Render Questions
Good afternoon,
My name is Roberto and I'm inexperienced, to say the least. I would like to ask you a few questions about rendering in Daz Studio. I don't have a particularly powerful PC, an I5 with 32gb Ram and an Nvidia 1050. I noticed that to make even the most trivial render my computer takes forever. I thought of creating one or more PCs to use as render nodes. (I saw some interesting proposals with Opteron) but (apart from the economic issue) I would like to understand if and how much the thing would change. (in the past I had experiences with the Poser, but the renderings seemed to me much faster. Ok maybe the quality wasn't the same, but at least I could do some renderings.) Can you help me?
Thank you
  • How much RAM does the 1050 have? It may just be running out, in whichc ase a better GPU with more memory might help. It's also possible that you simply need to update the driver (DS 4.12.0.86 needs an nVidia driver 430.86 or later - right-click on the desktop and select nVidia Control Panel to see the driver version). If you are using a system with an Intel GPU on the CPU it may also be that DS is set to use that, which won't help with rendering - again, the nVidia Control panel shoudl help with this and then check the Advanced tab of the Render Settings pane in DS to make sure that the nVidia GPU is checked).
  • Catherine3678abCatherine3678ab Posts: 674
    edited October 16
    Do we leave the CPU checked as well?
    709 x 682 - 31K
    Post edited by Catherine3678ab on
    I've seen credible advice that having both checked can actually slow things down, presumably because the CPU needs to manage the different devices. I suspect it might be system dependent, but if speed is of the essence I'd do some tests with CPU on and off in successive renders of a test scene or two and see how they compare.
  • Thank you. I'll try unchecking the CPU then because yes, on the longer renders things do seem to slow down and the fans go nuts.
  • My Nvidia 1050 has 4Gb Ram DDR5, I will try to leave checked one of them and try to find the best solution.
    Thank you, I will post the result ;)
