The Mac FAQ
Adding to Cart…
I'm struggling with the 32- and 64-bit thing. I have an older Mac, 2009, running Snow Leopard (10.6). While Snow Leopard is 64-bit capable, I don't believe I ever enabled it. For example, my system report says:
64-bit Kernel and Extensions: No
However, I know it's 64-bit capable, I installed the 64-bit DAZ Studio and it launched.
So my question is, should I uninstall and re-install using the 32-bit installer.
Thanks.
User Accounts
If I intend to use DAZ Studio 4 within 2 different (Mac) user accounts, do I need to do anything different when I install. Does it matter which account installs (or installs first)?
Just so you know, I tried this and I found the [user name]/Documents/DAZ 3D/Studio/My Library to be different for the 2 different accounts.
Thanks.
If you're using it with 2 different user accounts, it would be better to install the content to Shared.
Thanks, but I realize my question wasn't clear enough, and that I actually have 2/3 questions.
1. If using DAZ Studio 4 with 2 user accounts, do I need to do anything (besides the defaults) when I install the program (DAZ Studio 4)?
1B. Does it matter whether I use the standalone installers or the Installer Manager?
2. I haven't gotten content installed yet, but my second question is, Can you be more specific about "install content to shared?" Yes, I see that a folder was created in Users/Shared. But is there anything more significant than pointing to that during content install?
Thanks so much for your reply.
1. I don't know if Mac defaults to applications being available to all users -- if it does, then there's nothing else you need to do when installing.
1B. Should be the same whether you use standalone or Install Manager.
2. No, all that you need to do is use the location in Shared for content -- if it's a fresh install of DS (that is, you haven't had DS installed on this computer before), then it will by default map two locations: one in the particular user's documents, and one in Shared. If everything is going to be shared, I would remove the non-shared one. The default for DIM (DAZ3D Install Manager) is to install content to Shared.
Aside from what Mike has said:
(1a) Applications in /Applications are accessible by all users.
(1b) No, but when using standalone installers, think twice what default path they want to install to, you will most likely change that.
(2) If you plan to have "a lot of content", I would recommend installing all content to a separate disc, but other that that, as long as you have diskspace, just create a "My Librray' folder in Shared and install to that (but you can use whatever name you like.
And for your 64/32 bit question, 64 bit is the way to go. SL (10.6) has full support for user space applications running 64 bit.
32-bit is like installing an old VW beetle engine in your ford explorer ;-)
I've tried everything and I can't get the Content Panel to even show when Daz opens.This is what I get when Daz opens any suggestions? should i just erase all the daz info on my computer and re install? I didn't have this problem prior to installing Daz 4.6 pro. My system is Mac 10.6.8. Thanks!
First, do you mean Smart Content or Content Library, and when you say show, do you mean be visible or show any content?
Anyone tried DAZ 4.6 (and Carrara 8.5) on OSX 10.9 Mavericks?
DS 4.6 runs fine on Mavericks. There are no problems at all.
I've run both DAZ Studio 4.6 and Carrara 8.5 on it. Carrara seems to benefit a lot from the updated ATI Video drivers that come with 10.9.
Seen one "interface glitch" that I'm trying to reproduce so I can bugreport it in Carrara, a screen refresh after a open dialog that fails, but might not be related to 10.9 at all.
Thank you for the answers. I´m on OSX 10.9 Mavericks now and two renders I did before and after upgrade show a speed-up about 10% :-)
Yes, sounds reasonable. Specially if you are on a low memory machine, then memory compression really helps.
I've been struggling most the afternoon trying to get things to work right. I have the Genesis folders created (and showing up in Poser), but when I try to use Victoria 5, 6 or any of the Genesis figures it gives me the following error (see attached)
Now I've installed DSON in the poser directory where it said to but I'm not having any luck. Help? Someone?
If you're using P9/PP2012, do you have SR3.1 installed?
Just updated last week so yes, I think it's at SR3.1.
Updated from the update page at Smith-Micro, or updated to P9/PP2012?
Updated from the update page at Smith-Micro. Everything is a fresh, new install (with updates all over the place). Running Maverick (which I love). edit- just double checked (both on page an the product) it's SR3.1
exactly -where- am I suppoed to have DSON installed? The documentation was hazy. I have it installed in my P9 directory where all the poser installs are residing. But the error I'm getting is pointing at the starter essential folder they had me put in Documents.
Hi everyone,
Is there a complete list anywhere of where Daz Studio 4.6 installs files? Or is there an installer that removes everything from a machine?
I have an installation which consistently crashes when opening a dialog in one user account but which works perfectly in another account.
I've been deleting or renaming documents and folder in the corrupt user account. I think I've found all the ones associated with Studio, but it keeps crashing.
So far I've removed or renamed:
~/Documents/Daz 3D/...
~/Library/Application Support/Daz 3D/...
~/Library/Preferences/com.daz.Studio4 ... .plist (several files)
I've also tried installing a new copy of DS over the top in the hope it would overwrite the corrupt file but the crash remains.
Like I said, the installation works in another account, so it seems localised to the one user account.
Any advice appreciated.
Thanks,
Mike.
First off, can you provide me with the crash log as it might have crucial i of about where it crashes.
