[Released] Props & Poses Converter from Genesis 3 Female to Genesis 8 Female [Commercial]
13
  • RiverSoft ArtRiverSoft Art Posts: 6,977
    edited January 2020
    Cybersox said:
    Cybersox said:
    Any eta on G8f to G3f or v4 to g8?
    No, not eta yet.
    Is there a spark of life, at least?
    Spark?  Maybe.  But I still have to get G3M to G8M released first, and I got really busy with a "may not be able to sell it but I want it myself" project.
    Post edited by RiverSoft Art on
  • CybersoxCybersox Posts: 10,012
    Cybersox said:
    No, not eta yet.
    That wouldn't be the long awaited, much desired Freak 5 to AIko 3 pose convertor, would it?  heartheartheart
    Fine.  Just let us know before you drop the idea of other prop convertors entirely... you might be surprised to find that some of us are willing pay a much higher price tag than the going DAZ rates.
  • Cybersox said:
    Cybersox said:
    No, not eta yet.
    LOL.
    Oh, I want to continue them, though the posing (required for good conversion of props) gets significantly more challenging the farther back you go.
  • sean2_7606d08833sean2_7606d08833 Posts: 43
    edited January 2020
    is it normal for it to be slow? I don't have a slouch of a system by any means, but a normal-sized pose pack takes about 30min to complete. I dumped one in last night before bed that had over 900 lines and it's still running almost 19hrs later. My system specs are Ryzen 7 1800x w/ 32GB RAM and 1080TI.
    DS seems to get slower the more morphs you add to a figure; I don't know if it affects posing but it does affect loading G8F.  If you temporarily rename all those character conversion morphs to a new path, from data/Daz 3D/Genesis 8/Female/Morphs to data/Daz 3D/Genesis 8/Female/OldMorphs, G8F will load faster.  That might help with your pose conversion.
    So I'm hitting this performance issue with converting poses as well, and it feels to me like it's a bug. It *seems* like props convert much faster than poses, although I haven't measured the former, only the latter.
    I went through all my content directories and renamed Female to Femalex for all of Genesis 8 and most of Genesis 3, and added a new content directory with just the very minimum needed to load G3F and G8F without warnings.
    (Please Forgive the wonky formatting, but the preview and the actual post didn't match at all and I had to do a lot of tweaking just to get it readable.)
    Load times for G3F and G8F:
    2020-01-20 02:11:48.625 File loaded in 0 min 14.7 sec.
    2020-01-20 02:11:48.625 Loaded file: genesis 3 female.duf
    2020-01-20 02:11:57.907 File loaded in 0 min 3.8 sec.
    2020-01-20 02:11:57.907 Loaded file: genesis 8 basic female.duf
    It took 7 minutes to convert two poses (on an i9 @ 3.1 Ghz). Basically all the time is while "Writing assets..." is displayed.
