Show Us Your Bryce Renders Part 11
1…2425272930…100
  • HoroHoro Posts: 11,724
    edited April 2020
    Two Icosahedrons and two smaller ones inside made in Wings3D lit by the "Specular to TA Light" method (PDF on my website: 3D CG Documents > Mine > Light). The outer objects are partly transparent and reflecting. The inner ones have PHT boosted specular with max. halo to brighten the inside of the outside object. Backdrop and specular light source by an HDRI, rendered with TA and boost light. No diffuse.
    Icosahedrons
    1200 x 750 - 187K
    Post edited by Horo on
  • HansmarHansmar Posts: 3,229
    Horo: Thanks and double thanks, because it is largely thanks to you and David that these works have this wonderful mood. The Dinos are nice to use in this kind of scene indeed.
    Adbc, Tim82, mermaid010, Rieke77: Thanks and, as you probably know, the heavy lifting was largely done by the great landscapes and sies by Horo and David Brinnen.
    Rieke77: Wonderful abstract! Many detailed repetitions and great colours.
    Horo: Fantastic colourful work. Your special light methods are certainly worth a try.
  • adbcadbc Posts: 3,115
    edited April 2020
    Rieke77 : Awesome flowers abstract.
    Horo : Superb light and colours effect.
    Another abstract made with primitives.
    940 x 450 - 110K
    Post edited by Chohole on
  • Rieke77Rieke77 Posts: 619
    @ Horo - wow, this looks great. I like the light and colours.
    @ Hansmar - thank you so much.
    @ adbc - thanks a lot. Your image, with the primitives,  gives me new ideas.
    Hansmar - thank you.
    adbc - thank you. Now this is a cool abstract. It has a bit of a deep space feel.
    Rieke77 - thank you.
    Rieke77, Horo : thank you.
  • Tim82Tim82 Posts: 859
    i have not shared one of these for a while :)
    1754 x 875 - 859K
  • mermaid010mermaid010 Posts: 6,292
    edited April 2020
    Horo -  great render, love the lighting and colours.
    Adbc - beautiful abstract .. similar ideas yet not the same
    Tim - very nice landscape, nice atmosphere
    An abstract using torii and the Filigree Hdri
    700 x 700 - 338K
    Post edited by mermaid010 on
    @ Tim82 - great landscape and atmosphere
    @ mermaid010 - beautiful abstract render
    Tim - great scene.
    mermaid - thank you. Great abstract, a bit like a windmill and the sky fits as well.
    Tim82 : beautiful scene.
    mermaid : thank you. Awesome abstract, great sky and colours.
    edited April 2020
    The tree lights the ravine, another example of the Specular to TA Light method. Unfortunately, even though neither HDRI nor the sun have shadows (no HDRI Effect and Diffuse only Specularity) the render time cannot be considered swift, just short of 1 1/2 days - and I have another one cooking and heating my home.
    Living Light
    1200 x 885 - 341K
    @ Horo - this looks awesome!
    Horo : cool idea, superb image.
    edited April 2020
    Rieke77 and adbc - thank you.
    Another example of the Specular to TA Light method. Unfortunately, even though neither HDRI nor the sun have shadows (no HDRI Effect and Diffuse only Specularity) the render time was again just short of 1 1/2 days. Even though rendered with 256 rays per pixel, a bit of noise remained which I had to smooth in post with a Gaussian filter with a radius of 0.3 pixel.
    Bare Trees
    1200 x 840 - 409K
    Thanks Rieke, Horo and Adbc
    Horo - beautiful examples of the Specular to TA Light method, the Bare Trees is absolutely superb.
    edited April 2020
    The camera is with the GWL (gigantic wide-angle fisheye lens) inside an Alien-Artifact by MatCreator. IBL light from inside and reflections from outside. Big disappointment: I rendered over the network, Lighting showed render time and anti-aliasing time for each tile on each machine (aa-ing 8 times longer than rendering). The resulting image was not anti-aliased. I had to re-render it with the same setting without Lightning and after 9 hours, the result was fine.
    Plumes
    1200 x 1200 - 601K
    Horo : Specular to TA light method gives a spectacular light effect on those trees, beautiful.
    The render with the GWL has superb colours, very cool idea.
    @ Horo - the trees, with the Specular to TA light method, looks awesome.
    The GWL image has great colours.
    Beautiful abstract with the GWL Horo
    all of the new renders are awesome, supurb work!!! :)
    Thank you adbc, Rieke77, mermaid and Tim.
    edited April 2020
    A simple Sunset render, the eagle is a freebie
    800 x 600 - 196K
    looks fantastic :) ....great job!!!
    mermaid - beautiful result of this "simple" scene. Lighting is excellent, the eagle looks well lit, the mountains are very dark but there are a few hints of light and specular that give them the 3D look.
    mermaid : awesome scene, very attractive lighting.
    @ mermaid010 - wonderful sunset - wonderful render.
    Thanks Tim, Horo, Adbc and Rieke for your nice comments
    edited April 2020
    Three terrains, 5 instanced Autumn Apple 1 BTOs and 6 instanced alpine roses (made from 2 Bryce trees), the fields on the ground plane from the Vegetation set. Sky colour and ambient light by the Field2a_CSD (clear sky dome) HDRI, Bryce clouds and the Sun behind the trees.
    Fertile Vale
    1200 x 795 - 387K
    Wow absolutely beautiful work Horo