Second, I don't have a list but one thing that will be a problem is if things are installed into User Accounts, specially the content manager system, and not into /Users/shared.
So, is the idea tat the different users should have different content or should they share content? In the latter case I recommend installing into /Users/Shared (where data common between users is supposed to be located. Allthough there are some things still in ~/Library/Application Support/DAZ 3D that will clash in a multiple user environment.
Thanks for getting back so quickly.
This machine normally only has the one user so I went with the standard installation options and didn't change anything. I only created the second user account when I wanted to see if the problem persisted between accounts. So the original crashing predates a second user account.
I suppose 'crash' is the wrong word - the program gadgets and menus becomes unresponsive after I try to open or save a document. When the dialog appears, it immediately disappears. All of the top menu options are greyed out and none of the Daz Studio buttons or other widgets work any longer. According to the Mac, Daz Studio is still running and no crash has been detected - the application is using 0% of CPU time.
Since the menus are greyed out, the only way to get out of the application is to use Force Quit, I've attached the log file to the end of this message (no .txt attachments on Daz forums)
If you have ideas on how to fix it, I'm more than willing to try them out.
Thanks again,
Mike.
Process: DAZStudio [35838]
Path: /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
Identifier: com.DAZ.DAZStudio
Version: 4.6.1.17 (4.6.1.17)
Code Type: X86-64 (Native)
Parent Process: launchd [209]
Responsible: DAZStudio [35838]
User ID: 501
Date/Time: 2013-11-15 21:53:35.715 +0000
OS Version: Mac OS X 10.9 (13A603)
Report Version: 11
Anonymous UUID: 699E232E-770C-C2BE-925D-CA51FF4219D1
Sleep/Wake UUID: D0C75348-779F-4B51-88DE-5FE376DF0650
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 QtOpenGL 0x000000010486b57c QThreadStorage::deleteData(void*) + 28
1 QtCore 0x000000010317c624 QThreadStorageData::finish(void**) + 390
2 QtCore 0x0000000103273bbc QCoreApplicationPrivate::~QCoreApplicationPrivate() + 50
3 QtGui 0x00000001035293a2 QApplicationPrivate::~QApplicationPrivate() + 468
4 QtCore 0x0000000103288d8b QObject::~QObject() + 1299
5 QtGui 0x000000010352841b QApplication::~QApplication() + 1295
6 libdzcore.dylib 0x00000001001bdecc DzApp::~DzApp() + 2006
7 com.DAZ.DAZStudio 0x0000000100001605 main + 511
8 com.DAZ.DAZStudio 0x00000001000013e4 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff8d1aa662 kevent64 + 10
1 libdispatch.dylib 0x00007fff991d643d _dispatch_mgr_invoke + 239
2 libdispatch.dylib 0x00007fff991d6152 _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff8d1a9716 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff91967c3b _pthread_cond_wait + 727
2 QtScript 0x0000000104a703e7 QTWTF::TCMalloc_PageHeap::scavengerThread() + 91
3 QtScript 0x0000000104a7048b QTWTF::TCMalloc_PageHeap::runScavengerThread(void*) + 9
4 libsystem_pthread.dylib 0x00007fff91965899 _pthread_body + 138
5 libsystem_pthread.dylib 0x00007fff9196572a _pthread_start + 137
6 libsystem_pthread.dylib 0x00007fff91969fc9 thread_start + 13
Thread 3:
0 libsystem_kernel.dylib 0x00007fff8d1a5a1a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff8d1a4d18 mach_msg + 64
2 com.apple.CoreFoundation 0x00007fff95da4315 __CFRunLoopServiceMachPort + 181
3 com.apple.CoreFoundation 0x00007fff95da3939 __CFRunLoopRun + 1161
4 com.apple.CoreFoundation 0x00007fff95da3275 CFRunLoopRunSpecific + 309
5 com.apple.AppKit 0x00007fff92c5b1ce _NSEventThread + 144
6 libsystem_pthread.dylib 0x00007fff91965899 _pthread_body + 138
7 libsystem_pthread.dylib 0x00007fff9196572a _pthread_start + 137
