Locking objects?
Is there a way to lock objects in Carrara so you can't accidentally select and move them?
(or so you can select items underneath or behind them?)
thanks
thanks
Hi,
you could lock it by this way.
Use LOCK under the constraints tab instead of FULL
Or, if you have overlapping objects, RIGHT CLICK the mouse in the vicinity and it will give you a list of Objects to select from.
Or, if you know the name of the object you want to select, click on its name in the Scene Instance List.
Or, Click the hide unselected button at the top right of the viewport and then move down the instance list until you find the object you want.
How can this be done in Daz???
I find it easiest to just tick off their visibility.
They then can't be selected by mistake and everything behind them is in plain sight.
Even better!
Not that I would ever forget to turn something's visibility back on...
Nope.
Not me...
