Adding to Cart…
I forget why right now, but I needed to have the files installed in order to create the runtime support files.
I could possibly do this, but then nothing better be put in that folder that shouldn't be there. At least with the zip files, I can verify things.
Thanks. I hope you like it.
Ok, I will look at this tomorrow. It is almost midnight my time. I am sorry for the problem.
Thanks. I hope you enjoy it.
You are very welcome! Enjoy!
Great! I hope you like it.
LOL. I hope it fulfills your dreams completely!
You're very welcome!
Interesting. Thank you for sharing this. I am keeping your suggestions in mind. I will have to investigate.
You only see a product icon for Content Wizard or for an item when you try to Install Smart Content? Can you post the log?
For Content Wizard, you can save the product configuration file. It is designed to be portable between computers. Then you can use Content Wizard on the other computer to install your product.
I don't understand. The zip file still works and is usable. What do you mean by "Which is removed if the zip...using DIM?"
That is strange. Especially the first time, the start should be very fast. Could you post a log?
Great!
And thanks @DoctorJellybean again.
Thanks. I am glad you are happy.
It needs the zip files for the product to be fed to it. I am surprised you would need it for Connect products though. I would expect all of those to have Smart Content already.
I would have thought so, too.
Most do have Smart Content, in fairness, but an irritatingly large percentage of that Smart Content is partial or incorrect. I actually have Daz installed on 2 computers and ended up using DIM on one computer and Connect on the other, and I haven't noticed any difference between the Smart Content on each computer. I've been trying to fix the metadata for months, and I was about ready to tear my hair out with frustration. Even if this only works on products installed through the DIM (which I think is what you're saying?), it's an AMAZING and sanity-saving tool.
To clarify... this will NOT work on older (v4 era) Renderosity products?
OK, I have done some stuff: slow but I can see why.
I've added a clothing set from Rendo with some separate texture sets by other people. By itself the script recognises the texture sets but doesn't connect them with any thing. So I can manually make the link frm the top texture to the original top: and that should show up in smart content. I can use CNTRL to select multiple top textures, and assign those.
Is there a way to get the script to automatically make the connections once I have made the initial connection: so if I link texture 1 for the top to the original top, the script would then link the top textures to the top, and other bits as well (pants or whatever) to the relevant bits?
That error is most likely that the ZIP(s) only contain POSER content and no DAZ content/assets.
The only errors I have encountered (other than POSER only content) are Install Smart Content ones with products by DreamlandModels. Have not tried all their products just BARN ONE FOR DS, SINGLE HOME 16 FOR DS and SINGLE HOME 17 FOR DS. Log indicates NUMBER OF ASSETS: 0 so suspect the problem relates to the structure of their DAZ file in the products.
Oh I did get an Install Smart Content FAILED!!!...MAKE SURE ZIP IS NOT CORRUPTED error with DFORCE-FLIRTATIOUS FOR DS by Lully, have not checked those zip file yet.
Excellent work RiverSoftArt.
Sorry for the misunderstanding. Yes, the zip is perfectly usable.One is just not able to self install the zip should the script gets lost.
So when a zip is added, and the analyze process is started, the zip gets installed? Or does it gets extracted to the working folder?
That would be up to the user to make sure the folder is empty.
Unfortunately, yes. Actually, you would need to do all the steps plus a few extra ones. For existing CPA created packages, you would need to extract the Content folder to a temp folder and delete the existing Runtime\Support directories if it exists. Also make sure that the Manifest and Supplement dsx files created by CPA are not present in the temp folder, as CPA creates new ones.
My log:
11:29:07 GMT+0100 (West-Europa (standaardtijd)): Clearing Working Directory...
11:29:07 GMT+0100 (West-Europa (standaardtijd)): ...Success
11:29:07 GMT+0100 (West-Europa (standaardtijd)): Extracting files from C:\DAZ Content Wizard Temp orginal zip\dForce Kitchen Lingerie.zip...
11:29:08 GMT+0100 (West-Europa (standaardtijd)): ...Success
11:29:13 GMT+0100 (West-Europa (standaardtijd)): Analyzing Product...
11:29:13 GMT+0100 (West-Europa (standaardtijd)): Scanning "People" directory...
11:29:13 GMT+0100 (West-Europa (standaardtijd)): wearable File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie All.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie All.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie All.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): wearable File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie Panty.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie Panty.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie Panty.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): wearable File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie Wristband.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie Wristband.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie Wristband.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): wearable File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Kitchen Lingerie.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Kitchen Lingerie.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Kitchen Lingerie.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 01.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 01.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 01.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 02.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 02.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 02.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 03.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 03.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 03.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 04.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 04.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Lingerie/Lingerie Style 04.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 01.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 01.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 01.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 02.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 02.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 02.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 03.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 03.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 03.tip.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 04.duf
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 04.duf.png
11:29:13 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Panty/Panty Style 04.tip.png
11:29:14 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 01.duf
11:29:14 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 01.duf.png
11:29:14 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 01.tip.png
11:29:14 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 02.duf
11:29:14 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 02.duf.png
11:29:14 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 02.tip.png
11:29:14 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 03.duf
11:29:14 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 03.duf.png
11:29:14 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 03.tip.png
11:29:14 GMT+0100 (West-Europa (standaardtijd)): preset_material File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 04.duf
11:29:14 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 04.duf.png
11:29:14 GMT+0100 (West-Europa (standaardtijd)): .png File: C:/DAZ Content Wizard Temp/People/Genesis 8 Female/Clothing/OneSix/Kitchen Lingerie/Wristband/Wristband Style 04.tip.png
11:29:14 GMT+0100 (West-Europa (standaardtijd)): Analysis Complete.