8 libsystem_pthread.dylib 0x00007fff91969fc9 thread_start + 13
Thread 4:
2 QtWebKit 0x0000000105888fe7 WTF::TCMalloc_PageHeap::scavengerThread() + 91
3 QtWebKit 0x000000010588908b WTF::TCMalloc_PageHeap::runScavengerThread(void*) + 9
Thread 5:
0 libsystem_kernel.dylib 0x00007fff8d1a9e6a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff91966f08 _pthread_wqthread + 330
2 libsystem_pthread.dylib 0x00007fff91969fb9 start_wqthread + 13
Thread 6:
Thread 7:
Thread 8:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0xbadda9a853dbbead rbx: 0x0000610000014460 rcx: 0x0000608000120960 rdx: 0x0000000000000000
rdi: 0x0000618000018650 rsi: 0x0000000107cbb800 rbp: 0x00007fff5fbff970 rsp: 0x00007fff5fbff960
r8: 0x0000000000000000 r9: 0x0000000000000009 r10: 0x0000000000000006 r11: 0x000000000037ec40
r12: 0x000060800000ed00 r13: 0x000000010486b560 r14: 0x0000610000014460 r15: 0x0000000000000002
rip: 0x000000010486b57c rfl: 0x0000000000010206 cr2: 0x000000010595dd2c
Logical CPU: 6
Error Code: 0x00000000
Trap Number: 13
Binary Images:
0x100000000 - 0x100001fff +com.DAZ.DAZStudio (4.6.1.17 - 4.6.1.17) /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
0x100004000 - 0x101924fe7 +libdzcore.dylib (1) /Applications/DAZ 3D/*/libdzcore.dylib
0x10315a000 - 0x103407fff +QtCore (4.8.4) <20B075C1-19EC-9192-3B1B-5EC80AF5E49C> /Applications/DAZ 3D/*/QtCore.framework/Versions/4/QtCore
0x1034a1000 - 0x103e59fe7 +QtGui (4.8.4) <700E3224-BA7B-DBED-6C78-A13F42C14F51> /Applications/DAZ 3D/*/QtGui.framework/Versions/4/QtGui
0x10410c000 - 0x1041fcfff +libdzcmsconnector.dylib (1) <2F8AE7EF-ED80-F373-57A3-CE514FB3C5A0> /Applications/DAZ 3D/*/libdzcmsconnector.dylib
0x104303000 - 0x104346ff7 +phonon (4.4) <395930D2-D35A-524C-B688-219A500353D3> /Applications/DAZ 3D/*/phonon.framework/Versions/4/phonon
0x10436d000 - 0x104371fff com.apple.agl (3.2.3 - AGL-3.2.3) <1B85306F-D2BF-3FE3-9915-165237B491EB> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x104378000 - 0x1045dbfff +Qt3Support (4.8.4) /Applications/DAZ 3D/*/Qt3Support.framework/Versions/4/Qt3Support
0x1046ca000 - 0x1047f8fe7 +QtNetwork (4.8.4) <27B6F9D6-F603-8D1B-A146-1DE872CA8ACC> /Applications/DAZ 3D/*/QtNetwork.framework/Versions/4/QtNetwork
0x10485b000 - 0x104932ff7 +QtOpenGL (4.8.4) <74C8061B-510E-2839-CA16-2B6A34CA0FFA> /Applications/DAZ 3D/*/QtOpenGL.framework/Versions/4/QtOpenGL
0x104976000 - 0x104b4afff +QtScript (4.8.4) /Applications/DAZ 3D/*/QtScript.framework/Versions/4/QtScript
0x104c00000 - 0x104cd1fe7 +QtSql (4.8.4) /Applications/DAZ 3D/*/QtSql.framework/Versions/4/QtSql
0x104cf7000 - 0x1060b7fe7 +QtWebKit (4.9.3) <33D29FB4-DA92-1B0C-67AE-74681EA6A1ED> /Applications/DAZ 3D/*/QtWebKit.framework/Versions/4/QtWebKit
0x106a49000 - 0x106a8cfef +QtXml (4.8.4) <4529133D-A57B-C9F6-325F-53BC0CB92542> /Applications/DAZ 3D/*/QtXml.framework/Versions/4/QtXml
0x106aa6000 - 0x106c38fef +libvshared_fat_release_x64.dylib (5.3) <1E1455EA-970D-324B-8554-04CA445BF1C6> /Applications/DAZ 3D/*/DAZStudio.app/Contents/vcomponents_x64/libvshared_fat_release_x64.dylib
0x106d0c000 - 0x107459ff7 +libvkernel_fat_release_x64.dylib (5.3) /Applications/DAZ 3D/*/DAZStudio.app/Contents/vcomponents_x64/libvkernel_fat_release_x64.dylib
0x1079cd000 - 0x107b7cff7 +libvclient_fat_release_x64.dylib (5.3) /Applications/DAZ 3D/*/DAZStudio.app/Contents/vcomponents_x64/libvclient_fat_release_x64.dylib
0x109a19000 - 0x109a19feb +cl_kernels (???) <8EBAD2BB-AC0D-4ED6-9CF8-2C277C2AF83D> cl_kernels
0x109a1d000 - 0x109a1dfff +cl_kernels (???) <728639E4-9412-4E25-A513-E3F3CACB5ED2> cl_kernels
0x109a45000 - 0x109a46ff9 +cl_kernels (???) <2A4A911B-D9C2-45FD-B92F-6DC8B819993B> cl_kernels
0x109b06000 - 0x109ba9ff7 ColorSyncDeprecated.dylib (426) <1EBD0729-A174-3EA5-B226-DE63C2E89D14> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x109d33000 - 0x109d43ff7 +libdzalignace.dylib (1) /Applications/DAZ 3D/*/libdzalignace.dylib