    Here's the DAZ log file of the process for the first one (the converter log file didn't have anything useful):
    2020-01-20 01:40:24.691 DEBUG: START Conversion of D:/daz/main/People/Genesis 3 Female/Poses/Simply Everyday/Poses/Genesis 3 Female/Simply Everyday Female Base 01.duf
    [redundant informative stuff]
    2020-01-20 01:40:24.940 DEBUG: Copy loaded pose from Genesis 3 Female to Genesis 8 Female
    2020-01-20 01:40:24.940 DEBUG: Copy Pose Properties from Genesis 3 Female to Genesis 8 Female
    2020-01-20 01:40:24.940 DEBUG: Pose Controls set? false
    2020-01-20 01:40:25.751 Copying pose from Genesis 3 Female to Genesis 8 Female
    2020-01-20 01:40:26.360 DEBUG: Ancestor Bone is hip
    [lots of Loaded morph deltas]
    2020-01-20 01:40:27.686 Zeroing Genesis 3 Female Pose
    2020-01-20 01:40:27.686 DEBUG: Trigger Action DzZeroFigurePoseAction
    2020-01-20 01:40:27.717 DEBUG: Triggered Action DzZeroFigurePoseAction
    2020-01-20 01:40:27.717 DEBUG: Save Pose [very long line with all the bones]
    2020-01-20 01:40:27.811 Saving Pose to D:/daz/conversion3/People/Genesis 8 Female/Poses/Genesis 3 Female/Simply Everyday Female Base 01.duf
    2020-01-20 01:40:27.826 DEBUG: Defaults: {
    [1400 lines of JSON]
    2020-01-20 01:40:27.889 DEBUG: Saved Item: D:/daz/conversion3/People/Genesis 8 Female/Poses/Genesis 3 Female/Simply Everyday Female Base 01.duf
    2020-01-20 01:43:59.068 Zeroing Genesis 8 Female Pose
    2020-01-20 01:43:59.161 DEBUG: Trigger Action DzZeroFigurePoseAction
    2020-01-20 01:43:59.239 DEBUG: Triggered Action DzZeroFigurePoseAction
    2020-01-20 01:43:59.239 DEBUG: End convert
    2020-01-20 01:43:59.645 DEBUG: END Conversion of D:/daz/main/People/Genesis 3 Female/Poses/Simply Everyday/Poses/Genesis 3 Female/Simply Everyday Female Base 01.duf
    2020-01-20 01:43:59.645 DEBUG: RemoveExtraSkeletons Genesis 3 Female Genesis 8 Female
    In this log it looks like all of the time is between printing "DEBUG: Saved Item:" and "Zeroing Genesis 8". If tenses are consistent, "saved" happens after saving and "zeroing" happens before zeroing, so I'm not sure what's going on in between. Or maybe "Saved item" is before it saves and it's actually the save somehow taking 3.5 minutes. (I checked, just in case; saving a pose manually takes under a second, and zeroing g8 female pose is near instant.)
    There's another bug here which I'll report in a separate message for clarity.
    Post edited by sean2_7606d08833 on
    edited January 2020
    There's a bug in how new filenames are generated.
    In the above example, the input filename is:
    "D:/daz/main/People/Genesis 3 Female/Poses/Simply Everyday/Poses/Genesis 3 Female/Simply Everyday Female Base 01.duf"
    but the output filename is
    "D:/daz/conversion3/People/Genesis 8 Female/Poses/Genesis 3 Female/Simply Everyday Female Base 01.duf"
    Note that in the original, "Genesis 3 Female" and "Poses" both appear twice.
    In the output, the folder name "Simply Everyday" and one of the "Poses" has been lost.
    I realize this is non-trivial in this particular case, but I intentionally chose a product sold as a "DAZ Original" as something that one would expect should work. The wonkiness here is presumably because "Poses" appears again in the folder name. It seems like you're finding the rightmost occurrence of "Poses" rather than the leftmost. Of course the leftmost could break if the content directory itself has "/poses/" in it somewhere, which is not impossible. It feels like the RIGHT way to do this is to actually scan the list of content directories and match that to the filename so that you know what the true relative path from the content directory is, but if that's impossible or just too much work I think doing a match (either leftmost or rightmost) on "People/Genesis 3 Female/Poses" [and similar variants for other types] would be a lot safer than a rightmost match for "Poses".
    edited January 2020
    The delay is because I am updating the metadata.  When you save something in scripting you are supposed to be able to set what it is compatible with and set its compatibility base. There was a bug pre4.12 that doesn't allow you to do both at the same time. There is a function to set this stuff but it is slow.  I was told by Daz to use it as a workaround that made the code work pre-v4.12 "but won't mess anything up once the bug is fixed."  Supposedly, I could remove it now but I have seen this bug rear its head in other situations even just this week so I am reluctant to do so.
  • There's a bug in how new filenames are generated.
    The problem is every PA does something different, especially years ago.  It would be wonderful to match a relative path, but I can't see doing so.  Poses can be in People/.../Poses, in Environments/.../Poses, etc.  The standard, that Daz recommends but does not enforce, is that it should be in People/Genesis 3 Female/Poses/Vendor/Product/My Pose.duf.  You can always cut and paste within the Content Library in Daz afterwards.
