Adding to Cart…
I think your list got mixed up at some point as the one you titles t1 really doesn't look like 6500°K with pure white emissive colour... other question is at which luminance did you render?
I will not comment more tonight as I'm really tired, so more comes tomorrow, I will just add th testrenders as I made them, I included the light settings in the screenshots
Yes i made mistake naming it.
It was orange color 6500 temprature.
100k (100,000) lumens. No problem and have a nice sleep. I will also not work anymore today.
@TrisValentine, Here are some quick tests. These are all viewport draws, with Draw Mode set to Iray Nvidia and Environment set to a Color Black Backdrop. Images link to original size, and open in a new window.
The first two images have Emission applied to the light, using the Emission Color: White and Emission Temperature (K) of 4500. The light renders white, and the plane does not have any yellow on it. Full size image does show some yellow cast inside the glass.
The next three images have the Emission Color set to a bright yellow and the Emission Temperature (K) set to 0. The light renders the bright yellow, and fills the interior of the glass. The plane in the second image, however, still does not have a yellow cast.
The third image bumps the Luminance up to 60000 kcd/m^2 and does provide a slight yellow cast to the plane. (The same Luminance value did not produce a yellow cast in the Emission Color White example, so I didn't capture the draw.)
With a different set, I loaded the Iray version. I changed only the two globes in the center fixture, changing Emission Color to a bright green and Emission Temperature (K) to 0. The Luminance value is the default, and the same as the other globes in the set.
This last image changes the Emission Color to a soft yellow that matches the color of the rest of the globes. Emission Temperature (K) is still 0. Notice the reflected color above the four globes. The reflected color on the left has a greenish cast to it.
I hope this helps.
Thank you very much for your time and efforts. I sometimes feel little bad for asking too many questions here. I understand litlle bit of the concept behind this now but i will probably learn better when i am working with lights and by lighting different things.
Gel lighting and gobo lighting work is going slower then expected. I did make couple of scenes and renders but i ditched them as i didn't feel they were good enough quality for iray. Anyway looking at some gobo/gel references again and again today did give me some new ideas and its really nice to learn about things i never knew about. I had never heard about gobo and gel lights before i discovered this challenge. Even the last challenge about duplication helped a lot. When i was extending dream house by placing trees and walls i did not knew about instancing. Imagine how bad the lag was loading more then 20 trees and 40 walls in one scene.
I really appreciate the efforts everyone is placing in this challenges.
Thanks for your help. Btw. All this was to get shadows in 3 delight, but how do I turn on the shadows in IRay, in other projects?
Latest render. This would be really hard in I ray.
In Iray the shadows are always there, as it tries to simulate physical light, and there is no light without shadow. So no options to get rid of shadows in iray either, only some clever light settings to make a plac e seem shadowless
Hopefully someone will correct me if I am wrong but with temperature you are going to get a more "natural" looking light based on the temp you are using.
By colouring the light you have more control over the specific shade, ie: the only way to get purple is to colour the light.
Any time you put a primitive in front of a light source it is going to dim the light. Like having a set of sheer curtains covering a window. The light still comes through but not as strong.
Which light you use will come down to a combination of personal taste and what is required for the image. Each has their advantages and disadvantages.
You have some good reflections on the floor and the characters are looking good. Poses look natural. Is the only source of light coming from the outside? Are interior lights turned on?
I am missing pools of light coming from light sources inside the facility.
Shadows are always on in Iray. Every light source you use will cast shadows.
If you move or possibley rotate her arm / shoulder back slightly it may allow more of her face to be visible. Other than that her pose looks great and she has a wonderful expression.
I really like that shot of red in an otherwise monochromatic image.
The lights are on, but they're currently using 40 watt bulbs.
I have checked that the man and dog are on the ground plane using my "Drop to terrain" script. I have also changed the dog's pose to make it look more natural. I changed the colour of the IBL light to yellow which I think has toned down the glossiness of the dog a bit. I tried to add some shadows to show that both figures are on the ground by adding a spotlight above the man but I don't think the angle is right.
So here is ver.3. I think this will be the last revision, I am happy with the way it looks now, I ended up adding a spotlight really high up to camera left and pointed it at the roof for the "moonlight".
