My WIPS, renders and animations :)
1171820222327
  • akmerlowakmerlow Posts: 1,124
    Fishtales said:
    Mirror, Mirror
    2019-02-07 22:08:12.472 Total Rendering Time: 1 hours 3 minutes 13.22 seconds
    Click on image for full size.
    2019-02-07 20:38:42.690 Total Rendering Time: 46 minutes 20.73 seconds
    910
    So that's how her soul looks? Scary crying
    Fishtales said:
    Mech War
    2019-04-01 11:59:00.393 Total Rendering Time: 2 days 2 hours 46 minutes 41.68 seconds
    293
    Mecha for life!
  • FishtalesFishtales Posts: 6,045
    edited May 2019
    Long Way Home
    A Night In The Cemetery
    2019-05-07 08:45:59.494 Total Rendering Time: 23 hours 14 minutes 59.35 seconds
    657
    1920 x 1080 - 1M
    1920 x 1080 - 2M
    Post edited by Fishtales on
    edited June 2019
    At The Harbour
    2019-05-21 06:54:43.309 Total Rendering Time: 21 minutes 7.22 seconds
    2019-05-20 21:37:49.823 Total Rendering Time: 10 minutes 39.70 seconds
    696
    1000 x 1618 - 660K
    1920 x 1080 - 891K
    edited June 2019
    Seals
    2019-05-24 14:25:38.467 Total Rendering Time: 2 hours 7 minutes 29.20 seconds
    729
    1920 x 1080 - 2M
    edited June 2019
    Hurry up Moose!
    729
    1920 x 1080 - 2M
  • wscottartwscottart Posts: 431
    edited June 2019
    Fishtales said:
    @IceDragonArt
    Go to My Library/Scripts/Utilities/Create Advanced Iray Node Properties. Select the Plane (It is what I used but I suppose it will also work on any primitive) in the Surface Tab and apply the Iray Uber Base and then run the Iray Node script. That adds a new item under Parameters/Display called Enable Iray Matte with an On/Off button and another item called Iray Handle (I have no idea what that is for but it is a text box and I put Shadow in it but didn't see what difference that made :) ). It acts as a Shadow Catcher for items in the scene without Geometry, like in an HDRI, and allows shadows from the figures to be projected onto the HDRI which are vertical to the ground plane or should be above the ground plane, although those horizontal shadows don't show quite as well as the vertical ones. I then moved and resized the planes to fit where I wanted the shadows, that is the fiddly bit :)
    I was going to ask where to find this script, but after creating the post I decided to look in another library on my computer and there it was, now off to go find out how it works.
    Post edited by wscottart on
    edited June 2019
    Here are the videos.
    edited June 2019
    The Canal Boat
    2019-05-28 22:09:44.573 Total Rendering Time: 20 minutes 57.2 seconds
    833
    1920 x 1080 - 2M
    edited June 2019
    A Good Night Inn
    867
    1920 x 1080 - 2M
    edited June 2019
    Rendered these in 4.10 and 4.11 Beta to see what the difference was. Used the same settings for both.The only difference, other than render time, I can see is that 4.11 is slightly lighter, you can see it on the hair if you open both in separate tabs and flick between them. The Beta is the same release number as the full one.
    Dragon Mistress
    2019-06-17 20:16:55.023 Total Rendering Time: 3 days 4 hours 35 minutes 46.41 seconds
    36% done
    Studio.4.11 Beta
    2019-06-14 14:57:30.220 Total Rendering Time: 2 days 46 minutes 33.72 seconds
    36% done
    Studio 4.10
    897
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    edited June 2019
    Storm Cloud
    2019-06-16 13:46:36.218 Total Rendering Time: 3 hours 24 minutes 34.85 seconds
    Studio 4.10
    Buffalo Rain Dance
    2019-06-17 23:46:33.737 Total Rendering Time: 3 hours 7 minutes 8.17 seconds
    Studio 4.10
    923
    1920 x 1080 - 818K
    1920 x 1080 - 840K
    edited July 2019
    Checking Messages
    021
    800 x 980 - 508K
    edited July 2019
    Ascension
    2019-07-22 11:03:51.632 Total Rendering Time: 1 days 13 hours 16 minutes 50.90 seconds
    039
    640 x 800 - 350K
    edited July 2019
    Medieval Fantasy Bedroom
    2019-07-23 10:08:16.997 Total Rendering Time: 19 hours 38 minutes 19.85 seconds
    039
    1920 x 1080 - 1M
  • RakudaRakuda Posts: 931
    edited July 2019
    Fishtales said:
    @Fishtales That is a pretty cool technique with the zombies coming out of the ground. I had no idea it was possible to knock out the ground plane like this. Will have to keep that in the back of my mind for future use.
    plus, great render of the Medieval Fantasy room. That has some amazing textures and detail, haven’t really paid so much attention to my render times. I’m curious now.
