And now, for some kinda-sorta "freebies" of my own...
To get the "caveman" skintone, load G8M base mats and adjust following parameters:
Base Color: 0.729919 / 0.535642 / 0.415148
Translucency Color: 0.632043 / 0.442323 / 0.329729
Transmitted Color: 0.789314 / 0.470440 / 0.329729
To get the "caveman" green eyes, load G8M base mats and adjust following parameter for only the iris:
Base Color: 0.715465 / 0.560499 / 0.0938759
To get the "cowboy" skintone, load G8M base mats and adjust following parameters:
Base Color: 0.915750 / 0.638779 / 0.442323
Translucency Color: 0.867136 / 0.605484 / 0.453456
To get the "Cowboy" blond hair, load the "Wild Mane" hair and adjust following parameter:
Diffuse Color: 232 / 193 / 128
To get the "kinkster" skintone, load G8M base mats and adjust following parameters:
Base Color: 0.744530 / 0.744530 / 0.744530
Translucency Color: 0.867136 / 0.529523 / 0.288816
Transmitted Color: 0.680020 / 0.373615 / 0.223310
(All other skintones and eyes were adjusted in Photoshop, so I'm afraid I can't share them...)
If you follow on from that link it appears that celery is not de rigeur, so you're okay there. In fact I had no idea what a 'frahm' was (I was thinking saucy seaside postcards), and Google didn't help me - it kept pushing Nils Frahm. So thanks for enlightening us with Art's art. I even discovered that I'd inadvertantly plagiarized (is that possible* ? ;o) one of his pictures...
*plagiarism is, I think, by definition non-inadvertant
Thought it might still be of interest because I am working on producing a free set inspired by some vacation ads I've been getting. I modeled the landscape, hot tub, plants fence, etc. Have to get better with UltraScatter to finish the Studio version, but here is Vicky with Hongyu bikini in a Carrara WIP.
Oh no, it is even worse! There appear to be 4, count them 4, legs. That is because both refraction and reflection were poorly applied by me.
Saphire - thanks for the nice comment - even though I've made a few of the Carrara plants available separately as freebies, not enough to qualify for the challenge.
Not an entry yet...only 4 freebies !
Dollie was originally going to be your standard WW2 military type pinup - but then by a stange twist of fate involving hats...
Ah!! give her one of these http://xfrog.com/product/FL17.html to put in her mouth and then you will have 5! besides I think that hair color is not in the base file for little ol' F202 Dollie. But I could be wrong. And is that not our very own Apollo gracing the side of the plane? I recognize that short skirt anywhere.
I thought you'd linked to a freebie cigar (which made me think "she needs aviator sunglasses too").
Until I saw that telltale 'xfrog' in the URL.
But I definitely see Dollie here more as a cigar and sunglasses (and bottle of bourbon) type of gal.
However, I also see her as the kind of gal who'd perhaps have her mascot with a rose clenched between his teeth - and yes, he is indeed Apollo
Dollie's hair colour was just a bit of manual tinkering, so not a freebie. But the sky and lighting is my own worldball freebie - although I think it's not really in the spirit of the contest to use that as one of the 5 freebies ?
The plane can't be used as a countable freebie in this contest as it's no longer free (or even available?): Edit thanks to DollyGirl, here's a link - it's still a freebie ! http://www.colacola.se/expo_f4u.htm.
- F4U Corsair (by Bazze) as "Big Willy" - picked up from Content Paradise back in Dec 2012, 99% certain it was a freebie.
But there are plenty of great freebie planes (e.g. by NeilWilson at ShareCG) that I could use instead... e.g. the same plane - https://sharecg.com/v/83492/gallery/5/3D-Model/Vought-F4-U-Corsair..
Dollies skin (I used the V3 remap version) is V3 Anna (I think? Which was a freebie, although I can't recall from where, so also not a countable freebie)
P.S. The plane (and mascot) were an afterthought after I changed her headgear from a standard helmet (which apparently can't actually be used - anywhere!) to a peaked cap:
I tweaked a bunch of materials and the pose. Used whatever the default Iray light is, just played with the settings a bit (like rotation, etc.). All done within Daz Studio. No post work except for the watermark.
Your most welcome Pete. I think I found your first Corsair. It is here: http://www.colacola.se/expo_f4u.htm. Glaseye had it listed at PoserDAZFreebies. That rose sure looks good and Dollie, she is one bad a** girl. Everyone has done such a good job. It is fun coming in here and seeing where y'all get your freebies. Thank you.
All Links Check Out Plz Move To Entries Thread
Little Morticia gives an "I know something that you don't" type* snigger...
