Buy Something That Doesn't Work in Carrara? Post your Questions and Workarounds here. (please)
1222325272852
  • HeadwaxHeadwax Posts: 10,435
    I purchased Carrara about 3 years ago: I played around with it and lost intrest itin it fast.
    Oh you'll have to forgive Wendy et Stezza for their rudness @Softimage_Graphic_Artist .
    I have to admit I admire your intellectual stamina.
    I bought Carrara about 9 years ago and I am still trying to lose interest in it.
    You'll have to give us your secret so we can stop being jealous.
    i have to say, coming from Poser, i had a few false starts in carrara.
    i was used to parameter dials and poser shader room.
    hair and cloth dynamics in poser was just hype.
    didnt get physics results until i came to carrara.
    start with customizing the carrara ui, to "own" it, make it yours.
    larger menu font and background colours.
  • UnifiedBrainUnifiedBrain Posts: 3,588
    My request here is not for a product fix, but instead a question about a Carrara function that apparently does not work.
    I want to have some renders printed as posters.  I believe that print shops ask you to provide a 300 dpi image.
    In Carrara, my images are always 72 dpi.  I've changed the preferences to 300 dpi (preferences>render room>300dpi).  I've also changed the render room Output tab to 300 dpi.  To the best of my knowledge, nothing changes in the final render.
    In short, all my renders since the very beginning have aparently been 72 dpi (PNG images).  At least, that is what Photoshop Elements says, when I load them there.  Other renders I load there, such as Ron's Space images, always show up as 300 dpi.
    Am I misinterpreting something here, or doing something wrong?
    Thanks for any responses.
  • BrianP21361BrianP21361 Posts: 815
    UnifiedBrain you are missing something. dpi is really meaningless in Carrara. It's the total number of pixels that count. if you create an image in Carrara that's 800x1000 pixels and print it as an 8"x10" picture then it's 100 dpi. If you print the same picture at 4"x5" its going to be 200 dpi. So, if you want to print an 8"x10" at 300 dpi image created in carrara it should be 2400x3000 pixels. I did this quickly. I hope my math is correct.
    Thanks Brian.  You say that dpi is more related to total size (number of pixels) than it is an independent adjustment.  But is PSE, it clearly is an independent adjustment.  How can dpi be meaningless in Carrara, when there are (supposedly) two places in the software to make dpi adjustments?
    edited June 2019
    Let me try to explain with some images. I created a simple Carrara scene and rendered it at 640x480 pixels at both 72 dpi and 300 dpi. I opened both in PhotoShop Elements (first two screen shots). The images look identical. This isn't a Carrara bug. If I chose resize in PSE you can see the number of pixels, document size and dpi. Both images showed the same dpi (72) when I chose resize. If I change the dpi, the document size decreases by the same amount. Notice that the Resample Image check box is unchecked. If I left the Resample Image box checked and then changed dpi to 300, the document size will stay the same, but the number of pixels increases. Notice at the bottom is says "Bicubic(best for smooth gradients". PSE is using an algorithm to increase the number of pixels in the image. This resampled image won't look as good as an image that's rendered at the full pixel size to begin with, 2000x2667. The file size also increases significantly and it has to because there are more pixels. Does that make sense?
    1007 x 565 - 143K
    1008 x 561 - 147K
    1102 x 702 - 161K
    1105 x 713 - 154K
    1126 x 715 - 158K
    Post edited by BrianP21361 on
    edited June 2019
    I followed you to this point.  You were comparing the two images, and said that they looked identical.  Then you started talking about what PSE does to an image when you resize.  I also followed that part.
    What was missing - for me at least - was a conclusion about if the Carrara 72 dpi image was different in some way from the 300 dpi image. If the 72 and the 300 are indeed identical, right from Carrara, then Carrara is not functioning as the menus suggest.  And, that there is no value in choosing the 300 dpi value as a Carrara output.
    Post edited by UnifiedBrain on
  • StezzaStezza Posts: 8,813
    Say you have an image that is 500 x 500 with a 72dpi. You can go into image size (with the re-sampling checked) and make it 300dpi. This will give you a bigger image but it is probably not what you want. This will give you an image of 2083 x 2083. You will see that it will not change the inches.