    This is metadata for smart content and categories? Could we just have the option to not update the metadata? I don't need either of those updated in this case, and the current speed makes it unusable for me.
  • It would be wonderful to match a relative path, but I can't see doing so.
    DzContentManager::getRelativePath()? Then replace 'Genesis 3 Female' with 'Genesis 8 Female' and append to specified output directory?
    I can do that.
    edited January 2020
    This is a really good idea, but my point was that things are put all over the place.  There is no guarantee that 'Genesis 3 Female' is even in the path.  DAZ installs there, but users can sometimes organize their libraries differently. Searching for Poses is MUCH safer.
  • Ok, thanks.
  • Ok, thanks.
    Can you PM me your email address?  I would like to test that it makes a difference on your system.  I will add the options and all if it is.  Thanks.
  • I got a problem.  The script runs but it doesn't convert anything.
    Here's what appears in the script log:
    07:53:44 GMT-0600 (Central Standard Time): Executing Script
    07:53:44 GMT-0600 (Central Standard Time): Selecting Preset: D:/!PROJECTS & INSPIRATION/!Projects/Project 7 - Random Action Adventure/People/Genesis 3 Female/Clothing/Darkshade/Hand Poses/Darkshade Sai Hand Pose L.duf
    07:53:44 GMT-0600 (Central Standard Time): Converting prop or pose from D:/!PROJECTS & INSPIRATION/!Projects/Project 7 - Random Action Adventure/People/Genesis 3 Female/Clothing/Darkshade/Hand Poses/Darkshade Sai Hand Pose L.duf to D:/Converted Daz Content/!Converted Props/G3 to G8/Darkshade/Hand Poses/Darkshade Sai Hand Pose L.duf
    In the DAZ Studio log, I noticed this at the end:
    2020-02-11 07:53:45.828 WARNING: ..\..\..\..\..\src\sdksource\general\dzscript.cpp(1178): Unhandled error while executing script.
    2020-02-11 07:53:45.828 WARNING: QScriptEngine::popContext() doesn't match with pushContext()
    My output folder is empty.  Any thoughts?
    Could you post the full log of the conversion?  Something went wrong but it is hard to tell from this.
  • If you can wait a bit, I will run it again.  It looks like the script detected that the weapon was a wearable instead of a prop but it's hard to tell.  I have an appointment soon.  After I will try to convert again.
  • I think this part is the most important.  It converted the poses for the weapons, though.
    2020-02-11 19:24:30.013 DEBUG: Compatibility Base
    2020-02-11 19:24:36.482 DEBUG: Saved Clothing Item: D:/Converted Daz Content/!Converted Props/G3 to G8/Darkshade/Hand Poses/Darkshade Sai Hand Pose R.duf
    2020-02-11 19:24:38.235 Zeroing Genesis 8 Female Pose
    2020-02-11 19:24:38.347 DEBUG: Trigger Action DzZeroFigurePoseAction
    2020-02-11 19:24:39.548 DEBUG: Triggered Action DzZeroFigurePoseAction
    2020-02-11 19:24:39.549 DEBUG: End convert
    2020-02-11 19:24:39.675 DEBUG:      Copy Icons from D:/!PROJECTS & INSPIRATION/!Projects/Project 7 - Random Action Adventure/People/Genesis 3 Female/Clothing/Darkshade/Hand Poses/Darkshade Sai Hand Pose R.duf to D:/Converted Daz Content/!Converted Props/G3 to G8/Darkshade/Hand Poses/Darkshade Sai Hand Pose R.duf