0x10dc3a000 - 0x10dc3bfff +libdzautofit.dylib (1) /Applications/DAZ 3D/*/libdzautofit.dylib
0x10dc3f000 - 0x10dc45fff +libdzautoshaderbakeractions.dylib (1) /Applications/DAZ 3D/*/libdzautoshaderbakeractions.dylib
0x10dc53000 - 0x10dc57ff7 +libdzeasyloader.dylib (1) /Applications/DAZ 3D/*/libdzeasyloader.dylib
0x10dc5f000 - 0x10dc69fef +libdzimageio.dylib (1) /Applications/DAZ 3D/*/libdzimageio.dylib
0x10dc80000 - 0x10dc86ff7 +libqgif.dylib (0) <5F186D56-4BD3-80BE-22C8-9703302FA988> /Applications/DAZ 3D/*/libqgif.dylib
0x10dc8b000 - 0x10dc91fff +libqico.dylib (0) /Applications/DAZ 3D/*/libqico.dylib
0x10dc96000 - 0x10dccffef +libqjpeg.dylib (0) <6A2FC8A2-A6D7-56FC-2197-97E02D043E4D> /Applications/DAZ 3D/*/libqjpeg.dylib
0x10dcd8000 - 0x10dd29ff7 +libqmng.dylib (0) /Applications/DAZ 3D/*/libqmng.dylib
0x10dd3c000 - 0x10dd40fff +libqtga.dylib (0) <8B7BDB1F-9B3A-FF3B-6B2C-871FD76D98C5> /Applications/DAZ 3D/*/libqtga.dylib
0x10dd45000 - 0x10dd9aff7 +libqtiff.dylib (0) /Applications/DAZ 3D/*/libqtiff.dylib
0x10dfe2000 - 0x10dfe5ff7 +libdzmacvideo.dylib (1) <191821A5-552D-EE03-371D-EEBE17908348> /Applications/DAZ 3D/*/libdzmacvideo.dylib
0x10dfee000 - 0x10dff7ff7 +libdzshaderbaker.dylib (1) <9D1A284C-7AE2-92C2-C9FE-492BFC174466> /Applications/DAZ 3D/*/libdzshaderbaker.dylib
0x10f0f3000 - 0x10f36fff7 com.apple.RawCamera.bundle (5.01 - 718) <6CC4A1E5-A89A-369D-96C4-7A5ED40B487B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x10f7d2000 - 0x10f7dcfff +libdzmanualshaderbaker.dylib (1) <134B088C-A0AE-41D6-7BB1-8E511E5BB7EF> /Applications/DAZ 3D/*/libdzmanualshaderbaker.dylib
0x10f7e9000 - 0x10f7f0fe7 +libdzspotrendertool.dylib (1) <8EBE4487-8B63-8C18-BC19-4BD769B4F0ED> /Applications/DAZ 3D/*/libdzspotrendertool.dylib
0x1132ee000 - 0x1132f1fe7 +libdztransferutility.dylib (1) /Applications/DAZ 3D/*/libdztransferutility.dylib
0x1146bc000 - 0x11470efe7 +libdazscriptide.dylib (1) /Applications/DAZ 3D/*/libdazscriptide.dylib
0x114786000 - 0x1147b5fff +libdzautoriggerbasic.dylib (1) <0F980582-14C2-3B33-1BB4-86C2E7150EB2> /Applications/DAZ 3D/*/libdzautoriggerbasic.dylib
0x1147df000 - 0x1147edfe7 +libdzmorphfollower.dylib (1) <9EFC9A2E-1733-F5B6-A1C9-EC8CD8649FA3> /Applications/DAZ 3D/*/libdzmorphfollower.dylib
0x115000000 - 0x11519dff7 +libaniMate2.dylib (1) /Applications/DAZ 3D/*/libaniMate2.dylib
0x1152f8000 - 0x1153a7fef +QtScriptTools (4.8.4) <019CDB27-FCB3-12EE-55AD-FE6B8B8FC7A5> /Applications/DAZ 3D/*/QtScriptTools.framework/Versions/4/QtScriptTools
0x115402000 - 0x1154dbfff +libdzassetiofilters.dylib (1) /Applications/DAZ 3D/*/libdzassetiofilters.dylib
0x1155e1000 - 0x1155f7fe7 +libdzbrycebridge.dylib (1) <22B77ABD-B0B4-DC97-E851-53139A557816> /Applications/DAZ 3D/*/libdzbrycebridge.dylib
0x115611000 - 0x11563afef +libdzbvh.dylib (1) <1904648C-000D-2D34-CD91-D8D0C3D14701> /Applications/DAZ 3D/*/libdzbvh.dylib
0x115657000 - 0x1156a2fef +libdzcolladax.dylib (1) <8DD8BB2C-22F0-4951-DF01-F9B871540FF5> /Applications/DAZ 3D/*/libdzcolladax.dylib
0x1156dd000 - 0x115973fff +libDazCollada.dylib (1) /Applications/DAZ 3D/*/libDazCollada.dylib
0x115ba7000 - 0x115c55fef +libdzcomponents.dylib (1) <81A670B3-55D3-F989-881F-817E4E259523> /Applications/DAZ 3D/*/libdzcomponents.dylib
0x115d4b000 - 0x115d8dfff +libdzcontentdbeditor.dylib (1) <6CEA9D85-4C37-3DCE-FB2E-6523FD72A7ED> /Applications/DAZ 3D/*/libdzcontentdbeditor.dylib
0x115dae000 - 0x115dfeff7 +libdzcontentlibrarypane.dylib (1) <1C45BDC1-86D9-EE6D-107E-17229CC2F160> /Applications/DAZ 3D/*/libdzcontentlibrarypane.dylib
0x115e50000 - 0x115eb8ff7 +libdzcr2exporter.dylib (1) /Applications/DAZ 3D/*/libdzcr2exporter.dylib
0x115eed000 - 0x116049fe7 +libdzcustomizedlg.dylib (1) <1697B346-94D1-4AF5-2C8B-D86A8BF7A105> /Applications/DAZ 3D/*/libdzcustomizedlg.dylib