    If you want to change to a higher dpi for printing but do not want to change the onscreen image size, then you uncheck re-sampling. Un-checking sampling will give you the same pixel size (500 x 500) but will change the print size to 1.667 inches down from 6.944.
    I just did a test render at 640 x 380 x 300dpi and saved as jpg .. working as expected. yes
    Stezza, if my question was "How do I change an image I made in Carrara to 300 dpi in PSE, " then you answered it (as did Brian).
    In fact, I have done this many times myself.  And now that I am getting into printing, it will likely be the method I use for future printed work.
    But that is a workaround.  I brought up the subject of PSE only as a means to verify the dpi rate coming from Carrara.  And based on what the menus say in Carrara, I am supposed to be able to create a 300 dpi image, without doing a conversion in another software.
    I was hoping that maybe I was overlooking something, but it appears that the dpi settings in Carrara don't do anything.  The output stays at 72 dpi regardless what you select.
    To me, this is a bug. :)
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited March 2021
    Post edited by Persona Non Grata on
    Awesome, Selina!  It looks like you have the answer.  I will experiment with it later today.
    Many thanks for the replies and efforts to help, folks.  Cleared things up a bit. yes
  • SileneUKSileneUK Posts: 1,977
    edited June 2019
    It works... without fail.  If you are using a version of Photoshop, be sure you check your colour settings in PS. You can end up with a different set of colours on your image when you open it there and I am not talking about the RGB vs CMYK profile. If you see a rusty colour dominating your images in PS, go to Edit>Colour Settings and see if you are using Monitor Colour or some other colour setting. It does make a difference. Depending upon your system and software version you will have to have a play around to get your PS images to look the same as the ones you saved in the Render room.  Also I use TIFF or PSD and not jpgs... at 300, you don't want to lose any clarity.
    smiley  Silene
    Post edited by SileneUK on
    Thank you Silene.  Yes, it works great, now that I understand the bigger picture (literally) and the missing step.  It was a bit obvious, but I easily miss the obvious. :)
    Thanks for the additional tips!
    I'm looking forward to what advice the local printshop gives as well.
  • When going from screen to print there is a conversion from one colour space to another, ie RGB (screen) to CMYK (print). At the printshop their monitors and printers will have been calibrated so that what you see on screen is what you will get in print. The difficulty lies in the fact that your home machine probably isn't and my advice to you is to do your own printout and adjust it to get the colour you want in photoshop and take this along with your file to the printers as they will be able to match your paper copy to the finished print run.
    When I was working as a Graphic Designer I used to supply all artwork to the printers in PDF format as it contained valuable CMYK separation information and the correct colour profile to get the results I was expecting along with a hard copy printed on the company's printer which I had already adjusted by eye to get the desired result.
    Hope that helps (?)
    edited June 2019
    Hope that helps (?)
    What she said!! I still work as a 2D designer for my old employer when they get busy... can't seem to let it go. Feeds my expensive habit of 3D angel
    What are you rendering... can you post a sample?
     Also, if most of your colours are within the 'natural world' gamut, eg no overly bright/vivid colours, some of which you can get in RGB mode which is what your screen uses, then converting to CMYK for printing won't make a big difference.  EG, if your render is more photo-realistic and uses colours we see everyday, then it should be OK.  You can save a pdf in PS using 'save as' if you want to get an idea. It will automatically take your RGB render and change the colour profile to CMYK for most images.  You can also change your colour mode to CMYK in most photo programmes (eg PS) or if you cannot make a pdf. Then you will see your screen image change or not change depending upon the colours you used.  If not happy or sure about the colour result, then give the printer a PSD or TIFF file. They can tweak it to get a pleasing appearance.
    Your print bureau can help if they are printing on the premises by giving you a proof. Some will only give you a digital proof, though. Depends on where you go.   Be aware that if you are using a local business printer, their ethos will be to get a close to result. If it is a very important artwork, you need to go to a fine-arts printer.
