Cape with fur
I purchased the bundle of this product.
https://www.daz3d.com/dforce-classic-fur-cape-and-textures-bundle
I can't put the fur in the cape. I clicked in each material, the color changes but the fur does not come out. Here's how you see it. can anyone help me understand how it works? I add that there is a pdf with tutorial, but it only explains how to perform the dforce. Thanks
    Strand-based hair will only show in the render.
  • Okay, thanks, let's try it now
  • FSMCDesignsFSMCDesigns Posts: 12,858
    If you change the Viewport Line Tessellation Sides to 2 or more in the parameters tab, it usually shows in the iray preview mode.
  • felisfelis Posts: 6,611
    Or set Parameter > General > Simulation > Hair > Pre Render (PR) to "On" for the fur.
  • Fantastic, thanks. They are seen only during rendering occhiolino
  • it is visible only during rendering. They are not seen with the iray preview