0x116162000 - 0x116192fff +libdzdelightrenderer.dylib (1) /Applications/DAZ 3D/*/libdzdelightrenderer.dylib
0x1161b6000 - 0x116586fef +libdz3delightdll.dylib (1) <930A8E51-0D74-044F-79FA-D523DF19D738> /Applications/DAZ 3D/*/libdz3delightdll.dylib
0x1166d0000 - 0x11671cfff +libdzdformeditor.dylib (1) /Applications/DAZ 3D/*/libdzdformeditor.dylib
0x11677b000 - 0x1167c8fe7 +libdzexpexporter.dylib (1) <4788CB9C-AB04-42A3-09BF-3943B12EAEDD> /Applications/DAZ 3D/*/libdzexpexporter.dylib
0x116810000 - 0x116e71fe7 +libdzfbxexporter.dylib (1) /Applications/DAZ 3D/*/libdzfbxexporter.dylib
0x1170cf000 - 0x117709fe7 +libdzfbximporter.dylib (1) <03148036-64C3-9221-CB3C-D4603F690F58> /Applications/DAZ 3D/*/libdzfbximporter.dylib
0x117945000 - 0x1179befff +libdzfiguresetup.dylib (1) <618AB28F-A799-5937-55E5-ED904348CE4C> /Applications/DAZ 3D/*/libdzfiguresetup.dylib
0x117a40000 - 0x117a94fe7 +libdzhexagonbridge.dylib (1) <9702EA20-5325-4E5A-88DF-5A1752E9E71B> /Applications/DAZ 3D/*/libdzhexagonbridge.dylib
0x117aec000 - 0x117b8efff +libdzjointeditor.dylib (1) <850F7396-781D-0023-94B8-9F7D581E0AF1> /Applications/DAZ 3D/*/libdzjointeditor.dylib
0x117c31000 - 0x117c50fe7 +libdzlayerededitor.dylib (1) <308392F7-8E0E-8055-2AB0-C549CBB84D08> /Applications/DAZ 3D/*/libdzlayerededitor.dylib
0x117c76000 - 0x117c92fef +libdzlayerfilter.dylib (1) <61D20702-DF70-D258-48CF-87E6C11A18DB> /Applications/DAZ 3D/*/libdzlayerfilter.dylib
0x117cbc000 - 0x117cd8fef +libdzmaptransfer.dylib (1) /Applications/DAZ 3D/*/libdzmaptransfer.dylib
0x117d00000 - 0x117d18ff7 +libdzmorphloader.dylib (1) <6DF4E506-6A1F-0C75-4902-B4BFAB6FADA3> /Applications/DAZ 3D/*/libdzmorphloader.dylib
0x117d32000 - 0x117d40fe7 +libdzmorphloaderpro.dylib (1) /Applications/DAZ 3D/*/libdzmorphloaderpro.dylib
0x117d51000 - 0x117d66fff +libdzobjexporter.dylib (1) <631196FE-212F-F8C2-B5A6-6B7FCDE8290C> /Applications/DAZ 3D/*/libdzobjexporter.dylib
0x117d80000 - 0x118240fff +libdzoptitexclothbasic.dylib (1) <97A9514F-A473-7E1E-6E2B-408326165485> /Applications/DAZ 3D/*/libdzoptitexclothbasic.dylib
0x11883b000 - 0x118896fef +libdzpolygongroupeditortool.dylib (1) <2EC661C3-09E6-6E87-3B38-20612466EA1C> /Applications/DAZ 3D/*/libdzpolygongroupeditortool.dylib
0x11890f000 - 0x118921fe7 +libdzprimitives.dylib (1) <95D2A87F-00DD-6543-692E-A4356FA135CA> /Applications/DAZ 3D/*/libdzprimitives.dylib
0x11893a000 - 0x11897aff7 +libdzpropertyhierarchyeditor.dylib (1) /Applications/DAZ 3D/*/libdzpropertyhierarchyeditor.dylib
0x1189ce000 - 0x118a4cff7 +libdzpuppeteer.dylib (1) <2B45D133-8294-531D-9A34-A9685B70805F> /Applications/DAZ 3D/*/libdzpuppeteer.dylib
0x118afe000 - 0x118b58fff +libdzpz3importer.dylib (1) <1D55C708-1D15-6E97-6A93-F38A56DC24B2> /Applications/DAZ 3D/*/libdzpz3importer.dylib
0x118b95000 - 0x118bd8fe7 +libdzrenderedit.dylib (1) <063192A4-DE0D-4C61-CB9B-1B72B3FC27D8> /Applications/DAZ 3D/*/libdzrenderedit.dylib
0x118c1e000 - 0x118c37fef +libdzrenderlibrary.dylib (1) /Applications/DAZ 3D/*/libdzrenderlibrary.dylib
0x118c52000 - 0x118c5bff7 +libdzrslshadercompiler.dylib (1) <3097D5C0-8C96-34CE-C6E1-1F7378A1B088> /Applications/DAZ 3D/*/libdzrslshadercompiler.dylib
0x118c6a000 - 0x118e7bfff +libdzsavefilters.dylib (1) <5FA90379-C462-66D9-403D-D29C7312AA75> /Applications/DAZ 3D/*/libdzsavefilters.dylib
0x1190f6000 - 0x119128fff +libdzscriptedrenderer.dylib (1) <9BA34473-8AAF-971C-F357-C8F6CBE64FD4> /Applications/DAZ 3D/*/libdzscriptedrenderer.dylib
0x11915e000 - 0x119196ff7 +libdzscriptedsteps.dylib (1) /Applications/DAZ 3D/*/libdzscriptedsteps.dylib
0x1191ec000 - 0x119325fe7 +libdzshaderbuilder.dylib (1) <67708C69-959D-BF68-D7C0-AC7AB7C52984> /Applications/DAZ 3D/*/libdzshaderbuilder.dylib
0x1194c6000 - 0x1194d5ff7 +libdzshadereditor.dylib (1) /Applications/DAZ 3D/*/libdzshadereditor.dylib
