullah on
  • FishtalesFishtales Posts: 6,223
    If there isn't a bump or displacement map I just try the diffuse map and see how it works, usually it turns out not too terrible laugh
    edited April 2020
    @Sven DullahLike this you mean?
    Bring Home The Hay
    2020-04-24 22:09:27.638 Total Rendering Time: 1 minutes 32.90 seconds
    Click on image for full size.
    728
    1920 x 1080 - 2M
    Post edited by Fishtales on
    Sweet, I feel better alreadyyes...laugh
    edited May 2020
    Another Iray conversion
    Steam Carriage.
    2020-04-22 10:23:02.917 Total Rendering Time: 16.65 seconds
    2020-04-22 19:07:32.734 Total Rendering Time: 18.18 seconds
    759
    1920 x 1080 - 1M
    1000 x 1500 - 865K
    edited May 2020
    A few more old ones Iray updated.
    Steam Bike Pro
    2020-04-23 20:11:10.445 Total Rendering Time: 19.64 seconds
    2020-04-23 20:17:36.853 Total Rendering Time: 17.20 seconds
    782
    1920 x 1080 - 1M
    1000 x 1500 - 892K
    The Knights Tower
    885
    edited May 2020
    Not something I do much of is Animation, this is the latest effort. Done in Iray and edited in Vegas Pro 16.
    (Best viewed in HD)
    936
    I have done a bit more to Warg and this is iteration two. The render of the Lycan didn't want to play well with the Warg render and, because it is separate from the grass in the Warg render when put together in Vegas he looks as if he is running on top of it laugh Back to the grind.
    Warg 2
    968
    edited June 2020
    Maisie for Victoria 8 and the Orangery with the interior. Just to be aware when the Interior is added the lights are all on by default.
    2020-06-06 14:26:08.016 Total Rendering Time: 7 hours 2 minutes 44.75 seconds
    2020-06-06 22:57:32.137 Total Rendering Time: 35 minutes 31.16 seconds
    057
    1000 x 1500 - 974K
    1920 x 1080 - 2M
    Anyone tried the new Matte Fog function, bottom of the Environment pane?
    I fired up an old render and tried it out. The one thing I can't figure out is how to move it back and forward. As you can see the top of the two sails at the front are sticking out of it.
    Out of the Mist
    2020-06-11 21:48:16.679 Total Rendering Time: 4 minutes 33.36 seconds
    I tried a few different settings but all they did was change the Opacity or Brightness.
    Click on image for full size..
    074
    edited June 2020
    Genesis 3 Female, Bethany skin and Radiant Jaguar Hair, dForced Boho Dress, all with Iray tweaks :)
    2020-06-15 13:54:28.615 Total Rendering Time: 16 minutes 43.83 seconds
    Really?
    1000 x 1500 - 505K
    edited June 2020
    Trying out some odds and ends from my Runtime.
    Willow Creek and Mouse with Catalyzer Fur
    Now, what did I come up here for?
    2020-06-13 13:21:52.097 Total Rendering Time: 23 minutes 10.91 seconds
    926
    1920 x 1080 - 2M
    edited June 2020
    A quick one trying out HD Volumetric Clouds with Terradome 3 and CS Dimetrodon. Lighting is Sun and Sky Only.
    Everything has been tweaked in Iray as I just can't leave things as they are :)
    Catching the Rays
    2020-06-19 01:53:21.408 Total Rendering Time: 3 hours 21 minutes 18.40 seconds
    135
    1920 x 1080 - 1M
    edited June 2020
    Just carrying on with some quick setups using things from my Runtime.
    This is Planet Teros, for the rocks, Rigged water Iray 2 for the stream, water volume 03, and the small waterfall, pour 03, and Panthers. The lighting and background is an HDRI.
    Stop for a Drink
    2020-06-19 18:58:35.526 Total Rendering Time: 20 minutes 16.92 seconds
    140
    1920 x 1080 - 1M
    edited June 2020
    This started off redoing the shaders on The Old Railway and the Thumper to change them to Iray and it grew into something else.
    The Old Railway and Thumper.
