Mesh shrinkage during Morph transfer from G3F to G8F
bwise1701
I'm noticing quite a bit of mesh shrinkage when I transfer a morph from G3F to G8F - particularly in the lips - would anyone have a theory as to why? Using the transfer utility
thanks
I'm tempted to say you have subd on, but you couldn't transfer the morphs if that was the case.
I'd look for something turned on as I done have it when I transfer morphs. Currently used, is a good place to check.
Ensure no scaling anywhere.
rebooting this question. I have tried multiple trabsfer methods and still see the shrinkage - do others see this?
It would help if you described the methods you are using, and what you mean by shrinkage.
I have tried the G3 to G8 character converter scripts most recently but I have also tried the standard trsnfer utilty method. I see the effect even if I dial a character into some shape and export the obj and re-import it with morph loader pro as a single dial morph. And by shrinkage I mean I see sublte shrinkage from the original - even at subdivision level 1 - such that the where in the original the mouth looked closed - in the morph the lips look slightly thinner such that the mouth looks slightly open.
