Mesh shrinkage during Morph transfer from G3F to G8F
I'm noticing quite a bit of mesh shrinkage when I transfer a morph from G3F to G8F - particularly in the lips - would anyone have a theory as to why? Using the transfer utility
thanks
  • nicsttnicstt Posts: 11,715
    I'm tempted to say you have subd on, but you couldn't transfer the morphs if that was the case.
    I'd look for something turned on as I done have it when I transfer morphs. Currently used, is a good place to check.
    Ensure no scaling anywhere.
  • rebooting this question. I have tried multiple trabsfer methods and still see the shrinkage - do others see this?
  • It would help if you described the methods you are using, and what you mean by shrinkage.
  • I have tried the G3 to G8 character converter scripts most recently but I have also tried the standard trsnfer utilty method. I see the effect even if I dial a character into some shape and export the obj and re-import it with morph loader pro as a single dial morph. And by shrinkage I mean I see sublte shrinkage from the original - even at subdivision level 1 - such that the where in the original the mouth looked closed - in the morph the lips look slightly thinner such that the mouth looks slightly open.