    2020-02-11 19:24:39.690 DEBUG:      Copy Categories from D:/!PROJECTS & INSPIRATION/!Projects/Project 7 - Random Action Adventure/People/Genesis 3 Female/Clothing/Darkshade/Hand Poses/Darkshade Sai Hand Pose R.duf to D:/Converted Daz Content/!Converted Props/G3 to G8/Darkshade/Hand Poses/Darkshade Sai Hand Pose R.duf
    2020-02-11 19:24:39.692 DEBUG:      Cannot find assets for old preset /People/Genesis 3 Female/Clothing/Darkshade/Hand Poses/Darkshade Sai Hand Pose R.duf
    2020-02-11 19:24:39.692 DEBUG: END Conversion of D:/!PROJECTS & INSPIRATION/!Projects/Project 7 - Random Action Adventure/People/Genesis 3 Female/Clothing/Darkshade/Hand Poses/Darkshade Sai Hand Pose R.duf
    2020-02-11 19:24:39.702 DEBUG: RemoveExtraSkeletons Genesis 3 Female Genesis 8 Female
    2020-02-11 19:24:39.705 DEBUG: Selecting Preset: D:/!PROJECTS & INSPIRATION/!Projects/Project 7 - Random Action Adventure/People/Genesis 3 Female/Clothing/Darkshade/Darkshade Sai LH.duf
    2020-02-11 19:24:39.773 DEBUG: START Conversion of D:/!PROJECTS & INSPIRATION/!Projects/Project 7 - Random Action Adventure/People/Genesis 3 Female/Clothing/Darkshade/Darkshade Sai LH.duf
    2020-02-11 19:24:39.774 DEBUG: Converting prop or pose from D:/!PROJECTS & INSPIRATION/!Projects/Project 7 - Random Action Adventure/People/Genesis 3 Female/Clothing/Darkshade/Darkshade Sai LH.duf to D:/Converted Daz Content/!Converted Props/G3 to G8/Darkshade/Darkshade Sai LH.duf
    2020-02-11 19:24:39.782 DEBUG: Converting Prop or Pose
    2020-02-11 19:24:39.884 Converting Prop,Follower/Accessory,Preset/Pose/Hierarchical,Preset/Pose,Preset/Wearables,Preset/Properties: Darkshade Sai LH
    2020-02-11 19:24:40.002 Applying Preset: Darkshade Sai LH
    2020-02-11 19:24:40.002 DEBUG: Apply Preset D:/!PROJECTS & INSPIRATION/!Projects/Project 7 - Random Action Adventure/People/Genesis 3 Female/Clothing/Darkshade/Darkshade Sai LH.duf
    2020-02-11 19:24:40.558 File loaded in 0 min 0.1 sec.
    2020-02-11 19:24:40.558 Loaded file: Darkshade Sai LH.duf
    2020-02-11 19:24:40.581 DEBUG: WARNING: OctaneRender Scene Data does not have a presentation
    2020-02-11 19:24:40.581 DEBUG: Presentation is null.  Forcing presentation for wardrobe
    2020-02-11 19:24:40.583 DEBUG: Asset Mgr says content type is "": D:/!PROJECTS & INSPIRATION/!Projects/Project 7 - Random Action Adventure/People/Genesis 3 Female/Clothing/Darkshade/Darkshade Sai LH.duf
    2020-02-11 19:24:40.599 DEBUG: Asset is wearable
    2020-02-11 19:24:40.599 DEBUG: UpdatePreferredBase [object Object] /Genesis 8/Female
    2020-02-11 19:24:40.607 DEBUG: Presentation
    2020-02-11 19:24:40.607 DEBUG:   autoFitBase
    2020-02-11 19:24:40.607 DEBUG:   colorA [object Object]
    2020-02-11 19:24:40.607 DEBUG:   colorB [object Object]
    2020-02-11 19:24:40.607 DEBUG:   description
    2020-02-11 19:24:40.607 DEBUG:   iconLarge
    2020-02-11 19:24:40.607 DEBUG:   iconSmall
    2020-02-11 19:24:40.607 DEBUG:   label
    2020-02-11 19:24:40.607 DEBUG:   Preferred Base /Genesis 8/Female
    2020-02-11 19:24:40.607 DEBUG:   type Prop
    2020-02-11 19:24:40.607 DEBUG: Prop is OctaneRender Scene Data
    2020-02-11 19:24:40.617 DEBUG:
