Black Is Beautiful II
1…3738404243…52
  • HylasHylas Posts: 5,340
    During the recent sales I purchased three black female characters. Hope to get some renders out soon, will post them here!
    Rather disappointed in Shangrila by Mousso. Her morph is lovely but her skin lacks depth and is waaaay to yellow and orange. Even worse is that her face has a different tone than the rest of her body, so when I tried to balance out her complexion by adding blue to her skin, either her body or her face were always not quite right. I just requested a refund.
    This is only my 2nd Mousso character. The first one (an Asian character) has great skin, so I'm not sure what happened here. Or perhaps it's just me... the promos look alright. But then again, I never had problems like this with previous black characters.
    I'm much happier with Darcy 8 and Aniyah for Darcy 8. Face morph and skin are great for both characters, especially Aniyah. I don't particularly love their body morphs - both characters are very skinny - but it's not hard to dial in some curves.
  • GordigGordig Posts: 10,810
    Not mentioning any names, but there are some PAs here who probably shouldn't be creating black characters.
  • Slightly adding onto this, I highly respect the vendors who tell you what light set they use or render multiple examples. In an interesting reverse from Hylas, I remember when I bought a character due to one of the vendor's forum renders after ignoring the store renders (which were heavily washed out).
  • vwranglervwrangler Posts: 5,050
    edited February 2020
    Shangrila's main thing is that she's an overpaint of an FWSA Skinvent texture, and once you do that, it's hard to get detail back into the diffuse. She's also got a truly odd SSS layer; it's much darker than her diffuse, and I'm pretty sure that skin doesn't quite work that way.
    Her face is different, yes. It's set in from a different source than the rest of Skinvent, and then color matched, and it's hard to do that well. I do think her default shader made that much stronger than it is; A8L8 seems to mute it somewhat. Somewhat.
    I did wind up editing her hands and feet, because they were just weird. The lines on her palm had been drawn back in to be darker than the surrounding skin, which is good ... but they were perpendicular to where they should have been, which was truly weird.
    The yellowness that you saw was primarily due to her shader, rather than her texture. I shifted her to a different shader model with Altern8 for Lee 8 (A8L8), which both brought out what little detail she had, and undid the yellowness. I also tweaked that shader setting pretty hard to reduce her translucency weight, because A8L8 is meant for a lighter-skinned character; a translucency weight of .65 for a darker skinned character is kind of ridiculous. And then I gave her different translucency maps. I probably wouldn't have done any of that if I'd looked at her in the first 30 days I had her, but, well ... such is life. Anyway, she's workable now, I think.
    847 x 830 - 569K
    Post edited by vwrangler on
    So Shangrila's skin really has issues, good to know that I wasn't seeing things. I feel vindicated. Pity, her morph is really nice!
    Here's a really quick one...
    Face: 66% Darcy 8, 33% Mei Lin 7, plus a few tweaks
    Skin: Darcy 8 with lowered translucency
    Hey, if somebody could do me a favour and do a quick render of Laverne, but with Darcy 8 as a base instead of Monique 8, I'd sure appreciate it!
    650 x 1000 - 495K
    Post edited by Hylas on
  • sunnyjeisunnyjei Posts: 502
    vwrangler said:
    One Iray HDR light set that I use frequently for test renders is a freebie set by AgentUnawares: https://www.deviantart.com/agentunawares/art/Portrait-Light-Set-01-716649600
    The light set has a specific render setting for dark skin. He states that the set is for use in portraits, but it works pretty well for full-length as well.
    And as a side note, Daz seems to have changed something about how the forums work, with the recent unpleasantness and other issues, I guess. What I used to do -- copy the URL of the file attachment's thumbnail and delete the "thumbnail" text to get the full URL to the main image -- doesn't work any more. I had to put the example into the Daz gallery.
    Anyway, an example of how the AgentUnawares set can look. Note that there is a wall, painted a scratchy semi-gloss black, behind the character, which acts partly as a reflector. If there were no wall, the background would be either nonexistent, if the HDR dome were turned off, or black if it's on. In this case, it's on but you can't see it anyway thanks to the wall.
    EDIT: The texture is Tyrone for Darius 8. I think the settings are from Altern8 for Lee 8 -- it's been a while -- but they're definitely not his default setting.
    A weightlifter, candid
    @vwrangler
    what a great looking character :) What hair is that? I never get the hair to look that good.
