Go to My Library/Scripts/Utilities/Create Advanced Iray Node Properties. Select the Plane (It is what I used but I suppose it will also work on any primitive) in the Surface Tab and apply the Iray Uber Base and then run the Iray Node script. That adds a new item under Parameters/Display called Enable Iray Matte with an On/Off button and another item called Iray Handle (I have no idea what that is for but it is a text box and I put Shadow in it but didn't see what difference that made :) ). It acts as a Shadow Catcher for items in the scene without Geometry, like in an HDRI, and allows shadows from the figures to be projected onto the HDRI which are vertical to the ground plane or should be above the ground plane, although those horizontal shadows don't show quite as well as the vertical ones. I then moved and resized the planes to fit where I wanted the shadows, that is the fiddly bit :)
I was going to ask where to find this script, but after creating the post I decided to look in another library on my computer and there it was, now off to go find out how it works.
Rendered these in 4.10 and 4.11 Beta to see what the difference was. Used the same settings for both.The only difference, other than render time, I can see is that 4.11 is slightly lighter, you can see it on the hair if you open both in separate tabs and flick between them. The Beta is the same release number as the full one.
Dragon Mistress
2019-06-17 20:16:55.023 Total Rendering Time: 3 days 4 hours 35 minutes 46.41 seconds
36% done
Studio.4.11 Beta
Click on image for full size.
2019-06-14 14:57:30.220 Total Rendering Time: 2 days 46 minutes 33.72 seconds
@Fishtales That is a pretty cool technique with the zombies coming out of the ground. I had no idea it was possible to knock out the ground plane like this. Will have to keep that in the back of my mind for future use.
plus, great render of the Medieval Fantasy room. That has some amazing textures and detail, haven’t really paid so much attention to my render times. I’m curious now.
It can be a really handy thing to use in some renders.
I have done a bit more tweaking and have a new render running just now which is at 94% after 23 hours but looked good long before that, I am just letting it run to see how long it will take before changing more things.
After changing a few things in the bedroom render, and turning off the panel light outside the window, which I didn't realise was there, and turning the distant light/sun back on, I let this next render run. After it had sat at 95% for a long while with nothing looking changed I stopped it.
Still working on getting the render time down on the Medieval Fantasy Bedroom and I reckon this is as low as this view will go. I have moved to another camera to see how that renders.
Tried to get the render times down but they were all going for a day or more, although they looked good at 10 hours. I added a Dog 8 with LAMH hair to try a new render, all the settings I left the same.
Beware the Fire Demons
I was going to stop it at 10 hours but went to bed instead and let it run overnight.
2019-08-10 09:16:09.236 Total Rendering Time: 20 hours 39.17 seconds
Came across Muelsfell Modular Path Set which I hadn't tried. I loaded up the default scene Muelsfell Path Back to Hagswood !Promo Scene and started the render. It was going well over nine hours and seemed to have got stuck at 67%. I stopped it and did a few changes that I do on a scene when that happens and added one of my HDR images I made in Bryce, I was only using sun and sky set to night before.
So that's how her soul looks? Scary
Mecha for life!
Long Way Home
A Night In The Cemetery
2019-05-07 08:45:59.494 Total Rendering Time: 23 hours 14 minutes 59.35 seconds
657
At The Harbour
2019-05-21 06:54:43.309 Total Rendering Time: 21 minutes 7.22 seconds
2019-05-20 21:37:49.823 Total Rendering Time: 10 minutes 39.70 seconds
696
Seals
2019-05-24 14:25:38.467 Total Rendering Time: 2 hours 7 minutes 29.20 seconds
729
Hurry up Moose!
729
Here are the videos.
The Canal Boat
2019-05-28 22:09:44.573 Total Rendering Time: 20 minutes 57.2 seconds
833
A Good Night Inn
867
Dragon Mistress
36% done
Studio.4.11 Beta
36% done
Studio 4.10
897
Storm Cloud
2019-06-16 13:46:36.218 Total Rendering Time: 3 hours 24 minutes 34.85 seconds
Studio 4.10
Buffalo Rain Dance
2019-06-17 23:46:33.737 Total Rendering Time: 3 hours 7 minutes 8.17 seconds
Studio 4.10
923
Checking Messages
021
Ascension
2019-07-22 11:03:51.632 Total Rendering Time: 1 days 13 hours 16 minutes 50.90 seconds
039
2019-07-23 10:08:16.997 Total Rendering Time: 19 hours 38 minutes 19.85 seconds
039
@Rakuda
2019-07-24 12:42:03.068 Total Rendering Time: 23 hours 26 minutes 46.97 seconds
95% done
059
2019-07-29 11:23:05.152 Total Rendering Time: 14 hours 49 minutes 48.57 seconds
4.11 Beta
087
4.11 Beta
087
Strange one this, although I think I know the problem, the first 50% or so took around three hours and yet look at the finished render time.
2019-08-04 07:51:45.210 Total Rendering Time: 1 days 21 hours 43 minutes 16.32 seconds
Studio 4.11
112
89% done
127
Added a figure to get some balance. This is Gwenbleiz.
2019-08-11 12:30:49.175 Total Rendering Time: 16 hours 2 minutes 17.30 seconds
80% done
Gwenbleiz
2019-08-11 22:36:40.634 Total Rendering Time: 7 hours 51 minutes 23.59 seconds
136
Knights Meeting
2019-08-13 16:11:10.212 Total Rendering Time: 17 hours 47 minutes 25.17 seconds
145
Should I?
2019-08-14 16:51:37.693 Total Rendering Time: 2 hours 26 minutes 55.81 seconds
159
The Conquered or the Conquerors?
201
Would You Like Straws With Your Drinks?
2019-08-31 09:37:09.740 Total Rendering Time: 20 hours 37 minutes 26.37 seconds
Studio 4.12 Beta
228
The Enemy
2019-09-01 09:37:01.861 Total Rendering Time: 12 hours 42 minutes 1.20 seconds
Studio 4.12 Beta.
250
The result speaks for itself :)
2019-09-04 23:23:10.183 Total Rendering Time: 1 hours 22 minutes 12.18 seconds
Studio 4.12 Beta
273
An Offering
2019-09-06 12:52:10.122 Total Rendering Time: 2 hours 58 minutes 4.1 seconds
Studio 4.12 Beta
294
Now that was fast!!
Mergirl
2019-09-06 16:31:57.452 Total Rendering Time: 14 minutes 38.59 seconds
Studio 4.12 Beta
298