0x1194f0000 - 0x1196bcfff +libdzshadermixerbase.dylib (1) /Applications/DAZ 3D/*/libdzshadermixerbase.dylib
0x11985c000 - 0x1198e1ff7 +libdzshadermixergui.dylib (1) <91349A94-03EB-6066-EF21-E0C516320A82> /Applications/DAZ 3D/*/libdzshadermixergui.dylib
0x119994000 - 0x1199a2fff +libdzsmartcontentpane.dylib (1) <881F83DB-5497-D487-47CD-E2C1F27F88E2> /Applications/DAZ 3D/*/libdzsmartcontentpane.dylib
0x1199bd000 - 0x1199e1fe7 +libdztextureatlas.dylib (1) <75BBA029-A767-FED7-FE6E-383A736AEDC7> /Applications/DAZ 3D/*/libdztextureatlas.dylib
0x119a0f000 - 0x119a31fff +libdzu3dexporter.dylib (1) /Applications/DAZ 3D/*/libdzu3dexporter.dylib
0x119a5f000 - 0x119ae1fff +libdzweightmapbrush.dylib (1) /Applications/DAZ 3D/*/libdzweightmapbrush.dylib
0x119b81000 - 0x119b88fe7 +SDK_SceneInfoPane.dylib (1) /Applications/DAZ 3D/*/SDK_SceneInfoPane.dylib
0x119b95000 - 0x119ba5fe7 +libdzdrawstyles.dylib (1) <73D5275A-D83E-D226-1AB9-EF191F1B18AA> /Applications/DAZ 3D/*/libdzdrawstyles.dylib
0x119bc7000 - 0x119ca7fff +libdzpowerpose.dylib (1) /Applications/DAZ 3D/*/libdzpowerpose.dylib
0x11c7b3000 - 0x11c7b4ffa +cl_kernels (???) <07B1F917-887D-4F22-810A-1FF944E371EC> cl_kernels
0x12e582000 - 0x12e668fef unorm8_bgra.dylib (2.3.58) <9FF943D1-4EF7-36CA-852D-B61C2E554713> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x12eb3e000 - 0x12eb59ff9 com.apple.security.csparser (3.0 - 55471) <0FA462BA-746F-3ACB-A90D-DCC7F280482B> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x12f1c9000 - 0x12f1cafe4 +cl_kernels (???) cl_kernels
0x123480000000 - 0x123480294ff7 com.apple.AMDRadeonX3000GLDriver (1.14.21 - 1.1.4) <3133F944-09A8-3B30-B8B0-1C68FC2119F2> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/AMDRadeonX3000GLDriver
0x7fff64770000 - 0x7fff647a3817 dyld (239.3) /usr/lib/dyld
0x7fff8d194000 - 0x7fff8d1b0ff7 libsystem_kernel.dylib (2422.1.72) /usr/lib/system/libsystem_kernel.dylib
0x7fff8d1b1000 - 0x7fff8d1bbfff libcommonCrypto.dylib (60049) <8C4F0CA0-389C-3EDC-B155-E62DD2187E1D> /usr/lib/system/libcommonCrypto.dylib
0x7fff8d1bc000 - 0x7fff8d257ff7 com.apple.PDFKit (2.9 - 2.9) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff8d258000 - 0x7fff8d25eff7 libCGXCoreImage.A.dylib (599.7) /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x7fff8d25f000 - 0x7fff8d26aff7 com.apple.NetAuth (5.0 - 5.0) /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8d26d000 - 0x7fff8d41af27 libobjc.A.dylib (551.1) /usr/lib/libobjc.A.dylib
0x7fff8d41b000 - 0x7fff8d4a4fff com.apple.ColorSync (4.9.0 - 4.9.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8d4a5000 - 0x7fff8d4b2fff com.apple.Sharing (132.2 - 132.2) /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff8d4b3000 - 0x7fff8d4c0ff7 libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib
0x7fff8d4c1000 - 0x7fff8d550ff7 com.apple.Metadata (10.7.0 - 800.12) <04486C95-3E49-36C4-89B6-925E925BB417> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff8d551000 - 0x7fff8d7fbffd com.apple.HIToolbox (2.1 - 695) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff8d7fc000 - 0x7fff8d823ff7 libsystem_network.dylib (241.3) <8B1E1F1D-A5CC-3BAE-8B1E-ABC84337A364> /usr/lib/system/libsystem_network.dylib
0x7fff8d824000 - 0x7fff8d950fff com.apple.MediaControlSender (1.9 - 190.4) /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x7fff8d951000 - 0x7fff8d9a8fff com.apple.ViewBridge (1.0 - 46) /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff8da27000 - 0x7fff8dd11fff com.apple.CoreServices.CarbonCore (1077.13 - 1077.13) <21324540-8B84-3333-ADB8-D3D5181D4639> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff8ddc7000 - 0x7fff8dde2ff7 libPng.dylib (1038) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8dde6000 - 0x7fff8df56ff6 com.apple.CFNetwork (673.0.3 - 673.0.3) <42CFC3DB-35C8-3652-AF37-4BCC73D8BDEF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff8df57000 - 0x7fff8df70ff7 com.apple.Ubiquity (1.3 - 289) /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x7fff8df78000 - 0x7fff8dfa5ff2 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <43A137C4-3E72-37DC-945F-92569C12AAD4> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff8dfa6000 - 0x7fff8dfaeff7 com.apple.AppleSRP (5.0 - 1) /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff8dfaf000 - 0x7fff8dfd7ffb libxslt.1.dylib (13) /usr/lib/libxslt.1.dylib