  • barbultbarbult Posts: 27,586
    Here (front and profile) is Laverne 100% with Darcy instead of Monique. I dialed Darcy at the same percentages that Monique was in Laverne (body 70% head 75%). Her ear looks a little misshapen, but otherwise, she looks nice. I didn't fix poke through on the clothing.I wanted to let if fit as closely to her shape as possible.
    2000 x 1500 - 947K
    2000 x 1500 - 827K
    Post edited by barbult on
    That was quick, thank you! yes
    sunnyjei said:
    @vwrangler
    Thanks!
    It's Terran Hair. Included in the Darius 8 pro bundle.
    vwrangler said:
    sunnyjei said:
    @vwrangler
    Thanks!
    I knew it! What secret magic are you doing over there to get the curls looking so nice? I have that hair and it has never come out looking so nice in renderssurprise
    @vwrangler
    this is wonderful work. as a creator of ethnic characters im always watching others work for tips
    this is wonderful work. as a creator of ethnic characters im always watching others work for tips. to improve
  • emotionaldreams2emotionaldreams2 Posts: 141
    edited March 2020
    environment used here was Quick Lights Vol4 by PaperTiger
    skin is my character Lucious Maiya on rendo
    Post edited by Chohole on
  • sueyasueya Posts: 867
    I have noticed some people saying that Shangrila's texture needs some attention in order to make her look good. I have therefore tried using Kande's texture on Shangrila ( girl on left) The girl on the right is CC Joliette
  • Kelly2k7Kelly2k7 Posts: 30
    edited November 2020
    deleted
    Post edited by Kelly2k7 on
    Kelly2k7 said:
    I have been playing around in the surface settings lately, trying out new settings and got this as a result from a practice test.
    Very nice! yes
    @sueya: yeah, Shangrila's morph is really nice. She looked great with the skin of Eden and Twylite.
    I haven playing around in the surface settings lately, trying out new settings and got this as a result from a practice test.
    Hylas said:
    Very nice! yes
    Thanks
    A few characters I designed for a fantasy project.
    Yamowe
    Mawasi
    Giral
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,984
    edited March 2020
    I don't know she looks fine to me.  I got her when she was sold at Rendo.
    2000 x 2600 - 3M
    Post edited by ALLIEKATBLUE on
    Completely agree, and the issue isn't just limited to dark-skinned characters either. Perhaps I'm more picky than others, but it just seems that there's very very few that can make skin reasonably CONSISTENT. I've been told things ranging from "Just use different skin" to "Its your lighting". Well, when I see two different skin colors and/or major light/dark discrepancies between limbs/torso/etc., that are generally an equal distance from the same light source and are being illuminated from the same angle at the same brightness, its NOT the lighting. Its even more obvious when you open the textures in an image editor and see the dramatically different RGB values. It almost looks like they used two completely different skins and blended them together just enough so that there aren't any seams.
    Well ... that's almost certainly what they did do.
    When you use merchant resources, you have to work to make them look different from every other character using the same resource. The first thing they'll do is swap out the face and blend the edges, and -- ideally -- tinker with the skin tones to make them match without washing out the detail in the face. That's all fairly difficult.
    Working from photographic resources that haven't been mapped to the UV of whatever character you're trying to make is apparently immensely more difficult -- time and cost prohibitive, for most -- which is why merchant resources get used. (And in the case of male resources in particular, overused.)
  • Hylas said:
    lovely.. what hair is that?
  • Kenyatti pauses in the middle of creek bridge to contemplates just how safe that shortcut through foreboding forest is.
    edited April 2020
    It's Redz Real Curly by RedzStudio, over at Renderosity.
    The same vendor is selling a very similar product here as well: https://www.daz3d.com/short-afro-hair-for-genesis-3-and-8
  • NylonGirlNylonGirl Posts: 2,400
    Glasses really make a wardrobe complete.
    Black Woman in Purple Glasses
  • 3Diva3Diva Posts: 12,058
    edited April 2020
    The character Laverne is still one of my favorites. Here she is with some Altern8 Lee 8 Adjustments and light post-work (color and contrast adjustment).
    800 x 1040 - 1M
    Post edited by 3Diva on
  • SevrinSevrin Posts: 6,314
    Here is a render I did of Oshun.  This is a beautiful HD model and she renders pretty nicely without too much trouble.
    Black Girl in Grey Shirt
