Report sales errors here: "There's Always Another Sale™"
1…6791112…100
  • chromchrom Posts: 261
    "Because you own all the Victoria Base Characters,"  purple Banana option doesn't work.
  • Richard HaseltineRichard Haseltine Posts: 111,688
    SaulCs said:
    I am seeing the discounts applied because when i do two items without the banana, I get a slightly higher price than a new plus the banana.
     BUT the extra 10% key discount is supposed to apply when you already own the Banana Suit without having to add to the cart. Yeh, I know it's free but not everybody will realize that you have to add it again when you already own it.
    Right, I just don't own it yet.
    Yes, if you already own the banana suit the discount is not being applied.
    Are you sure? I see 55%(ish) off in cart for Newly Mad items, which is the 50% for two+ and the 10% for key items.
  • SaulCsSaulCs Posts: 67
    Yes, just tested it again. The 10% for key items is not being applied in the cart for the Artists Store Items, it works for the newly mad items and still mad. After you buy the already owned banana suit the discount is applied for the artists store items, the problem is that with the banana in the card the discount coupons/codes will not work.
  • felisfelis Posts: 6,550
    And it doesn't work for Bonus Madness: 10.48 * 0.3 * 0.9 = 2.83, but list as 3.15 in cart
  • ByrdieByrdie Posts: 1,783
    For those who got the purple banner because we own all the Vickies, does anybody know just which select Daz Originals it applies to? I know New Releases, PC+ Items, Gift Cards and Memberships are excluded but is there a category section to pick from or what? indecision
  • Charlie JudgeCharlie Judge Posts: 13,641
    There is a 'SHOP NOW' button in the message. That brings up the items
    blush Thanks. I am a dunderhead today it seems.
  • LeanaLeana Posts: 13,560
    The link I have in the offer is this one: https://www.daz3d.com/daz-originals#filter_new=0&filtered=1
    So all DO except new and PC+ items
    but does the purple banner work for you?
    I had no success
  • TorquinoxTorquinox Posts: 4,941
    It worked yesterday. Sorry, that's no help for you today.
  • memcneil70memcneil70 Posts: 6,137
    I just tried it, but no good.
  • MelanieLMelanieL Posts: 7,878
    I'm still not seeing the extra 10% off - two New items are going to 50%, but I bought the Banana Suit yesterday.
    I had no success
    DAZ changed it to single use only. So, if you already used it yesterday it doesn't work today
  • Matt_CastleMatt_Castle Posts: 3,284
    Buy it again. It's free.
    ah yes, but if you add it to the cart to get the discount the coupons will not work
    I'd like to reiterate this.
    Having to have a free item in the cart to make a discount work is a pain when it comes to coupons (and it *is* the start of the month, so everyone has fresh coupons) and is just going to create a glut of requests to CS.
  • missuskissesmissuskisses Posts: 918
    edited April 2020
    I am only getting 50% off newly mad and still mad items with two such items in the cart, despite having "purchased" the banana yesterday. Yes, re-adding the banana will change it to 55% off, but then I can't use my PC coupon three times because the banana eats the majority of the discount...
    In other words, still not working for me, and would appreciate a fix. Thank you!
    Post edited by missuskisses on
  • jd641jd641 Posts: 463
    edited April 2020
    Is the Platinum Perks coupon code repeatable? If it isn't, I need to be reaaaaaaaally selective of what I want.
    Post edited by jd641 on
  • DripDrip Posts: 1,269
    Despite the release of the new dForce Elf Guardian Outfit, WildDesigns is not part of the featured artists?
    edited April 2020
    Exactly that. Non PC members can use the DAZ originals coupon this week and PC members can use it three times, so lots of coupons.
    Said that the 10% key item discount seems to be working now.
    Post edited by SaulCs on
  • L'AdairL'Adair Posts: 9,479
    @missuskisses, the 10% Key discount should be working now. It wasn't working for me earlier, too, but it is working now.
    I haven't tried since the April extension; but during the original March period I was able to use it multipl;e times.
    Dunno if anybody mentioned it but the free item you can choose today for buying a Newly Mad item is futzing up the purple banner discount. For example, the Dragon 3 shows at $0.00 if I put it in my cart with the required products -- Daz Banana Suit and Zophael for G8 Male -- but my discounted Daz Originals then jump from $2.57 each to around $7.00 each. sad
    Free products like that always seem to throw the cart into a tizzy fit.
    I suspect you have two options: split it into two purchases, or buy the cart and ask for a refund.
    If you're willing to go the second route, I recommend leaving the creature freebie out of the cart while you select everything else. Then screencap your cart. Add the creature freebie. Screencap the cart again. Checkout, and file a ticket and attach both screencaps, asking for a refund of the difference.
  • Cris PalominoCris Palomino Posts: 13,010
    I had no success
    Please put in a ticket.
  • SevrinSevrin Posts: 6,314
    The Newly Mad items are listed together with the Still Mad items and under the Still Mad heading.
  • IppotamusIppotamus Posts: 1,580
    Because you own all the Victoria Base Characters, we're offering you $20 OFF* Select Daz Originals when you buy the Banana Suit for Genesis 8 and any Newly Mad Item
    Shop Now
    *Items must be in cart simultaneously for discount to apply.
    Usable once per customer.
    Discount excludes New Releases, PC+ Items, Gift Cards and Memberships.
    Offer valid only for intended recipients.
    Offer is only for a limited time
    There are no longer any Newly Mad items to trigger this purple banner offer as they have all been moved to Still Mad.
    edited April 2020
    Shop Now
    The page has an issue, but the Newly Mad items are the first thirteen items listed, (which includes the two Bonus Madness products further down the page.)
    Post edited by L'Adair on
  • KinichKinich Posts: 941
    Shop Now
    Already used the $20 offer so can't check but I suspect today's releases will trigger the offer as they did trigger the Gift Card Discount.
    By the way it is possible to get up to 35% off the Gift Cards, $200 plus gift card =20% off, add a Newly Mad Item +10% (including Bonus Madness items, it is cheaper to add both if you have the bonus discounts applied), +10% for being a PC+ Member (not Honorary),
  • jjmainorjjmainor Posts: 500
    Instead of 2 bonus items, you could use one and add the free banana.
    @Ippotamus and
    @Sevrin
    I just refreshed the March Madness page and the Newly Mad are now being listed correctly.
    Thanks, Daz. smiley
    The Related Madness items are all also in the Still Mad section, which has an identical discount anyway, so Related Madness seems to be a bit redundant? Or are the discounts from the two sections supposed to add up, which they currently don't?
