The Hackers got to my XP Complaint Thread
1171820222350
  • frank0314frank0314 Posts: 14,799
    Kyoto Kid said:
    ...OK, this was weird. Downloaded the two freebies for today and when I clicked on the 'Ready to Install" tab, one of them (The Rock Demon) didn't appear.
    It shows up for me
  • XyetztXyetzt Posts: 27,456
    I looked up belly ring and Daz store thought I was looking up bullring. Are there any piercing packs for G2F?
    I haven't seen any
    Frank0314 said:
    I haven't seen any
    I used the V3 piercing pack. Is the bellyring visible?
    1010 x 922 - 71K
    can't see belly ring. maybe if you rendered more pixels?
    Kyoto Kid said:
    ..yeah ones on the Autobahn can be pretty bad because of the unrestricted speed in rural areas. Saw the aftermath of one where a Porsche slammed into a bridge pier. The driver must have been going area fairly high rate of speed as the debris was sprayed over a wide area of the roadway, most of which, save for the tyres and engine block, was not much larger than a tin of Altoids.
    Also saw the results of another high speed crash here in the States (in my old hometown many years ago) where a Corvette, which was racing another car by the airport, went out of control and slammed broadside into the middle barrier of a tunnel under a runway The front axle, engine block, and bumper were more than halfway down in one side of the tunnel, the back end about the same distance in the other. The middle of the car (and occupant) pretty much ceased to exist from the force of the impact
    oh mannn.
    here it's the friggin traffic cameras. 1st car was braking hard for the just turned red light. car 2 was still trying to make the light. it's the kinda thing you can only pray everyone survives it.
    Is this better?
    1010 x 922 - 71K
  • starionwolfstarionwolf Posts: 3,670
    edited October 2013
    I can barely see the piercings in neither your render nor my render.
    edit: your second render is better. I need to work on mine. lol
    498 x 480 - 44K
    Post edited by starionwolf on
    Is this better?
    yeah i see something this time. :)
    that reminds me, i should render my images at 800x600, not 640 x 480 pixels. :D
    DanaTA said:
    ps1borg said:
    Morning. Cold south wind blew all the grey clouds away overnight and left a big bright but cold sun-kissed blue sky day for us so far.
    It got cold here today. The high in my town was 53 (F) today. Inside it was only 64 at the warmest part of the day...so I opened up the vents downstairs and turned the heat on. That's too cold for me. My hands get cold and stiff and I can barely even type. I hate that!
    Dana
    going down to 35F tnite.
    the draft stopper thingees do make a difference.
    I want to go steal an apple but then that apple is set out for us to eat.
    more pixels ! :)
    Does she need more piercings
    1010 x 922 - 105K
    i'll try to render a scene at 1024 x 768 to see how long 3Delight takes. I'll swap out the hair with transparency layers for some other hair though.
    Here is a render that is closer up.
    1356 x 922 - 224K
    apple is delicious with caramel.
    caramel apples. it's the season for those caramel popcorn balls to come out.
    I have no caramel so it is just an apple.
    a few tee hees :lol:
    499 x 404 - 29K
    384 x 319 - 14K
    599 x 620 - 55K
    Here is another wip
    1356 x 922 - 250K
  • DanaTADanaTA Posts: 13,375
    Dana
    And that 64 was at the thermostat...which is at about my eye level. So down where we sit, it's lower. It was probably about 60. Draft stoppers are good, I have one downstairs in the basement door. But this isn't from draft, it's because I hadn't turned on the heat yet this season. It's better now.
    Dana
    DanaTA said:
    Dana
    Dana
    i hope the oil prices don't go up this winter. utilities are included in my rent, my rent will go up.
    We have natural gas for our heat and cooking. But the news said that is going up this year. :down: I don't keep it as high as I used to. We'll see what the damage is this year.
    Dana
    how do you turn on skin sss in DS? is it a node like poser? is it a slider surfaces doodad?
    Here is another wip
    she's wearing a pretty necklace in this one..
    Dana
    i heard natural gas is better than oil.
    we're on a dead end, there's no gas option available. have oil heat and electric stove.
    Here is another wip.
    1356 x 922 - 229K
    edited October 2013
    Apply the Elite Human Surface shaders. Here is an old tutorial for Daz Studio 3: How to use the Elite Human Surface Shaders
    I forgot where the EHSS shaders are in Studio 4. I think they are in the shaders folder under Daz Studio files. Sorry, I can't check now. I'm using another computer now.
    Edit: I found one of my old screenshots online from an online backup. Hope this helps.
    Edit 2: after you load the Human Surface Shader, you can turn on Fresnel, Velvet and Subsurface scattering. You may want to reduce the specular strength.
    491 x 564 - 70K
    613 x 703 - 84K
    Dana
    Well, it's certainly cleaner. And to my knowledge, all the great chefs prefer gas to electric. I don't have to worry about a tank running low, or leaking. I've had natural gas for cooking and heating since I've been married, and many years when I was young as well. Never had a gas leak problem.
    Dana
  • TJohnTJohn Posts: 11,355
    Small is good when testing, speed-wise though.
