Carrara Challenge #47: Structured/Unstructured...or "Unstructured Structure"
13567…12
  • DesertDudeDesertDude Posts: 1,239
    Selinita said:
    Using FOG as a means to differentiate elements in an image...
    This and the no fog image...I am convinced you are a professional photographer Selinita. I'm working on a model for an image from a sketch that has this same "ropy arms" feel. Love it!
    ed3D said:
    Stezza :      Building Blocks
    _pretty good
    and  the Material on those Blocks ?? thanx
    thanks @ed3d the block was modeled from a cube.
    the bump map was from my own resources used on the grey basalt shader and incresed to 200% in the Carrara stone shaders tab.
    Nice workflow Stezza !
    +1 yes
    Unstructured - Fall of Rome, with the collapse of worldwide civilisation "Mad Max" gangs take over fighting for diminishing resources.
    Great concept Bunyip! And I'm already digging the lighting. Nice!
    edited June 2019
    Selinita said:
    I just had to have a go at a breezeblock too...
    This image show's Carrara's displacement mapping
    This image demonstrate's Phil's Phong Modifier
    As a side; I've been reading William Vaughan's book on 'Digital Modelling' to get a better flavour for this skill I'm lacking in.
    Thank you Selinita for the comparisons between Carrara's displacement mapping and Philemo's plugin. Cool!
    Ooooh! Great book. William Vaughan is a genious - I love his software agnostic approach to modeling. Another book you and anyone here might be interested in is his "Pushing Points Topology Workbook". It is specifically about topology and making all quad models. Focus is on how to get out of trouble when you model yourself into a corner...of triangles, ngons and all the other horrid places you can suddenly find yourself when the goal is an all quad model.
    Post edited by DesertDude on
    edited June 2019
    This just looks cool.  Not sure what you mean by using fog to differentiate elements, however.
    I can't be certain but I'm guessing it's Distance Fog, which can be found when you select 'Scene' at the top of the Instances Tab, then in the Effects Tab you'll find Atmopshere>Distance Fog. Dial in your settings from there. Screen shot is set to arbitrary settings and fog color.
    291 x 367 - 20K
    edited June 2019
    Mystarra said:
    cany quite get the right shader for terrain clouds
    watching ant man atmo  is messing with my perspectives.
    ant ton neeee!! nooo
    lost where i saved the ocean foams shader from he cafe tutorial
    and theres a tank
    disintegration by the cure
    back it up lol
    back it up
    Disintegration by the Cure... heartheartheart Everything they made is gold
  • StezzaStezza Posts: 9,284
    edited June 2019
    World's First Cordless Drill     cool
    800 x 600 - 676K
    Post edited by Stezza on
    edited June 2019
    Ha ha - great image as usual Stezza!
    Can I ask a question about how you achieved some of the subtle blue colored shadows in the image? I have experimented in the past using custom mattes in post to drive shadow colors and values. Just wondering because Carrara's native lights (no GI / Indirect light fancy stuff)  can be greyscale drabness,  even with Intensity slider adjustments. Thanks
    Edited to add: yes, I know we can add colored fill lights, but the color of cast shadows...
    edited June 2019
    Thanks, TP Lightdomes is what I used for that with Carrara's realistic sky, I had to tone down the blue a fair bit for that.. you can't get them anymore I don't think from the store.. I think they were extincted.
    the best lighting domes for Carrara, I use them for 99% of my renders with slight adjustments here and there. I dunno how new users can get them now frown
    Selinita said:
    Here's my model...
    one can never have too many building blocks to play with wink
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited March 2021
    Post edited by Persona Non Grata on
    edited March 2021
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,775
    Well there is this
    https://www.sharecg.com/v/30481/gallery/5/3D-Model/Light-Dome-presets-for-Carrara-6
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    Well there is this
    Il will soon upload a new plugin that allow to create light domes from HDRI.
    edited March 2021
    edited June 2019
    Mystarra said:
    wip: emu over troubled waters
    playing with anything glows
    Old Man Emu - classic song
    Not the version i remember but has energysmiley
    Post edited by Mistara on
    edited March 2021
  • ed3Ded3D Posts: 2,656
    edited June 2019
    Stezza :
    thanks ed3d the block was modeled from a cube.
    _you're welcome and   Thanx
    Post edited by ed3D on
    edited March 2021
    Selinita said:
    Terrains as cloud generators ...
    The shader needs alpha to punch some holes in it (unless it's a dark stormy cloud scape)
    Click to enlarge
    SETTINGS:
    • Colour - something predominantly grey (add a splash of colour for fun!)
    • Alpha - Cellular: Fractal, very large scale (use transform of [overall] 128 as a starter and set lower limit to punch holes in it
    • Bump - Cellular: Fractal, normal scale for added interest
    • Glow - Be subtle to make them stand out
    looks good!
    edited March 2021
    edited June 2019
    fuzzy cave wear!
    dead pool, all dinosaurs feared the t-rex
    Well there is this
    Looking forward to that!!
    spent the weekend learning how the hdr cam works on iphone,.
    Well there is this
    What you need are 360 panoramic images which can but need not be HDRi as well
    what DAZ sells as HDRi are Panoramic 360 HDRi, a bit of a misnomer
    HDRi simply stands for High dynamic range image and can be any lens type, my iPad does them too, it takes two photos at different exposures and combines them to get an inhanced image but it is Not a 360 panorama
    edited March 2021
  • DiomedeDiomede Posts: 15,468
    edited June 2019
    More Freebies!
    Great additions by all.  Will have to comment later.  Have just enough time to post some freebies.
    Meanwhile, in honor of our host, DesertDude, here are some building blocks for our structures.  Build something spectacular.
    These are great examples of over-modeling.  Could easily assemble some cube and cylinder primitives, but the underneath?
    In any case, here are some awesome structural pieces, because everything is awesome!
    See attached zip file.
    Everything is awesome.
    zip
    zip
    Legos Freebies scene carrara.zip
    208K
    1378 x 743 - 109K
    Post edited by Diomede on
    edited March 2021
    its all better fluffified
    fluffy dice, fluffy emu, hairy tomatoes, hairy cavemen
    edited June 2019
    what structure to do next?
    i'm blanking on deconstructing no lightbulb dingsenlightened
    watched the antman movies
    but thinking the quantum realm would be like a biodome
    no structures there just slug like critters lookin hungry
    edited March 2021
