Adding to Cart…
It’s a difficult pose, a pose with two figures.
Maybe it helps if I tell you how I did it with my render also two figures.
First I start with the main figure the male.
I rotated him in the right direction and pose the lower body (hip, legs, and feet)
Then pose the upper body not the arms and the head that will came later
Now the second figure the female I rotate her in the right position and also begin with the lower body
(Hip, legs, feet) then pose the upper body when I did that I go further with the male upper body
to fit with the female then, the arms, neck, head and the hand then fix a few things what wasn’t Quite right.
I hope this is helping.
Keep going you can do it.:)
Jeff, are you trying to say that you don't think I can do it in just a month? :lol: Why don't we have a laughing-until-crying smiley? You know me too well, dear friend.
I like posing the Ando-Genesis. Then adding skin, clothes, hair are easy. Next you'll want me to add a background, cameras, and lights, won't you? I keep forgetting to render before coming to the forums, so I'll go do that and be back.
AtticAnne, I know who needs a little push just to get them over the hump. Push, nudge... winky wink.
Surgeon removed right hand from thigh. Worked on her left hand. Slow and steady goes the course. Back to working on hip.
I could tell you how to do some tweaking in poser, but not sure if the commands are the same in DS.
Hmm; face towards the camera, right shoulder a little forward and both shoulders a little more relaxed, back arched back instead of forward, legs stretched out a bit more, both left hand and feet bent to make contact with the surface, and right hand's wrist wresting on right knee.
I use the surface grid and a good amount of camera rotation to get parts in contact with the surface properly but some people prefer making a surface plane at ground level. With the grid one wants to go into a front/side view to see what drops below the grid, with plane, one can rotate anywhere below the plane and move items down till they get poke through, then inch it back up.
Edit: on second look, the left shoulder isn't relaxed as much as it's forward a bit also, with the wrist turned to create the hand pose and a slight arch in the arm. (The arm arch I'm not sure one could recreate.)
Camera movement and zooming in/out are critical in posing. Hopefully everyone is familiar with the [+] to zoom in to/center rotation around selected area. That little button is your friend ;)
Also, if we find ourself going back to a specific area/angle(s) a lot, it helps to create a camera(s) there to be able to quickly jump back and forth between that area and our default camera.
I only mention this because these are things I learned the hard way. Through much trial and error.
Here's an interesting one I thought I'd try, but upon trying it I found Genesis wouldn't bend that way without distorting. I'm curious if anyone can duplicate this pose without modifying the basic shape of the legs, back etc..
AtticAnne get a Plane chucked in there to help with getting the legs right, You can always delete that plane later.
Okay Gedd has some good points. So I'll put them in easy DS terms, I hope. For posing, to get CLOSE and work on your the part you need try this.
Make your Main Camera, the one you will Render from. LOCK it or remember you NEVER move it. Now select the part you wish to edit, go to your Perspective Camera and ZOOM in and move around untill your good and can Do your pose work. If you like Create a NEW camera and Name it Hand Work ect.. Use current camera view when you create the new camera. Go back to your Main Camera and check your work. You can do this as many thimes as you need.
Just remember the RENDER camera never moves.
And that is one problem with using a drawing as a reference. The original artist likely had taken "artistic licence" and modified the proportions of the figure until it "looks" proper but actually isn't.
Yes, that's the conclusion I had reached also but thought It made for a good discussion point. Plus it's always good to throw something out there like that since someone might have some tricks we aren't familiar with :)
Ok, figured if I was going to comment I should post something since I have the time at the moment.
Btw, this wasn't as easy as it looks. I had to resculpt the entire character, especially the face, change body proportions, turning off limits in a few cases etc..
This doesn't apply to the contest but thought I'd mention for anyone interested. The skin was a highly customized version of Zoey with color change, specular, gloss etc.. adjustments to give the 'airbrushed' look. The post work was confined mostly to contrast and saturation boost.
