Thanks, I'm going to have to file support ticket about the Genesis 2 Female Essentials and the Subsurface Shader Base. Manual downloads are showing no updated versions of them.
I manually downloaded both of them yesterday and re-downloaded them a few minutes ago.
Does anyone have the DIM dates for the newest versions?
Also are the manual downloads current for Sans.Pokerface Expressions? I don't have a DIM version for them too.
3Drama Xpress (DIM) (Genesis) (Notes: DIM files last updated on 9-27-2013.)
Genesis 2 Female Starter Essentials (DIM) (DSON) (Note: DIM files updated on 10-1-2013.)
Mad Nurse for Genesis 2 Female(s) (DIM) (Genesis 2 Females) (Notes: DIM files last updated: 10-3-2013 DSON / 9-17-2013 CF.)
Sans.Pokerface Expressions for Girl 6 (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files updated on 10-04-2013.)
West Park Insanity Poses (DIM) (Genesis) (DSON) (Notes: DIM Files updated on 5-22-2013.)
Notes: I filed a support ticket about the Manual Downloads not being current for Genesis 2 Female Starter Essentials and Subsurface Shader Base.
I'll make a post when I hear back from support about them.
Can someone check to see if the CF files for Mad Nurse for Genesis 2 Female(s) got updated too. The Manual Downloads are only showing the DSON Core ones have been.
Last update for CF Mad Nurse for Genesis 2 Female(s) is 9-17-2013.
Furisode Genesis (DIM) (Genesis) (Notes: DIM files last updated on 9-12-2013.)
Furisode Genesis 2 Female(s) (DIM) (Genesis 2 Females) (Notes: DIM files last updated on 9-12-2013.)
Notes: Some more info abiut the update to Genesis 2
Several files located in the DAZ and Age of Armor sub folders of the data folder were updated on 10-1-2013. you can look in the folders as and check the dates. The manual downloads are giving the current version.
The usually method of just checking date of the Manifest files doesn't work.
The separate Subsurface Shader Base were not updated.
There are no Age of Armor subfolders inasmuch as these are SickleYield/Fuseling products. The artist name folder is "SickleFuse."
There was an update that just went live to fix an issue on the right sleeve of the Genesis version when translating on the X axis.
My note was a follow up for the Genesis 2 Female Starter Essentials that were mentioned a few threads up not the SickleYield/Fuseling products mentioned.
What are the current file versions for Furisode Genesis and Furisode Genesis 2 Female?
Afternoon Heat Outfit for Genesis 2 Female(s) (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Boardwalk Outfit for Genesis 2 Female(s) (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-14-2013.)
BWC Cool Teen Josie Poses (DIM) (Genesis 2 Females) (DSON)
DP Teen Josie 6 Carrara Shaders (DIM) (Genesis 2 Females) (Notes: DIM files last updated on 10-7-2013.)
Dress Code Violation Outfit (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Emotions for Teen Josie (DIM) (Genesis 2 Females) (Notes: DIM files last updated on 10-9-2013.)
Everyday Poses for Josie (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Expressions for Teen Josie (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-9-2013. Has no CF.)
Foxy Stripe Shirt (DIM) (Genesis 2 Females) (Notes: DIM files last updated on 10-9-2013.)
FW Cassie (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Izzy (DIM) (Genesis 2 Females) (DSON) ( Notes: DIM files last updated on 9-20-2013.)
Josie Sport Poses (DIM) (Genesis 2 Female) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Josie Tails Hair for Genesis 2 Female(s) (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Lisa Textures for Teen Josie 6 (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 9-18-2013.)
Scarf Braid Hair (DIM) (Genesis 2) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Sneaking Out Clothes for Genesis 2 Female(s) (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Sporty Braid (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Sweet Flower Hair (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Tanked for Genesis 2 Female(s) (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 9-19-2013.)
Teen Josie 6 (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 9-24-2013.)
Teen Josie 6 Pro Bundle (see separate entries for each product in the bundle)
Teen Josie 6 Starter Bundle (see separate entries for each product in the bundle)
Urban Girl for Teen Josie 6 (DIM) (Genesis 2 Females) (DSON)
West Park Horror movie poses 1 (Genesis) (DSON) (Notes: DIM files last updated on 10-15-2013.)
West Park Horror Movie Poses 2 (Genesis / Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-15-2013.)
Darkish for Emotions (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated: 10-10-2013 DSON Core / 10-15-13 Poser CF.)
Intriguing Poses for Genesis Female (DIM) (Genesis) (DSON) ( Notes: DIM files last updated on 4-15-2013.)
Intriguing Poses for Genesis Male (DIM) (Genesis) (DSON) ( Notes: DIM files last updated on 4-22-2013.)
Dark Elves for Genesis 2 Female(s) (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-11-2013.)
Intriguing Poses for Genesis Male (DIM) (Genesis) (DSON) ( Notes: DIM files last updated on 10-16-2013.)
Starship Piranha (DIM) (DSON) (Note:DIM files updated: 1-31-2013 DS / 10-13-2013 PS. Product is a vehicle with Genesis and M4 pilot poses.)
Other Notes:
Defiant for Genesis got updated recently. Anyone have the DIM file dates for it?
Just wanted to give you all a "heads up" that Handy Dandy is about to receive an update. It is currently in QA, but should be available shortly. I have reworked the V4 to Genesis and Genesis 2 fixes and have also done the same for M4 hands. The thumb will pose better in the majority of cases, but for some reason I can't get it perfect. I don't know exactly what is different between on Generation 4 pose and the next, but the numbers I am using seem to work for most poses in at least getting them to look like normal thumbs, if not posing them properly. The exception seems to be fist positions. The thumb won't quite go right, but it's a lot closer than without Handy Dandy.