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Installing Product to Daz Studio...
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Verifying existence of Renderosity store: true
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Verifying "d Force Kitchen Lingerie" product does not exist already
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Found existing product in Daz Studio: d Force Kitchen Lingerie
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Product: d Force Kitchen Lingerie
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Description:
11:29:50 GMT+0100 (West-Europa (standaardtijd)): URL: 139798
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Artists: OneSix
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Store: LOCAL USER
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Vendor: false
11:29:50 GMT+0100 (West-Europa (standaardtijd)): GUID: dde7ead2-93ea-48d7-a25d-fb6fb241f2bb
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Date Installed: Fri Feb 28 2020 22:12:35 GMT+0100 (West-Europa (standaardtijd)) (Currently Installed: true)
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Date Released: Fri Feb 28 2020 22:24:49 GMT+0100 (West-Europa (standaardtijd))
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Copy: false, Delete: true, Insert: false, Modify: true, Rename: true
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Number of Assets: 1
11:29:50 GMT+0100 (West-Europa (standaardtijd)): Number of Child Containers: 0
11:29:54 GMT+0100 (West-Europa (standaardtijd)): Building product metadata...
11:29:54 GMT+0100 (West-Europa (standaardtijd)): Creating Product Icon from C:/Users/****/Desktop/Nieuwe map/kitchen lingerie.jpg...
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Creating support file...
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Importing Product into Daz Studio...
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Product Created: dde7ead2-93ea-48d7-a25d-fb6fb241f2bb
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Updating Assets Compatibility Bases...
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Product: d Force Kitchen Lingerie
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Description:
11:29:55 GMT+0100 (West-Europa (standaardtijd)): URL: 139798
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Artists: OneSix
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Store: LOCAL USER
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Vendor: false
11:29:55 GMT+0100 (West-Europa (standaardtijd)): GUID: dde7ead2-93ea-48d7-a25d-fb6fb241f2bb
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Date Installed: Fri Feb 28 2020 22:12:35 GMT+0100 (West-Europa (standaardtijd)) (Currently Installed: true)
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Date Released: Sat Feb 29 2020 11:29:55 GMT+0100 (West-Europa (standaardtijd))
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Copy: false, Delete: true, Insert: false, Modify: true, Rename: true
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Number of Assets: 1
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Number of Child Containers: 0
11:29:55 GMT+0100 (West-Europa (standaardtijd)): Installation Completed Successfully
log saying 11:29:55 GMT+0100 (West-Europa (standaardtijd)): Store: LOCAL USER while i have Renderosity selected
OK, I have installed some products and they appear in smart content.
However I have a significant problem. One product was a Rendo Maddelirium character (MDD Theory) (G8). Now when I use Daz, Genesis 8 Female isn't linking to any items such as Wardrobe, so I can't Filter by Context to find anything. Genesis 8 Male is working as per usual. Genesis 3 female loads slowly, but is working with smart content. Genesis 8 Basic Female and characters appear in the smart content pane. However if I look in materials, I can see MDD Theory (+ one other which I've been meaning to uninstall as it appears with everything).
Any suggestions? I'm guessing that the cock-up occurred with the smart content install for MDD Theory, but I don't know that. There are a range of faults reported in the log, but there have been quite a few of those before.
Hmmm. Well, I hope it makes things easier for you.
It depends (if you are talking about the Smart Content feature). If the V4 product only has stuff in Runtime directory, then there won't be any smart content. If the V4 product uses the older, script-like files (.ds), then there won't be smart content for those either.
Sorry, no.
@surreal Thanks. I will have to look at the Dreamland ones. I can confirm I have problems with Barn One, which I have. It looks like the generated .dsx is wrong, though I am unsure how at this point.
@stacywallace, it looks like your error is slightly earlier though. Have you set the artist/vendor? Could you save your configuration for this product and post it here?
For analysis, the product is unzipped to the working folder only. Only when you click Install Content do any files get copied over.
Understood.
Ok. That looks good. Can you save the configuration for this product and post that? I want to see what you classified everything as.
i am not understand **Ok. That looks good. Can you save the configuration for this product and post that? I want to see what you classified everything as.** can you explain a bit more what you need?
thanks
Nothing comes immediately to mind. I am guessing G8F WAS linking to items such as wardrobe before using this product? Or you hadn't tried in awhile? I wouldn't think that installing MDD Theory could mess it up. Can you post your CW configuration for MDD theory?