    2020-02-11 19:24:40.617 DEBUG: Vendor Name: RiverSoft Art
    2020-02-11 19:24:40.617 DEBUG: Product Name: OctaneRender Scene Data for Genesis 8 Female
    2020-02-11 19:24:40.617 DEBUG: Item Name: OctaneRender Scene Data
    2020-02-11 19:24:40.617 DEBUG: Copy loaded pose from Genesis 3 Female to Genesis 8 Female
    2020-02-11 19:24:40.617 DEBUG: Copy Pose Properties from Genesis 3 Female to Genesis 8 Female
    2020-02-11 19:24:40.673 DEBUG: Copying "pCTRLlFingersGrasp" to "pCTRLlFingersGrasp": 1 (weight=1), old=0
    2020-02-11 19:24:40.680 DEBUG: 1 0
    2020-02-11 19:24:40.681 DEBUG: 1 1
    2020-02-11 19:24:40.681 DEBUG: Copy Pose Properties from Genesis 3 Female to Genesis 8 Female
    2020-02-11 19:24:40.735 DEBUG: Copying "pCTRLlFingersGrasp" to "pCTRLlFingersGrasp": 1 (weight=1), old=1
    2020-02-11 19:24:40.735 DEBUG: Pose Controls set? true
    2020-02-11 19:24:41.244 Loaded image DarkShadeSai.jpg
    2020-02-11 19:24:41.448 Loaded image DarkShadeSaiB.jpg
    2020-02-11 19:24:41.931 Copying pose from Genesis 3 Female to Genesis 8 Female
    2020-02-11 19:24:42.317 DEBUG: Ancestor Bone is lHand
    2020-02-11 19:24:42.726 DEBUG: END Conversion of D:/!PROJECTS & INSPIRATION/!Projects/Project 7 - Random Action Adventure/People/Genesis 3 Female/Clothing/Darkshade/Darkshade Sai LH.duf
    2020-02-11 19:24:42.726 DEBUG: RemoveExtraSkeletons Genesis 3 Female Genesis 8 Female
    2020-02-11 19:24:43.010 DEBUG: Execution Complete.
    2020-02-11 19:25:03.088 WARNING: Script Error: Line 1071
    2020-02-11 19:25:03.088 WARNING: Error: cannot access member `getNodeParent' of deleted QObject
    2020-02-11 19:25:03.088 WARNING: Stack Trace:
        <anonymous>()@C:/Users/Public/Documents/My DAZ 3D Library/data/RiverSoft Art/Common/RSPropConversionFunctions.dse:1071
    2020-02-11 19:25:03.105 Error in script execution: C:/Users/Public/Documents/My DAZ 3D Library/Scripts/RiverSoft Art/Props & Poses Converter/Props & Poses Converter G3F to G8F.dse
    edited February 2020
    Ok, this is weird.  The script loads the DrakShade Sai LH, but what it finds is something called OctaneRender Scene Data?  I don't do Octane but I wonder if it puts something in the scene?  When I run on the same item, the script finds the weapon and everything is different after that:
    2020-02-12 08:07:05.638 DEBUG: START Conversion of D:/Documents/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Darkshade/Darkshade Sai LH.duf
    2020-02-12 08:07:05.640 DEBUG: Converting prop or pose from D:/Documents/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Darkshade/Darkshade Sai LH.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Props/Darkshade/Darkshade Sai LH.duf
    2020-02-12 08:07:05.640 DEBUG: Converting Prop or Pose
    2020-02-12 08:07:05.872 Converting Prop,Follower/Accessory,Preset/Pose/Hierarchical,Preset/Pose,Preset/Wearables,Preset/Properties: Darkshade Sai LH
    2020-02-12 08:07:05.972 Applying Preset: Darkshade Sai LH
    2020-02-12 08:07:05.972 DEBUG: Apply Preset D:/Documents/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Darkshade/Darkshade Sai LH.duf
    2020-02-12 08:07:06.384 File loaded in 0 min 0.2 sec.
