Star Trek Builders Unite 4 : In a Runtime Darkly!
1…4445464749
  • shadowhawk1shadowhawk1 Posts: 2,211
    Any idea on what you are going to use for a hair prop yet? Really curious to see how you finish this one off.
  • GRFK DSGN UnlimitedGRFK DSGN Unlimited Posts: 1,129
    Really hadnt thought bout that. I was going to try my hand at modeling the ridge rings.
    David
    I am looking forward to seeing how this progresses. Is this for a personal progect or something you are going to give out as a freebie?
    It was a personal project to see if I could do it. The morph I can make it a freebie. The texture was a modified Daz product. The ridge rings are next on the agenda.
  • TimbalesTimbales Posts: 2,456
    edited December 2013
    I haven't done a Star Trek render in awhile. I've been feeling a bit creatively empty lately.
    One of the things that never quite jived with me on some of the ships is the warp nacelles without a secondary hull. The secondary hull is where the warp engines and engineering exist, so it seems odd to have warp nacelles with nothing powering them.
    I did my own kit-bash for a Ptolemy class, adding a secondary hull and using the Crossbow configuration for the nacelles.
    800 x 450 - 216K
    800 x 450 - 216K
    Post edited by Timbales on
  • jaguarry3jaguarry3 Posts: 230
    Been doing some more work on my ringship . Converted it to a figure and added a bone so that the ring can be rotated flat . Useful when entering a space dock or station
    961 x 832 - 23K
    961 x 832 - 23K
    961 x 832 - 20K
    961 x 832 - 30K
    961 x 832 - 37K
    I like the Crossbow warp nacelles on this ship it gives it a more well thought out design appearance to it, and with the secondary hull mounted via a dorsal neck really makes this ship look tons better.
    Great idea Jag, looks like it would also work well for more stealthy missions as well. The retracted warp ring really gives this ship a sleek profile.
    very cool
    thanks!
    It's official. The first issue of my comic, The Final Frontier, is for sale on Amazon! If you want the link, please PM me or drop me an email ([email protected]).
    David
    David
    Congrats David! Glad to see your hard work and skills are paying off!
    Thanks! Hope I sell lots and lots of issues.
    Here's an update to the Klingon. Attempting to model the Ridge Rings.
    David
    1429 x 2000 - 2M
    David
    congrats!
    Klingon ridge rings again. This time rendered in Carrara 8
    David
    1429 x 2000 - 884K
    thanks glad you like her
  • edited December 1969
    Hey guys, I've run into a problem and, maybe, someone here can help me.
    I've been running Poser 8 now for a couple of years. The other day, I started it and the library window won't load. It's not "blank" with the background color. It's white and when I put my cursor over it I get the icon like it's loading. But, it never loads. It just stays like that.
    I've tried all the "fixes" that were recommended. All my Windows and Adobe Flash files are up to date. My LAN connection is fine. I even deleted the Poser preference file. Nothing. Nada. The library still won't load.
    Any suggestions? Anyone? ...Buehler? ...Buehler?
  • fixmypcmikefixmypcmike Posts: 19,733
    IE11 breaks Poser. Smith Micro has patches for P9 and up, but for P8 your only option is to revert to IE10.
    MS has even issued a fix to help you, it stops auto update updating IE to IE 11
    http://www.microsoft.com/en-gb/download/details.aspx?id=40722
  • wsterdanwsterdan Posts: 3,620
    David
    Just bought it, congrats!
    Have you considered selling it on http://www.comixology.com as well? They have their Indie Submit program up and running.
    -- Walt Sterdan
    Post edited by wsterdan on
    fixmypcmike and chohole, thank you. It worked.
    I owe you dudes!
    Hey, maybe you guys could help me with this one, too, as DAZ's tech support seems to be ignoring my request.
    I recently bought the Muscle Morphs for Victoria 4, but, they don't seem to be loading into the figure. I've tried injecting them into previously saved V4 characters and nothing. I've opened a new file, brought V4.2 over from the Characters>DazPeople folder, injected the Morphs+++, then tried to inject the morphs and still nothing. The only evidence it did anything was under "deformers" in V4's body directory ("Wirey" replaces "Strength"). If I try to inject the muscle morphs individually, they just replace whatever morph was in "deformers".
    Any takers on this problem?
  • adamr001adamr001 Posts: 1,322
    Sounds like V4 didn't get initialized after the install of Muscle Morphs. in the runtime where V4 is installed browse to ~\runtime\libraries\!DAZ\ and you should find a "DzCreateExPFiles-V4.bat" . You need to run that. This shouldn't be necessary with DIM installs though.
  • blutobluto Posts: 916
    ok ,guys , as some of you may know ive upgraded to poser 9 a couple of months ago .
    I was kinda jazzed about it as it means I can play around with the genesis figure .
    well im lost, after months of fighting dson importer and genesis I thought I finally got it to work.
    I no longer get any error messages at startup ,
    poser says genesis is loaded into the librarys.
    so when I click the button to load genesis into my render scene .... it loads nothing
    I don't get it the editer says its there but the window looks void of any figure .
    any ideas ???
  • Richard HaseltineRichard Haseltine Posts: 111,760
    An empty figure usually means that the core files were not installed, or were not installed to the right place. You should have a folder named Data alongside the folder named Runtime in the library you are using - the Data folder in turn should hold the \DAZ 3D\Genesis folder.
    I gotta say that this forum ROCKS!
    I have a problem that I'm losing my mind over for days, and you guys solve it in hours! Now, I've got a Poser 8 that's working properly and muscle morphs for my V4 figure.
    My thanks to you all.
    ok , do need to use the daz files ?
    because the poser ones don't have a data file with the runtime
    You need to install the DSON Core files (e.g. Genesis 2 Female Starter Essentials) as well as the Poser Companion FIles (e.g. Genesis 2 Female Starter Essentials PoserCF).
    that seems to have done the trick , thank everyone
    Hey everyone,
    It is getting really close to a starting a new thread so here are the ideas for a new thread title, any idea on who is taking the thread for the next round?
    Where no pixel has gone before
    The trouble with textures
    The Renders of Triskelion
    By Any Other Render
    And the Render Shall Lead
    All Our Renders
    For the World Is Hollow and I Have Touched the 3d Sky
    For the Render is Hollow and I Have Touched the Mouse
    The Naked Render
    What Are Little Renders Made Of?
    The Render Trap
    The Render of Terror