    If you have colours that your artwork must have as vivid and outside of the normal natural gamut like those vivid pinks, greens and turquoises, then you can pay for a Pantone colour to be added to the printing process to capture that colour.  Extra cost.
    Here's a screenie of what I mean about the colour gamuts for RGB and CMYK.  The K of CMYK is represented by the black bit in the centre. CMYK is a pigment/ink based system. Even our home printers are now mostly a passable CMYK,.  RGB is a light based system, and what you can see on your monitor and the centre bit is white.   Pantone is an ink mfr who create specific pigments for the printing industry. They can do anything, eg metallics and day-glow colours. It's added to the printing press to get special colours and of course costs more.
    Just changed the image which gives a better view of RGB vs CMYK... the first screenie was not very explanatory and one I substuted and took off had it backwards. Shame on a printing site for doing that!
    yes  SIlene
    Thanks gals, for those great tips.  I'm sure that there will be a learning curve, and you helped smooth it.yesheart
    I have had several things printed in the past, but never any of my Carrara artwork.  What I will bring them are mostly PNG versions of renders I have entered in the Challenge.  I'm particularly interested in large sized posters, such as 24 x 36 inches.  At 300 dpi, those will be some weighty renders!
    The print company I use is interesting because they only do work for other printing companies.  In other words, they don't deal with the general public.  I got an exception because I self-publish a book, and they took me on as a client almost 20 years ago.
    Well done! Are you doing another book or set of illustrations now? enlightened  Silene
    Nope, just exploring the idea of doing posters. There is another book I am working on, but that is another story. smiley
  • mindsongmindsong Posts: 1,735
    edited June 2019
    i see what you did there... :^)
    (and thanks selinita and selineUK_Carrara for the tips - I've PDF-d and offlined this page for future reference)
    --ms
    Post edited by mindsong on
    huuuh loading this made carrara shutdown,  no message, just bam! closed.
    https://www.daz3d.com/wurlie-electric-organ
  • Mystarra said:
    Whuuuh loading this made carrara shutdown,  no message, just bam! closed.
    Don't own it even though I used to play a real one but maybe it has the rigid nodes
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,279
    edited September 2019
    not sure if this counts because not something bought at DAZ
    but
    Occassionally I get an FBX file that just stuffs up Carrara saying rendering failed and creating UI glitches
    I have imported other FBX files from the same source that work fine
    I wish I had a way to find the trigger, I have passed it through several other softwares such as iclone, Ultimate Unwrap 3D and Autodesk FBX convertor to no avail, it still does it
    it is an UE4 file and interestingly enough it stuffs up importing back to UE4 too
    this is the file in iClone, I have gotten the other Paragon figures I did this with into Carrara fine
  • OK, I realize that I am incredibly late to the party, but is there a way to reliably get Genesis 3 clothing into Carrara?  I don't care if it fits, as I can usually ajjust a clothing item in the modeling room to any character.  I just want to bring in some clothing items that don't crash Carrara.
    The first time I tried it, everything looked great, but the render became endless and it crashed.
    Thanks!
    you need to change all the clothing you want to blended weight in DS first and resave them in another folder ( that's what I do ) then you can get (most of the time) the items into Carrara wink
  • Thank you Stezza.
    It took me 20 minutes to remember how to find a product in DS.  Those little trianges are smaller than I remembered.
    Then it took me 15 minutes to find the blended weight menu.
    But I got there, and it worked!  Was it worth it?  Of course.  The G3 clothing made my render at least 1% better. smiley
    something to be said for rendering nudes smiley
    need more potted ferns  tee hee
    there was something about a submarine a bunch of pages ago.
    underground sub?
    underground sub?
    If you're referring to my post last year about a texture issue it was about https://www.daz3d.com/secret-underground-base-and-submarine.
    underground sub?
    thanks.  nice sale price,
    just needs a splash of yellow paint.
    Oh dear, seeing what you mean.
    not seeing any geograft to cause artifacts
    mebbe something that can test normals all pointing the correct way ...
    Post edited by Mistara on
    or a freshly made alt uvs map. seeing sections cut into strips.
