CAR AND BIKE LOVERS THREAD - MARK IV
1929394959698»
  • hacsarthacsart Posts: 2,037
    Good save GL.. looks good..
    edited August 2019
    Left or right? smiley
    1680 x 1050 - 1M
    Post edited by hacsart on
  • DanaTADanaTA Posts: 13,382
    Nice!  Both impressive, but I think I prefer the style of the one on the right.
    Dana
  • Robert FreiseRobert Freise Posts: 4,678
    Left for Sunday go to meeting Right for Friday and Saturday night
  • GLWoodardGLWoodard Posts: 3,335
    Why are there Model A wheels on the Duece?
  • SaphirewildSaphirewild Posts: 6,729
    I was wondering the same thing indecision
    There has to be some proper wheels somewhere, the spare tire wells seem to be containing the right wheels!
    edited August 2019
    Mesh came without wheels.. those were the closest I could find... The spare wheel mesh couldn't easliy be broken out to separate components...
    hacsart said:
    Sadly, that;s the way the mesh was done, and I couldn't  get the spare wheel mesh broken out...
    GLWoodard said:
    why are there Model A wheels on the Duece?
    You could probably use the wheels off of the 3D Classics 32 Ford, if of course, you have that one!
    https://www.renderosity.com/mod/bcs/ford-b400-1932---extended-license/119438/
    Unfortunately, I wasn't able to locate the Poser version, which would be much less expensive than the extended license version, but EL version will work with any software that opens obj's.
    Trying a different approach to bust out the rim form the spare wheel..  stay tuned..
    Waits impaiently giggles!!
    edited August 2019
    Ok.. used a break faces instead of a break geometry...  the spare wheel object has more to it than juts the wheel, lots of fender and other bits.. So I deleted everything that wasn't the rim.. and exported to an obj.. and then used one of the 3d Classic tires scaled to fit the imported wheel.
    This better? only downside so far, is that If I change the color of the wheel , I can;t change the color of the spare wheel rim/s[pokes to match, not without more surgery..
    1680 x 1050 - 1M
    Looks good to me
    edited August 2019
    I'll bet this one looks more proper for a 32 Ford!
    1860 x 881 - 585K
    Post edited by GLWoodard on
    Actually it does look a lot better with the proper wheels attached, I know in real life, the bolt pattern was the same for both the Model and the 32 Ford's, so the wheels would interchange, what gets me is these so called artists who make this content often don't seem to think accuracy is important, but then again, history was probably never their strong point, so historical accuracy probably isn't either!
    BTW, where did you get the coupe?
    edited August 2019
    Can;t remember off hand... I'll see if I can find out...
  • RurisRuris Posts: 123
    edited September 2019
    Hi friends,
    Hope I can join you guys here.
    Just want to check with you experts, is the car object looking a bit small vs the model? Wiki says the https://en.wikipedia.org/wiki/Apollo_Intensa_Emozione is 1130mm in height.
    Post edited by Chohole on
    Ruris said:
    Hi friends,
    Howdy
    That's just shy of 4 feet high for the car so judgeing by the pic I'd say just a little unless she's over 6 ft tall
    Hi,
    The grid is in metric, yes? 1 box  = 1 meter. Seems close to the specs in wiki. 5m length and 2m width.
    Official Kanade height is 179.9 (thought a doll like model would be smaller, who knows)....so with some heels, thats 190cm I suppose.
    Well, FWIW, an architectural text I have suggests that for modeliing the avergae femal heright is 1.610 meters. So your figure base at 1.79 seems a bit too tall. TRy scaling her so that the roofline on the car is just about waist heiogh, for a start, and go from there..
    I have to agree Having looked at some pictures of the car with people she does appear to be to tall and in the pictures I found where people were standing beside the car the roof line was just slightly above the waist to just below the ribcage
    Post edited by Robert Freise on
    Lisa and Her Hotrod!
    2000 x 1000 - 523K
    Nice!
    Tudor!
    1680 x 1050 - 1M
  • Tramp GraphicsTramp Graphics Posts: 2,423
    That just means that she's "above average". Nothing wrong with that. cheeky
    New thread https://www.daz3d.com/forums/discussion/349811/car-and-bike-lovers-thread-mark-v