    Post edited by Rakuda on
    @Rakuda
    It can be a really handy thing to use in some renders.
    I have done a bit more tweaking and have a new render running just now which is at 94% after 23 hours but looked good long before that, I am just letting it run to see how long it will take before changing more things.
    edited July 2019
    After changing a few things in the bedroom render, and turning off the panel light outside the window, which I didn't realise was there, and turning the distant light/sun back on, I let this next render run. After it had sat at 95% for a long while with nothing looking changed I stopped it.
    2019-07-24 12:42:03.068 Total Rendering Time: 23 hours 26 minutes 46.97 seconds
    95% done
    059
    1920 x 1080 - 1M
    Still working on getting the render time down on the Medieval Fantasy Bedroom and I reckon this is as low as this view will go. I have moved to another camera to see how that renders.
    2019-07-29 11:23:05.152 Total Rendering Time: 14 hours 49 minutes 48.57 seconds
    4.11 Beta
    087
    1920 x 1080 - 2M
    4.11 Beta
    087
    edited August 2019
    Strange one this, although I think I know the problem, the first 50% or so took around three hours and yet look at the finished render time.
    2019-08-04 07:51:45.210 Total Rendering Time: 1 days 21 hours 43 minutes 16.32 seconds
    Studio 4.11
    112
    1920 x 1080 - 1M
    edited August 2019
    Tried to get the render times down but they were all going for a day or more, although they looked good at 10 hours. I added a Dog 8 with LAMH hair to try a new render, all the settings I left the same.
    Beware the Fire Demons
    I was going to stop it at 10 hours but went to bed instead and let it run overnight.
    2019-08-10 09:16:09.236 Total Rendering Time: 20 hours 39.17 seconds
    89% done
    127
    1920 x 1080 - 1M
    edited August 2019
    Added a figure to get some balance. This is Gwenbleiz.
    2019-08-11 12:30:49.175 Total Rendering Time: 16 hours 2 minutes 17.30 seconds
    80% done
    Gwenbleiz
    2019-08-11 22:36:40.634 Total Rendering Time: 7 hours 51 minutes 23.59 seconds
    136
    1920 x 1080 - 2M
    600 x 1200 - 481K
    edited August 2019
    Knights Meeting
    2019-08-13 16:11:10.212 Total Rendering Time: 17 hours 47 minutes 25.17 seconds
    145
    1920 x 1080 - 1M
    edited August 2019
    Should I?
    2019-08-14 16:51:37.693 Total Rendering Time: 2 hours 26 minutes 55.81 seconds
    159
    1920 x 1080 - 2M
    edited August 2019
    The Conquered or the Conquerors?
    201
    1920 x 1080 - 2M
    edited August 2019
    Would You Like Straws With Your Drinks?
    2019-08-31 09:37:09.740 Total Rendering Time: 20 hours 37 minutes 26.37 seconds
    Studio 4.12 Beta
    228
    1920 x 1080 - 2M
    edited September 2019
    The Enemy
    2019-09-01 09:37:01.861 Total Rendering Time: 12 hours 42 minutes 1.20 seconds
    Studio 4.12 Beta.
    250
    1920 x 1080 - 1M
    Came across Muelsfell Modular Path Set which I hadn't tried. I loaded up the default scene Muelsfell Path Back to Hagswood !Promo Scene and started the render. It was going well over nine hours and seemed to have got stuck at 67%. I stopped it and did a few changes that I do on a scene when that happens and added one of my HDR images I made in Bryce, I was only using sun and sky set to night before.
    The result speaks for itself :)
    2019-09-04 23:23:10.183 Total Rendering Time: 1 hours 22 minutes 12.18 seconds
    Studio 4.12 Beta
    273
    An Offering
    2019-09-06 12:52:10.122 Total Rendering Time: 2 hours 58 minutes 4.1 seconds
    Studio 4.12 Beta
    294
    1920 x 1080 - 1M
    Now that was fast!!
    Mergirl
    2019-09-06 16:31:57.452 Total Rendering Time: 14 minutes 38.59 seconds
    Studio 4.12 Beta
    298
    800 x 1000 - 576K