    2020-06-19 22:29:06.925 Total Rendering Time: 3 minutes 41.20 seconds
    Zombie Train Crash
    2020-06-20 21:56:45.417 Total Rendering Time: 2 minutes 17.67 seconds
    148
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    edited June 2020
    Another SandIrayed render. Everything that wasn't Iray when loaded is now smiley Used The Dead Forest for the Environment with the Matte Fog function.
    Who's Stalking Who?
    2020-06-21 10:10:22.094 Total Rendering Time: 2 minutes 14.57 seconds
    160
    1920 x 1080 - 939K
    v#
    Very nice it is too.
    Snow Leopard Catalyzer
    2020-06-24 10:28:54.144 Total Rendering Time: 4 minutes 59.13 seconds
    203
    edited June 2020
    I got the lions at the same time as the Snow Leopard.
    Leo the Lion and Friend.
    2020-06-24 18:37:55.592 Total Rendering Time: 32 minutes 9.41 seconds
    Dforce hair on left, Catalyzer hair on right.
    215
    1920 x 1080 - 770K
    edited June 2020
    Messing about with the surface settings in Iray for Breaking Waves.
    Breaking Waves.
    2020-06-23 16:52:03.859 Total Rendering Time: 4 hours 31 minutes 33.90 seconds
    Stopped at 93% done.
    224
    1920 x 1080 - 855K
    edited June 2020
    This is Mace for Genesis 3 or it was until I got tampering with his surfaces smiley
    Mace Original
    2020-06-29 08:57:34.700 Total Rendering Time: 19.20 seconds
    Mace with my changes.
    2020-06-29 09:48:26.145 Total Rendering Time: 24.14 seconds
    I lost the render settings after that one but here are some new ones smiley
    2020-06-29 16:44:29.121 Total Rendering Time: 47.20 seconds
    2020-06-29 17:15:51.326 Total Rendering Time: 44.7 seconds
    242
    1000 x 1500 - 568K
    1000 x 1500 - 547K
    1000 x 1500 - 662K
    1000 x 1500 - 671K
    edited July 2020
    I found this hair in my Runtime and Sandirayed it. It looks really good. It come up as Antonia Flo Hair and loads as flo-app but it isn't in the store. I did this short Animation to show it.
    https://www.ftscotland.co.uk/gallery/piwigo/galleries/Videos/DAZ 3D Animations/flo-hair-001.mp4
    261
    Moving on I have rendered everything at the same time instead of compositing each figure so the Lycan is no longer running on the grass. I also changed it to night.
    Warg
    311
  • firewardenfirewarden Posts: 1,488
    Warg
    311
    Very cool! Can't imagine the amount of work that went into that!!!
    I think roughly a week of rendering as it was done with three different camera angles although I only used two in the end :)
    edited July 2020
    Dinner Time
    2020-07-06 20:06:45.998 Total Rendering Time: 57 minutes 27.75 seconds
    CPU Only
    355
    1920 x 1080 - 2M
    edited July 2020
    Fun at the Fair
    2020-07-15 20:52:08.181 Total Rendering Time: 30 minutes 12.84 seconds
    398
    edited July 2020
    Playing around with the Old Station and old Railway Line I noticed something that should have been picked up before publishing. It looks to me like a UK station and line and yet the signals and signs are on the wrong sides :) Standing on the platform with your left side towards the line and looking along it then the train will be coming towards you which means the signalling and signs for that train should be on the same side facing it so the driver can see it. If it is in fact a US of A station then they are obviously correct. :) I'll have to go and change all the signs and signals and re-render the images :)
    2020-07-22 09:15:45.168 Total Rendering Time: 1 hours 32 minutes 52.18 seconds
    407
    1920 x 1080 - 1M
    edited July 2020
    Yeti in the snow.
    408
    1920 x 1080 - 2M
    edited July 2020
    Through the Tunnel
    2020-07-22 19:38:42.575 Total Rendering Time: 1 hours 5 minutes 38.66 seconds
    CPU
    Before adding DOF
    2020-07-22 18:29:29.854 Total Rendering Time: 1 hours 21 minutes 57.84 seconds
    CPU
    With DOF
    415
    1920 x 1080 - 2M
    1920 x 1080 - 1010K