0x7fff8dfd8000 - 0x7fff8dfdafff libRadiance.dylib (1038) <55F99274-5074-3C73-BAC5-AF234E71CF38> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff8dfdb000 - 0x7fff8dfddfff com.apple.EFILogin (2.0 - 2) /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff8e04c000 - 0x7fff8e0acff2 com.apple.CoreUtils (1.9 - 190.4) /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff8e0ad000 - 0x7fff8e0d7ff7 libpcap.A.dylib (42) <91D3FF51-D6FE-3C05-98C9-1182E0EC3D58> /usr/lib/libpcap.A.dylib
0x7fff8e0d8000 - 0x7fff8e125ff2 com.apple.print.framework.PrintCore (9.0 - 428) <8D8253E3-302F-3DB2-9C5C-572CB974E8B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8e126000 - 0x7fff8e12eff7 com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <98BBB3E4-6239-3EF1-90B2-84EA0D3B8D61> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff8e12f000 - 0x7fff8e18efff com.apple.framework.CoreWLAN (4.0 - 400.45.1) <775F9444-8059-30A2-8058-7F7ACD68CCF1> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff8e18f000 - 0x7fff8e191ff3 libsystem_configuration.dylib (596.12) /usr/lib/system/libsystem_configuration.dylib
0x7fff8e192000 - 0x7fff8e1f2fff com.apple.ISSupport (1.9.9 - 57) /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
0x7fff8e262000 - 0x7fff8e392ff7 com.apple.desktopservices (1.8 - 1.8) <09DC9BB8-432F-3C7A-BB08-956A2DDFC2DE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff8e393000 - 0x7fff8e395ff7 com.apple.securityhi (9.0 - 55005) <405E2BC6-2B6F-3B6B-B48E-2FD39214F052> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff8e3dc000 - 0x7fff8e442fff com.apple.framework.CoreWiFi (2.0 - 200.21.1) <5491896D-78C5-30B6-96E9-D8DDECF3BE73> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff8e443000 - 0x7fff8e4a0fff com.apple.imfoundation (10.0 - 1000) <122D84B9-871D-3885-9D8D-840CD529028F> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x7fff8e4a1000 - 0x7fff8e4fafff libTIFF.dylib (1038) <5CBFE0C2-9DD8-340B-BA63-A94CE2E476F2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff8e777000 - 0x7fff8e77cfff com.apple.DiskArbitration (2.6 - 2.6) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff8e77d000 - 0x7fff8e82dff7 libvMisc.dylib (423.32) <049C0735-1808-39B9-943F-76CB8021744F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8e82e000 - 0x7fff8e91dfff libFontParser.dylib (111.1) <835A8253-6AB9-3AAB-9CBF-171440DEC486> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff8eb19000 - 0x7fff8ee33ff7 com.apple.MediaToolbox (1.0 - 1273.29) <6260E68B-7E50-3D49-8C0A-7145614C13D8> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff8ee56000 - 0x7fff8f0e7ff7 com.apple.AOSKit (1.06 - 176) <35525B2F-B02F-31FD-A3B2-FD6AE6D32C11> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
0x7fff8f16f000 - 0x7fff8f180ff7 libz.1.dylib (53) <42E0C8C6-CA38-3CA4-8619-D24ED5DD492E> /usr/lib/libz.1.dylib
0x7fff8f181000 -
First, that crash seems to be when you quit DAZ Studio, am I correct? It looks like something related to OpenGL/Videocard memory cleanup.
Second, can you please try to describe step by step what you do when it becomes unresponsive, or correct me if I'm wrong in this description.
You start DAZ Studio, then you want to open a saved file, but when then open file dialog appears DAZ Studio gets laggy and the open file dialog never really shows. Am I right?