I have also tried to get the presets saved as Pose(s) instead of Script(s) so that they are easier to find. I'm not sure yet if that will get implemented, but I did put in the request.
Defiant for Genesis 10/11/2013 replace zero-length files, update metadata
West Park Horror movie poses 1 (formerly West Park Insanity Poses) 10/15/2013 renamed folders
West Park Horror movie poses 2 (formerly Shock Treatment) 10/15/2013 renamed folders
Afternoon Heat Textures (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Boardwalk Textures (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 10-14-2013.)
Chunky Boots for Genesis 2 Female(s) (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 9-13-2013.)
Cute Mini-Dress and Shoes (DIM) (Genesis) (DSON) (Notes: DIM files last updated on 8-21-2013.)
Cute Mini-Dress and Shoes Textures (DIM) (Genesis) (DSON) (Notes: DIM files last updated: 5-8-2013 DSON Core / 5-9-2013 CF.)
Defiant for Genesis (DIM) (Genesis) (Note: DIM files updated on 10-11-2013.)
Fantasy Fighter for Genesis 2 Female(s) (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 7-22-2013.)
Fight! for Fantasy Fighter (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 7-28-2013.)
Furisode Genesis (DIM) (Genesis) (Notes: DIM files last updated on 10-10-2013.)
Furisode Genesis 2 Female(s) (DIM) (Genesis 2 Females) (Notes: DIM files last updated on 10-15-2013.)
Mad Doctor for Genesis Male (DIM) (Genesis) (DSON) (Notes: DIM files last updated on 5-29-2013.)
Tanked Textures (DIM) (Genesis 2 Females) (DSON) (Notes: DIM files last updated on 9-19-2013.)
G2F essentials were updated due to Daz Studio receiving an update to 4.6.1.17. Something about projection maps compatibility.
No, it was to prevent a potential crash: http://www.daz3d.com/forums/viewreply/443341/
Same general idea. lol :P
Was still fixing projection templates.
G2F Starter Essentials: 10/1/2013
Updated :
Mad Nurse for Genesis 2 Female(s) (DIM) (Genesis 2) (DSON) (Notes: DIM files last updated on 10-3-2013)
Thanks vwrangler, Vaskania, Mike, & MickyBel.
Updated & Added:
Thanks MickyBel.
New :
People of Earth: Faces of Asia (DIM) (Genesis 2 Females) (DSON)
Thanks MivkyBel,
I got it added to the list.
Added:
New :
Courtly Intrigue Poses (DIM) (Genesis) (DSON)
Mix and Match for Super Dress (DIM) (Genesis 2) (DSON)
Super Dress and Leggings for Genesis 2 Female(s) (DIM) (Genesis 2) (DSON)
Super Hosiery (DIM) (Genesis 2) (DSON)
Wren Hair (DIM) (Genesis / Genesis 2) (DSON)
Not in the list :
Ideal Beauty: Gia Addon (DIM) (Genesis 2) (DSON)
Ideal Beauty: Girl 6 Addon (DIM) (Genesis 2) (DSON)
Thanks MickyBel,
all have been added.
I also added to the list.
Shock Therapy Poses (DIM) (Genesis / Genesis 2) (DSON) (Notes DIM files updated on 10-2-2013.)
New :
Urban Girl for Teen Josie 6 (DIM) (Genesis 2) (DSON)
BWC Cool Teen Josie Poses (DIM) (Genesis 2) (DSON)
Teen Josie Pro Bundle :
Afternoon Heat Outfit for Genesis 2 Female(s) (DIM) (Genesis 2) (DSON)
Boardwalk Outfit for Genesis 2 Female(s) (DIM) (Genesis 2) (DSON)
Dress Code Violation Outfit (DIM) (Genesis 2) (DSON)
Everyday Poses for Josie (DIM) (Genesis 2) (DSON)
Expressions for Teen Josie (DIM) (Genesis 2) (DSON)
Foxy Stripes Shirt (DIM) (Genesis 2) (DSON)
FW Cassie (DIM) (Genesis 2) (DSON)
Izzy (DIM) (Genesis 2) (DSON)
Josie Sport Poses (DIM) (Genesis 2) (DSON)
Josie Tails Hair for Genesis 2 Female(s) (DIM) (Genesis 2) (DSON)
Lisa Textures for Teen Josie 6 (DIM) (Genesis 2) (DSON)
Scarf Brad Hair (DIM) (Genesis 2) (DSON)
Sneaking Out Clothes for Genesis 2 Female(s) (DIM) (Genesis 2) (DSON)
Sporty Braid (DIM) (Genesis 2) (DSON)
Sweet Flower Hair (DIM) (Genesis 2) (DSON)
Tanked for Genesis 2 Female(s) (DIM) (Genesis 2) (DSON)
Updates :
DIM Files updated on 10-14-2013
DIM File updated on 10-15-2013
West Park Horror Movie poses 2 (DIM) (Genesis / Genesis 2) (DSON)
Thanks MickeyBel.
Added & Updated: 10-15-2013
Added & Updated:
Updated :
Intriguing Poses for Genesis Male (DIM) (Genesis) (DSON) (Note: DIM files updated on 10-16-2013)
Does somebody know which UVs the Lisa texture needs?
(I don't have V6 or Josie)
The texture uses Victoria 6 UVs.
Thanks for the answer!
Thanks MickyBel.
Updated:
Other Notes:
Thanks Mike.
Added & Updated : 10-18-2013
New :
Growing Up for Genesis (DIM) (Genesis) (DSON)
Updated (and not in the list) :
Handy Dandy (DIM) (Genesis / Genesis 2) (DSON) (Note: DIM Files updated on 10-17-2013)
Thanks MickyBel,
I just added those.