Muscle work looks great, it really helps sell the pose I think. Now tilt his head down so he's looking at the creature coming up from behind and get that smile off his face ;p
Thanks! I should have another draft ready sometime later today.
The entries that have been posted to the contest thread so far are very impressive! Looking forward to seeing these other WIP's completed...
Finer means finer detail like the grip of the hand but these should be done at the end of the posing.
Ayden, don't get discouraged. You picked a very challenging pose but anyone would learn a lot doing this pose. I plan on trying it when I have the time. Not to enter into contest ofc, but because it is such a good pose for practice and learning :)
Btw Anne, If you find getting the back arch correct is challenging, I have a method I've found works for me. I start at the Hip & Pelvis, get that angle correct (quite a bit of bend here it looks like.) Then I pivot the whole genesis character to get it back into basic alignment. I might go back and forth a couple times here to get it right, ignoring the legs, abdomen and chest. After that looks right, I work my way up the abdomen and chest to get the form, and out the legs, sometimes going back and tweeking the pelvis.
Also, to make this easier I have the 'scene' tab on the right side of my window setup and the 'parameters' (and surfaces) tab on the left to make it easier to select then adjust quickly. I will select an item in the view window then if necessary fine tune the selection in the scene tab. Then on the left I can adjust parameters and surfaces.
I managed to get Genesis like this without distortion.
I tried you’re pose , Not for the contest.
I cheated with genesis v4 I used a little bit gen basic child.;-)
I did not used out of limit.
AydenShade keep going you can do it.:)
v'n, did you use base genesis or a custom char? Oh... another thing, does it look good from all camera angles or that one? I found I could do some poses with a given camera angle but it would be distorted in others. This isn't a problem ofc for a single piece, just that I go into automatic mode sometimes trying to make it fit all camera angles and that might be overkill at times ;)
I used Genesis with V4 shape and it looks OK from all angles. I did have limits off as well.
Nice :)
Looking at your image it does point out another complication, doing the hair without dynamic hair. Hair would almost definitely need post work. It's pretty creative that you could come up with some that move in that direction... guessing a 'wind' morph on the hair?
Oh! Mec4D... if you see this post, what are the chances of getting morphs for your hair for different body angles?
Genesis v4, limits are all on.
Hi gang-
There seems to be some great thing going on here. Just wanted to post my preliminary poses and get some feedback. I have never actually completed a project using Daz, so this will be interesting.
The general idea here it to bock in the main poses then go back and refine them. Does anyone know if I can save the facial expression as just a pose for the face?
I really hate to do this to a new user, but
Please replace your images with untextured figures, as others have done, the basic grey genesis.
Wow sasje that is some might fine posing there...got the weight perfect.
And people don't forget when posing think about gravity. Posing the figure's body and limbs are only part of the process to get better results. Breast movement, clothing hanging and hair dangling. Clothing and hair can be difficult to get right due to the limitations of the movement morphs some clothes and hair have. The image below is an example of using to hair products to make one hair, took a lot to figure out but it is possible to fake it by hiding some of the hair's surfaces but now we have the Polygon Editor in DS4 which enables us to hide polygons but we can come to that later. If you are interested this thread http://www.daz3d.com/forums/discussion/3967/#50076 has some good advice on use the PGE (polygon Editor)
Another way is to use postwork but again it requires some skill which Idon't have. :) You might though.
Can you find what is wrong with this image below. I look at it now and see it plain as day but when I made it last year I didn't see it at all.
To me the issue with the above image is that the man's feet are not firmly and flat on the ground. Even if you assume the woman is a 98 pound weakling, that's still 98 pounds of added weight. I suppose the other issue could be that the man's bangs don't look quite right.
Did I win? ;-)
If you mean bangs as in the hair, yes. His right leg is taking all the wait and his right foot is firmly flat and Colliding with the floor. I have seen men lift women like this with one foot like his left. But it is the balance I am mainly referring to. The right leg and foot should be 100% under the wrist which is the point of the weight. Not by much but it is enough to throw the balance off.
LOL Humm maybe a bonus prize. :)
