Manually Clear GPU?
2»
  • bishboschbishbosch Posts: 54
    RTX 2070, latest Studio Driver release (442.19)-- a barroom scene with a couple large texture maps, the largest related to Auto Face Enhancer HD skin (which looks wonderful). I did what I could with Scene Optimizer and Decimator.
    I'm still having luck with mclaugh's unlikely trick-- the freezing has stopped-- and I'll start using ManFriday's Render Queue hopefully soon. I'm still very new to 3D animation so I'm sure there's something I'm missing.
    2020-03-26 22:24:50.317 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Importing lights for motion time 0
    2020-03-26 22:24:51.519 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Initializing light hierarchy.
    2020-03-26 22:24:54.831 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Light hierarchy initialization took 3.312s
    2020-03-26 22:25:31.865 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: Unable to allocate 31976004 bytes from 159996312 bytes of available device memory
    2020-03-26 22:26:44.759 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.7   IRAY   rend error: CUDA device 0 (GeForce RTX 2070): Scene setup failed
    2020-03-26 22:26:45.125 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.7   IRAY   rend error: CUDA device 0 (GeForce RTX 2070): Device failed while rendering
    2020-03-26 22:26:45.735 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.7   IRAY   rend warn : All available GPUs failed.
    2020-03-26 22:26:49.929 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.7   IRAY   rend warn : No devices activated. Enabling CPU fallback.
    2020-03-26 22:26:50.089 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.7   IRAY   rend error: All workers failed: aborting render
    2020-03-26 22:27:14.009 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Lights memory consumption: 11.2874 MiB (device 0)
    2020-03-26 22:27:16.526 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Material measurement memory consumption: 0 B (GPU)
    2020-03-26 22:27:16.526 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : PTX code (515 KiB) for SM 7.5 generated in 7.46s
    2020-03-26 22:27:16.540 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Materials memory consumption: 3.09475 MiB (GPU)
    2020-03-26 22:27:40.843 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Texture memory consumption: 1.08817 GiB for 424 bitmaps (device 0)
    Sorry to turn this into a Techical Help thread, but like I said the posts in this thread seemed relevant to my problem.
  • kenshaw011267kenshaw011267 Posts: 3,805
    First are you rendering multiple scenes without closing the old render previews? That keeps those renders in VRAM.
    Second even if you close renders there is a memory leak that impacts running multiple renders during the same session. I recommend shutting down DS and restarting ever few renders.
    Other than that the log says you ran out of VRAM. Why it isn't rendering on CPU could be a RAM issue. If you're using the beta it there is a setting that prevents CPU fallback.
    If not you may not have enough free RAM.
