Realistic Renders... NOT!! 12 "And we're back in the room!"
1…444546474850»
  • RogerbeeRogerbee Posts: 4,460
    Artini said:
    Could not resist to the Mars Explorers for Genesis 2 Male(s)
    http://www.daz3d.com/mars-explorers-for-genesis-2-male-s
    Nice,
    You should try the glass shader on that visor, you should still get a decent render time if you flag it as primitive hitmode.
    CHEERS!
    Bobvan said:
    I also noticed significantly faster render times using 3DL in some cases but I have even though its not that often had fast Luxrender times
    Nice,
    You should give the Advanced Ambient Light a try and see how you get on with it, that has ways to really cut render times.
    CHEERS!
    the render on the right has nicer shadows. Nevermind the poke-through of the evening gown. I have trouble posing long dresses.
    For the second render, I used the image based lighting from Andrea. The IBL is faster than the Uber area light.
    Which figure did you use in the second render? If it's Genesis I can highly recommend Poke-Away, they updated it for G2 recently as well.
    CHEERS!
    Hi folks,
    I couldn't risk us getting to P100 with me AWOL, so, I've started a new 'RR....NOT!!" thread:
    http://www.daz3d.com/forums/discussion/32848/
    So, if you guys have anything new to share, please post it there
    CHEERS!
