Alembic "unknow error"
Hello,
I want to export a model to 3ds max using the Alembic exporter but there are some problems. When I try to export the Genesis 8 model without clothes it works fine and even with some clothing on it seems to work the way it should, but when I add a jacket or blouse the exporter says "Unknown error occurred while exporting file". So I cannot export the model with the clothes I want and I can't figure out why. Does anyone has experience with this?
I could really use some help because I need this to work!
Thanks.
  • Is it specific items? Are they perhaps not standard fitted items but, for example, OptiTex dynamics?
  • wolf359wolf359 Posts: 3,955
    Hi check your naming conventions,
    According to Daz studio user "RobheadArt"
    Multiple items with the same names are still causing him
    "unknown errors"  importing  to houdini as of DS version 4.11
    https://www.daz3d.com/forums/discussion/298831/alembic-exporter
    OptiTex dynamics?
    Optitex Dynamics theoretically should not cause Alemebic export problems if the simulation is "frozen" to morphs
    before export.
    OptiTex dynamics?
    before export.
    I was just considering possible variables.
  • Does the blouse/jacket have buttons that are props connected via Rigid Follow Nodes?  If so, try removing the buttons for the scene.
