Adding to Cart…
How well would that translate to v4 or m4?
V4/Harry is in progress. For Poser it is a quite simple process, but I will require some assistance for Studio.
I wouldn't know how to help ... but at least I finally went from DS4.7 to 4.10, lol.
Use Morphloader to import obj
Under edit adjust rigging to figure shape
rightclick the obscure little hamburger menu icon in parameters choose edit mode select the morph
under that menu pick and run ERC freeze
save as asset morph and find it in the list tree that pops up and tick it
you can share the dsf file created in the data folder under your name
Morphloader Pro or Advanced? If the scaling is ok for Poser, will it be ok for Studio? I exported with factor 100 from Poser und imported with 0.01 from Hexagon (damn scaling bug!).
I will try it later, thank you!
Doesn’t matter but yes choose Poser scale if obj is
Oh and do this on the duf file not the Poser format
Thank you for doing this Hemi.
The problem is, that the morph files only work on the poser format. On the duf file I get a "Vertex count mismatch in Morph Loader". I tested morph loader advanced and pro in base and high resolution, the meshes of poser and studio version look identical.
So it will work in Daz but under the poser content tab?
Oh dear now then I can’t help
No, the poser pmd file won't inject in DAZ and the other method doesn't work on the poser model. I will not do the process of morphing again on what appears to be the same mesh. I cannot see any difference and am pretty frustrated at the moment.
Edit:Maybe I found a way, will check it tomorrow.Uhm ... I this one is very outdated (DS 4.6), used Dawn and I never uploaded it on Sharecg ... but maybe it still works?
http://www.mediafire.com/file/w31lg0rpmdr5ogc/PMDInjectionToDazStudioMorphMorphLoaderPro.pdf
Thank you for your ssistance, but I think I found a workflow.
I tried opening the Poser cr2 with the morph applied in Studio (only the horse). Then I switched it to Triax Weight mapping. I loaded the DS version of Harry, switched it to base resolution and tried to transfer the morph with the transfer utility (only the morph). But then Studio crashed every time I tried.
So I exported the shape of the cr2 horse as OBJ with DAZ scaling and used this with morph loader pro on the DAZ version. This worked! If I save the morph as asset, it can be distributed, right?
Proof of concept, V4 left, G8 right:
Yes the duf morph is able to be redistributed
just set up a matching data folder structure with the dsf in it
Hemi those look great. Will it also work on Gen 3 ?
Yes, as Genesis 8 and 3 have the same base mesh. But you'll need the Genesis 8 Female Body Morphs res. the G3 Version.
This is looking awesome ... I'm all over the v4/harry centaur. Will you be doing m4 and k4 versions, too?
I'm super-excited about this as a possibility for me. Is the v4/m4 going to be an available product somewhere? If LAMH could also be incorporated, I'd pay lots of money for the combo.
Keep in mind that this is not a professional product and it will be free. So it has it's limitations.Horse poses that bend, twist oder side-side the neck2 will result in poke through but by resetting these dials this can be compensated. The same will happen for poses that affect the lower body of the human figure.
Here's a WIP (Victoria 4.2 on HiveWire Horse).
Very exciting, all the same :)
I just uploaded the DAZ Version on DeviantArt
https://www.deviantart.com/hemi-426/art/HiveWire-Centaur-Morphs-DAZ-806017485
Woohoo! Can't wait till I have time to play with it. If someone gifted you with the k4 morphs, so you could create a k4/harrry foal model, what exactly would you need?
Nice!!!! Great image overall and I am really loving how the "Harry" part looks! Great job!
Your harry centaur looks so natural :)
Great image!
Good to see you back! I have been using your old versions forever since i hate the hight transition between horse and figure on the official DAZ centaur.
Looking forward to anything new you come up with for the newer figure!