    2020-02-12 08:07:06.384 Loaded file: Darkshade Sai LH.duf
    2020-02-12 08:07:06.839 DEBUG: DarkShadeSai_LH ( Prop/Arm/Left/Hand ) is Clothing Prop,Follower/Accessory,Preset/Pose/Hierarchical,Preset/Pose,Preset/Wearables,Preset/Properties? true
    2020-02-12 08:07:06.839 DEBUG: UpdatePreferredBase [object Object] /Genesis 8/Female
    2020-02-12 08:07:06.839 DEBUG: Presentation
    2020-02-12 08:07:06.839 DEBUG:   autoFitBase
    2020-02-12 08:07:06.840 DEBUG:   colorA [object Object]
    2020-02-12 08:07:06.840 DEBUG:   colorB [object Object]
    2020-02-12 08:07:06.840 DEBUG:   description
    2020-02-12 08:07:06.840 DEBUG:   iconLarge
    2020-02-12 08:07:06.840 DEBUG:   iconSmall
    2020-02-12 08:07:06.840 DEBUG:   label
    2020-02-12 08:07:06.840 DEBUG:   Preferred Base /Genesis 8/Female
    2020-02-12 08:07:06.840 DEBUG:   type Prop/Arm/Left/Hand
    2020-02-12 08:07:06.842 DEBUG: Prop is DarkShadeSai_LH
    2020-02-12 08:07:06.855 DEBUG:
    2020-02-12 08:07:06.855 DEBUG: Vendor Name: RiverSoft Art
    2020-02-12 08:07:06.855 DEBUG: Product Name: Darkshade Outfit for Genesis 3 Female(s)
    2020-02-12 08:07:06.855 DEBUG: Item Name: DarkShadeSai_LH
    2020-02-12 08:07:06.855 DEBUG:      Directory does not exist: D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Props/Darkshade
  • I do have Octane for Daz Studio installed on my computer.  But Octane has never been an issue before with your clothing and poses converters.  Hmmm, I will try to disable it and see what happens.  I will let you know.
    For the RSSY Clothing Converter from Victoria 4 to Genesis 8 Female there was an update that the readme said: 2020-02-13 Added.CRZ Support
    What does that mean?
    It means that it will find.CRZ files now as welll as the other file types.
  • HeavyRayHeavyRay Posts: 190
    re:   Spark?  Maybe.  But I still have to get G3M to G8M released first, and I got really busy with a "may not be able to sell it but I want it myself" project.
    I sure hope that new project is the "universal" content_packager/metadata_inserter that you teased us with in a recent (YT?) video??  I am dying to have something like this...  The comment about "may not be able to sell" does concern me though....  ;-(
    I don't have any comment about it at this time. sad
  • c567591ac567591a Posts: 47
    carrie58 said:
    Okay so I have to ask this but is the Generation 4 to Genesis 8 on list for this ?I ask cause I have a lot more jewelry for V4 then any other generation ........and somebody had to ask ya know
    Sheesh!  You really cannot wait. laugh If the sales support it, yes, it is on the list, though the posing is harder between V4 and G8F.
    I'm definitely looking for the V4 version.  I have a LOT of V4 props I'd like to use and its a lot of work to move them all back in place (especially rings).
    oh i second this highly! LOL.
    Ok, I get the message!  laugh  I will see what I can do.
  • AntonoAntono Posts: 24
    I find myself visiting your DAZ store and this thread every day to look for any updates on the V4 version. It would breathe a second life to a lot of beloved stuff in my runtime.
    (in case the message wasn't loud and clear)
    LOL.  Message received.  However, I usually go down the generations, and especially with this one where the pose conversion will get more challenging as I go further back (good pose conversion is necessary for good prop conversion).
  • lwaveslwaves Posts: 238
    I'm just saying but given the dominance of folks in this thread asking for a V4 to G8F version, you could always get the hardest one out of the way next, making your life 'easier' after that. Not that I'm hinting at you to do anything out of order. cheeky  Pwetty please, with sugar on top.wink
    laugh