I guess I'm channeling Anastacia of Astora, now.
Gobo is courtesy of OutOfTouch; I was lazy so I grabbed a HairBlend mask instead of firing up Gimp. I dropped the gel in favor of turning the temperature up, as the light didn't seem right.
marjoemartino: You may want to look into emission profiles for your flashlight. There's a forum thread here and a product here; I'm not very practiced with them, but it really helps differetiate between close, man-made lights and distant and/or natural lights. Your lighting is really even, which makes more sense for sunlight or moonlight than something behind a glass lense. Additionally, the profile can help draw the eye to the source, whereas in your image I find the flashlight easy to overlook.
Part of the difficulty of using IBL is the interface between 2D and 3D. It's relatively straight-forward to manage when the area around the camera is flat. (Relatively is the key word.) Unfortunately, it doesn't look like your dome is doing you any favors. The pure topography of the site would have been bad enough, but the immediate area is full of bushes! Captured as a flat image, I don't know of any way to weave your 3D characters in amongst them the way they would have been had they been in front of that camera.
A common solution is cut off your characters' feet, but that doesn't really work with what your characters are doing. If you plan to stick with IBL, I would recommend looking for a flatter image: a field, not a brushy hillside.
AT, Kismet2012. I started of by doing a smiple render to show the light bulb but i took on a life of it's owne. i think this one belongs in the beginer challange but don't know.
Now for the problem. Is the lightbulb magic or is it the boy?
Hi Sueya. You clould add a prop as a base for your figers to stand on like a big rock or somthing. In this render the marble and figers are props and every thing behind her is a LBI. I hope this helps.
Not for the challange.
You have a nice pose in this scene. did you make it yourself? The background HDRI is way off and does not suit this scene. The subjects are not standing on ground even if the script said so. I feel like you should just change the HDRI and here is Forum Thread that lists free to use HDRI's. I recommend using a park HDRI and properly reading licences for whichever HDRI you end up using.
To reduce the glossiness you have to select dog first and change settings under surface tab.
EDIT:
Other than this, i feel like you need to use something to showcase lighting. I mean the challenge's theme is presence or lack of lighting and using a variety of them will be nice.
That is a very nice picture.
This scene looks very nice.
This is purely my view and you can ignore it but if there was some kind of volumetric light coming from windows that lit some of the the room then that that would look awsome. The scene could be darker to make the bulb stand out and could even create reflections in the eyes of the boy.
Hi! Lots of great stuff here - I can't wait to go back through the thread and look at everything more thoroughly. In the meantime, I'm participating in the intermediate challenge. Here is my image so far:
I ended up with this after a few hours of playing around with various toys (especially the Luminosity light sets, which are a LOT of fun). I really like a lot of the elements of this image, but taken together ... it doesn't feel cohesive, and I'm at a loss as to what direction to go next. Comments/critiques/advice would be very much appreciated!
Hello,
here is my entry for the beginner's "Lighting" competition. I played quite a bit with up to four lights to get the mood I wanted for this scene. In the end, I decided to use just two lights: the cold, slightly bluish "moon-light" through the window and the warm light from the candle. Both lights meet at the scene's main figure.
I would really appreciate critiques, hints and tips for improving the scene :)
I call the scene "Nighthounds".
Best regards,
@cloth1975. WoW! I loveit. Um what is she holdng? And the thng looking throug the window with the moon light on it is awsome.
@TrisValentine, What i was thinkig and there are some other things i wont to do as well. Plus i wont to have a go at doing some trans on the ears.
Images taking on a life of their own does seem to happen. I often start out with one idea and end up somewhere completely different.
To answer your problem...for me it is the boy.
The problem may be the black background. It gives the impression of going on forever. Is there a backdrop or did you change the background colour to black? If there is no backdrop perhaps adding something, even a plane or a curtain if you have one, to give the impression there is a "wall" of some kind behind her. Like if she is on a stage.
Lovely image.
This is getting really nitpicky but is the flame on the candle a separate prop? Can it be adjusted? If yes, the flame should be up straight even as the candle is being held at an angle.
Or it could be the camera's angel that is giving me that impression.