Little Morticia raises an eyebrow, smiles sweetly, and chuckles...
It's that classic pinup girl, Lucy Lastic !
*Don't ask me - I don't know what it is.
I apologize for the ommission of celery. https://www.lileks.com/institute/frahm/index.html
Hi,
Here my entry (no postwork) :
Freebies :
[Elf Girl Textures for Genesis 8 Female by KnochenKater] https://sharecg.com/v/88556/gallery/21/DAZ-Studio/Elf-Girl-Textures-for-Genesis-8-Female
[Side Swept ROse Hair for Genesis 3 & 8 Females by zoro_d] https://www.renderosity.com/mod/bcs/side-swept-rose-hair-for-genesis-3-8-females/126602
[G2F Shorts & Tied Top (Top only) by Wilmaps] https://www.wilmapsdigitalcreations.co.uk/view_product.php?id=185
[Pleated Skirt for G8F by Digidotz] http://www.digi-dotz.com/index.php/free-poses/daz-clothes/233-free-pleated-skirt-for-daz-g8f
[HDR Evening Sun by Giantcow] https://giantcowfilms.com/2015/12/01/hdr-evening-sun/
[Ajrarn's BackProp by Ajrarn] https://www.renderosity.com/mod/gallery/ajrarns-backprop-available-in-freestuff-/901938/?p
[Background Image by dbWalton] https://www.renderosity.com/mod/freestuff/standing-on-a-corner-in-galena-kansas-hires/82518
Purchased :
[Morph and smile] https://www.daz3d.com/amira-hd--expressions-hd-for-genesis-8-female
No count : G8F
P.S. How do we know everything is ok so we can post in the entry thread?
Saphirewild, who is currently running the contest, will let you know in this thread.
Thank you!
First time entering one of these.
Freebies:
Jewelry Set by Leilana : https://www.renderosity.com/mod/freestuff/jewelry-set/78314
Freebie: ED's Bends V8 Poses by Edheldil (used pose 07 mirror) : https://www.renderosity.com/mod/freestuff/freebie-eds-bends-v8-poses/79710
Side Swept ROse Hair for Genesis 3 & 8 Females by zoro_d : https://www.renderosity.com/mod/bcs/side-swept-rose-hair-for-genesis-3-8-females/126602
Airforce sunglasses by insane_machine : https://www.renderosity.com/mod/freestuff/?item_id=64123
Genesis 8 female dForce Shirt : https://www.most-digital-creations.com/g8f_shirt.php (requires newsletter email subscription)
11 Free High Resolution Fabric Textures (used fabric 1 for the towel) : http://www.premiumpixels.com/freebies/11-free-high-resolution-fabric-textures/
No Counts:
String Bikini for Victoria 6 (included with Studio 4.x) : https://www.daz3d.com/string-bikini-for-victoria-6
DAZ Studio Iray HDR Outdoor Environments (included with Studio 4.x) : https://www.daz3d.com/daz-studio-iray-hdr-outdoor-environments
Purchased Items:
P3D Mylou for Genesis 8 Female (used her skin) : https://www.daz3d.com/p3d-mylou-for-genesis-8-female
Constanza HD For Genesis 8 Female (used body and head morph) : https://www.daz3d.com/constanza-hd-for-genesis-8-female
Beach Props (was free at some point, used the deck chair and drink) : https://www.daz3d.com/beach-props
Deck Accessories (also got it free sometime, possibly christmas, I used the table with umbrella) : https://www.daz3d.com/deck-accessories
Welcome aboard - am enjoying your entry, and am looking forward to more.
Post Apocalyptic Pin-Up
Acindina- https://www.sharecg.com/v/91300/gallery/21/DAZ-Studio/Acindina-for-G8F-Dress
Hair- https://www.renderosity.com/mod/freestuff/dforce-french-twist-hair-for-genesis-8-female-s-/81937
Lounger- https://sharecg.com/v/90585/related/5/3D-Model/Four-Sun-Lounger-UPDATE
Swimsuit- https://www.wilmapsdigitalcreations.co.uk/view_product.php?id=396
Beer Can (retexured in Gimp)- http://trekkiegrrrl.dk/mpp4.htm
Slurm Background- https://www.deviantart.com/deviantartspeedfreak/art/Futurama-Slurm-Wallpaper-276807878
Render scene using above. Used Python to create a noise map which I used as a cutout opacity map on no count plane textured with
Brick texture/bump, beer crate, traffic cones, and trash bag https://sfman.deviantart.com/art/Free-for-DAZ-Urban-Streets-Of-Tomorrow-by-sfman-723531345
Truck & Rubble- http://www.sharecg.com/v/79785/gallery/5/3D-Model/Old-pickup-and-rubble
Not an Entry
^ uhhhhh... she appears to have a third leg
You very talented to do all that in Carrara!!