Do you have any of these installed?
- Default Folder X
- Akvis Enhancer
Both fiddle with the open/save dialogs and might, In don't say the will, cause problems.
Hi,
Thanks for the blindingly fast reply (makes me slightly guilty to be slobbing out on a Friday evening).
Daz Studio opens as normal and doesn't show any errors. t can work inside the application as normal; I can browse my libraries, add objects, render things out and so on. The program works completely normally until I need to use a dialog. I've been able to get it to lock up when trying to open an existing file or save a project, as well as trying to load an image when editing a texture. It does seem to be something to do with the standard Mac file dialogs that's at the root of the problem. The dialog appears as normal, I can see files and folders inside the dialog window, but it then closes on its own and all the onscreen widgets stop working.
After it becomes unresponsive there's nothing I can do in the program apart from force it to quit through the Apple menu -> Force Quit dialog. If I left it alone, Daz Studio would just sit there quite happily. I've not been able to get Daz Studio to crash even after all the widgets become unresponsive. When I use Force Quit, Mac OS produces a standard report containing all of the information I just posted.
I've not got either Default Folder X or Akvis Enhancer installed. The machine that's causing the problem is a 2011 i7 iMac with 8GB RAM running Mac OS 10.9. AFAIK it is completely up-to-date.
I have a second Mac here (2012 MBP also running 10.9) if you'd like me to install Daz on another machine.
Mike.
Can you please "lock it up once more", then in Activity Monitor select DAZ Studio (which probably says "not responding" and do Sample. (I can't screen shot how as I'm running OS X in Swedish.
I think the button says Sample application or something similar. Save the sample as textile and if it is not to long, post here, otherwise PM me and I'll give you an email to send jt to. The sample will most likely tell me where it gets stuck.
OK, thanks for the sample. It shows what I suspected, the code gets an unhanded exception and dies deep inside the file filter callbacks.
Now a couple of related questions, sorry but thats the best way of solving things unless you can access the machine directly.
What kind of disk are you using and do you have some kind of "disk performance enhancing" software installed? Is it the local disk or a remore NAS, a removable disk like a USB disk? Have you waited a few minutes to see if it fixes itself, can be a very poor disk performance.
Basically why I ask is that the way it works (I don't know the exact code of DS but have been programming the Mac since the dark ages and before that) is that for every file that is in the directory you opens from, the file filter will only enable files that the calling software (in this case DAZ Studio) has said are OK files. Somewhere deep inside this mechanism fails for some reason, could be numerous things, but most likely there is some kind of other software doing it's own filtering and they mismatch and clash and cause this system exception.
It can be that the finder database had been severely corrupted. Disk Repair (show errors) in Disk Utilities might answer that, and a Repair could fix that, so please try that, and try your other Mac and see it it works there. Also, there is an update to DS (that I know haven't fiddled with this part of the system but it might help to install that.
And last, do you have any external plugins installed for DAZ Studio (DS), like Reality or something else?
Hi,
Good news, I've got it working again.
As you suggested I did a reboot into the Disk Utility and then a full disk permissions repair which took forever and didn't report any issues, but Daz is up and working again.
Thanks so much for all your suggestions, I really appreciate the huge amount of time you spent trying to fix it.
Mike.
Great to hear it was fixed!
Have fun with DS, welcome to the world of 3D!
Hi, just wanted to share a quick tip to make installing DAZ content a lot easier. If you ever have something that is zipped up in a folder hierarchy like: (DAZ Studio stuff)
My Library ▸ data ▸ etc
Or: (Poser stuff)
Runtime ▸ libraries ▸ etc
Instead of drilling down through each subfolder and manually copy/pasting files, or launching a Windows VM to take advantage of its native Merge command, you can do the same thing on a Mac!
WARNING: Does require you to use Terminal.app but it's super easy
Assuming your content is arranged so that it's all contained in one Content or My Library folder, with Runtime inside of it, all you need to do is use the ditto command:
1. Type ditto with a blank space directly after it
2. From Finder, drag the source folder you want to merge (Runtime, My Library, etc) onto the Terminal window. You will see a green plus icon. You should see it automatically fill in the file path for you. It will also automatically type in a blank space so do not add another manually.
3. From Finder, drag the destination folder you want to merge WITH (your content Runtime, My Library, etc folder). It's very important these are named the SAME! It is not case sensitive however so don't worry about that. You will see it automatically fill in the destination path for you.
4. Press Enter/Return. You will see a little filled in square while it is copying the files over. You will know it's done once it moves down a line.
That's it!
I created RendoInstall, you can find it here: http://4eyes.code66.se/?page_id=7463 which does that but with a GUI. I also have some other tools for Mac users there as well.
And in 10.8 (might even be 10.7) or later you can option drag a folder to a folder and you will get a dialog asking merge or replace.
Hi everyone,
First off, I have only just come back to Daz again after being away for close to a year. Before I had a PC, but I have upgraded to a iMac now. There is a problem that I hope you can help with.
Due to upgrading my extra hard drive, I had to uninstall Daz3d and reinstall again. When I did, I could not find any smart content! Everything is installed ok, but I use the smart content a lot. So can someone please tell me how to get this back again?I have reimported the meta data again, but nothing.
Thanks for your help. :)
