Adding to Cart…
Highlights:
https://www.daz3d.com/forums/discussion/comment/4937121/#Comment_4937121
Where can I get DAZ 4.12 beta?
I tried
https://www.daz3d.com/daz-studio-beta
but don't see it.
Okay, here's my instructions from a previous post:
*This was added since the original post.
Would 4.12 even still be available as a beta now that it's the general release?
Yes.
Recently Daz has been updating the Public Build to match the General Release, when there isn't a newer version, so that people have the option to try it out before replacing the previous build.
that is exactly my intention.
@L'Adair
Thank you for the instructions. I only read & tried the description at the link and missed the buying of the beta.
Well, I'm trying out the beta, but keeping a copy of the old beta files.
... Cause, well software. :)
Beta and General Release do not seem to be exactly the same right now. Beta is 4.12.0.85 and General Release is 4.12.0.86.
I believe the differences are minor styling layout changes, rather than functional http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#private_channel (edited after correction by Rob).
I just updated my beta version of Studio to the latest and now I can't seem to make the left pane window smaller by using the yellow highlited line, just bigger, it now is taking up more than a third of my screen. If I orient the tabs along the top of the window I can make it a bit smaller but when I switch the tabs back to the side they are hidden behind the viewport then. Is this a bug or is there some adjustment I need to make in studio? I have never had this happen with any other updates.
Is the Timeline pane docked there? If so remove it (drag it out or close it) and dock it at the bottom or leave it to float, assuming you want it at all.
No I never have the timeline tab open, this left hand pane has the tabs for content library, smart content etc ( not sure of all tabe as I am at work right now) but I am sure I could slide the yellow hilite further to the laft to make that pane narrower before the update
Are there any panes docked to the same location as the viewport? (You'd see one or more tabs at the top, next to the tab for Viewport.)
ETA: Another issue I've seen is when the object listed in the left column of the left pane, (especially in Parameter,) has a long name, I can't resize the column if it means covering up part of the name. Could that be what's going on?
In the current version? http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#4_12_0_75
I have attached a screen shot of my Studio window with the yellow hilited side showing .. i can't move it to the left any farther than it is to make that pane smaller and I am sure I could prior to updating the Beta. I tried with the timeline tab open and closed since Richard mentioned it and it didn't make any difference.
This screenshot shows that you DO have the Timeline pane open. It is at the very bottom of the screenshot on the left. I don't know if that is causing your problem. though, since it doesn't appear to be part of that pane group on the left. Since you don't use it, you could close it and see if that helps.
@barbult Yes this screen shot shoes the timeline tab, I had tried with it open and closed but same result. I also hadn't made any changes to my studio layout prior to or after updating that I know of so I thought maybe I clicked something without realizing to cause this to happen now
Can i install beta if i'm using 4.8 daz studio?
I heard that you changed CMS since 4.9 so i wonder if i'll have to do additional library or smth
You should be OK - I still run DS 4.6.3.52 as my "standard" version alongside the DS4.11.0.383 Beta, sharing the CMS databses and have found no problems. (I wanted to keep DS4.6 for various reasons, so I've just been using Betas since DS4.7 was released)
I assume you are already using PostGreSQL rather than Valentina databases? I think PostgreSQL came in with DS4.6.3 so by DS4.8 it was probably standard?
Oh, one thing: I use DIM to install everything, I have never used Connect - there may be a difference there which might cause CMS database problems, I really don't know about that.
Yes, PostgreSQL had been the default for soem time by 4.8 so unless you have Valentina only from a long time back you should be OK. Even if not, you can (barring corruption) convert the database to PostgreSQL and use that in both 4.8 and 4.12.
I suggest you read the first post here carefully before starting: https://www.daz3d.com/forums/discussion/353851/daz-studio-4-12-pro-general-release/p1 - I think it applies as much to installing the Beta alongside a very old version as it does to upgrading to the general release.
Rob has added a note that running an older version (pre 4.9.x.x) is ill-advised as there were significant changes made.
@Kharma I have 4.12.0.85 Public Beta. I can move the slider, but there does seem to be a minimum width that I can't go below. I'm just throwing out ideas now:
Where did he do that? Perhaps I ought to read it.
I checked on my install of DS 4.10 and I can definitely make the left docking area alot smaller than in the 4.12 BETA so this must be a problem with my install as it doesn't seem anyone else has mentioned having the same issue?
@barbault thank you so much! I had already tried uninstalling and reinstalling the Beta but that didn't make a difference, so I started as you suggested closing tabs, sure enough as soon as I closed the Figure Setup tab I could resize the pane. thanks a million ... I hope Daz notices what an asset you are in the forums, always helping and offering suggestions!
I miss DAZ 4.10. I have Iray scenes that rendered beautifully on CPU on my little lappy, but those same scenes won't render at all with 4.11 0r 4.12. That doesn't make sense. I'd live to be able to retrograde to 4.10.
Added as in sent a note to the mods.