I wish you have entred it though
if anyone is intrested in some of the free plants, see https://www.sharecg.com/diomede
Yikes ! Shades of Uxia Cambarro, ( from the movie Dagon* ) - although she only had two legs tentacles.
I do hope that the hot tub isn't bottomless.
*Warning! For those of a delicate disposition - you really don't want to know more...
Preparing for Summer RPG Sessions
Vivid Skies (freebie from DS Creative Magazine) http://4eyes.code66.se/dsc/SkyBGFreebie.zip
Graca V4, she looks much better on thumbnail https://www.renderosity.com/mod/freestuff/graca-v4/79744
House (4th row, 2nd column) https://web.archive.org/web/20050204022611/http://www.sams3d.com/Freebies.htm
Rattan Chair https://elleque.net/?p=3626
Coffee Table http://freezone.thefantasiesattic.net/index.php?main_page=product_info&cPath=138_141&products_id=486
Paid:
Alana Hair (I thought this one was freebie) http://www.most-digital-creations.com/alana_hair.htm
Lilian Bikini https://www.daz3d.com/lilianbikini-for-victoria-4-and-aiko-4
pw Toon Shaders https://www.daz3d.com/pwtoon
Big Willy Ain't No Pilot - He's My Bird !
The four freebies I'd counted are:
- F202 Dollie - https://sites.google.com/site/mdp6gdl/ ...see also https://poserdazfreebies.miraheze.org/wiki/F202_Dollie
- Cosplay for F202 Dollie (by EvilInnocence) - https://www.evilinnocence.com/shop/cosplay-for-f202-dollie.html
- WWII Pilot hat (by Lucien_Lilippe) - https://sharecg.com/v/81526/gallery/5/3D-Model/WWII-Pilot-hat ...OBJ format
- Apollo Maximus (with grass skirt, toon hair, and toon skin) as "Big Willy" mascot
Almost Human
Wanted to try something simple but striking. Not sure if I succeeded, but I think it's a nice pinup, at least!
Freebies:
Sirine - https://sharecg.com/v/89913/browse/21/DAZ-Studio/SIRINE-for-G8F
Android G8 - https://www.deviantart.com/mysticartdesign/art/MysticArtDesign-Android-759619113
MDC G8F Swimsuit - https://www.most-digital-creations.com/g8f_swimsuit.php
Arah3D Winter Goddess (Necklace) - http://thefantasiesattic.net/xmas/2018/index.html (Day 7)
Arki Striga Earrings - https://www.deviantart.com/aarki/art/Striga-Earrings-737489099
Daz Studio Posing Scripts (Look At Camera Script) - https://sharecg.com/v/76667/favorite/8/Script/Updated-Daz-Studio-Posing-Scripts-now-for-G3F
Side Swept Rose Hair - https://www.renderosity.com/mod/freestuff/side-swept-rose-hair-g3f-g8f-part-1/79533, https://www.renderosity.com/mod/freestuff/side-swept-rose-hair-g3f-g8f-
No Count:
Plane Primative (background)
Iray Uber Base Shader (for conversions)
Paid:
Shades of Blue Poses - https://www.daz3d.com/shades-of-blue-poses-for-genesis-8-female-and-victoria-8
Genesis SuperSuit (shader for background) - https://www.daz3d.com/genesis-supersuit
Entrified.
(and thanks DollyGirl for that wonderful inspirational nudge...)
No, I'm The Pilot, Li'l Jilly ... Big Willy's My Bird !
FREEBIES:
- Vought F4-U Corsair..(by Neil Wilson) - https://sharecg.com/v/83492/gallery/5/3D-Model/Vought-F4-U-Corsair.
- Universal Sunglasses (by Slosh) - https://www.sharecg.com/v/68727/related/11/Poser/Universal-Sunglasses
- Smoking V4 - Cigarette SmartProp (by 3-d-c) - https://www.sharecg.com/v/33769/related/11/Poser/Smoking-V4-Cigarette-SmartProp
- Apollo Maximus (with grass skirt, toon hair, and toon skin) as "Big Willy" mascot - https://adh3d.com/apollo.html
- Red Rose (XFrog) - http://xfrog.com/product/FL17.html
- my own environment/lighting set - http://www.sharecg.com/v/69798/gallery/15/2D-Resources/Above-The-Clouds-WorldBall-Environment-Set
( Edit: link to the corresponding post in the entries thread )
Keeping you busy aren't we Saphire!
