(Commercial) NOW IN STORE - Sickle Rigging And Morphing System
11517192021
  • DoctorJellybeanDoctorJellybean Posts: 10,091
    How about adding/converting Dawn clothing for Genesis?
  • scal.64.psscal.64.ps Posts: 140
    +1000
    +1000
    That would require me to be able to create a Dawn clone for Genesis. I doubt seriously whether Hivewire's licensing allows that. DAZ has let me do a G2F clone for Genesis mainly because both are their products and I sold it in their store.
  • BendinggrassBendinggrass Posts: 1,388
    Wilmap is basically right, but for clarification:
    SRMS is for Genesis 1 only.
    There IS a product that helps with Genesis to G2F conversion. It is the Sickle Dress Rig G2F, which is here: http://www.daz3d.com/sickle-dress-rig-genesis-2-female
    I wouldn't call it a true SRMS G2F because it adds no FBMs. I have a full bodysuit/dress setup for SRMS G2F that is unreleased because of a problem that DAZ has not yet fixed with Studio (you can't conform G2F clothing to other G2F clothing without triggering an Autofit prompt, a problem that does not exist with Genesis).
    If you want breast help with G2F, your best bet is the Breast Fixes morph pack: http://www.daz3d.com/clothing-breast-fixes-for-genesis-2-female
    So does this mean I can then convert G4 clothing to G6 clothing by using Sickle Rigging and Morphing System, and then going to Sickle Dress Rig Genesis 2 Female ?
    Thanks.
    R
    Thanks.
    R
    Hoo boy. I haven't tried that whole thing yet. I would expect yes, but there would be more artifacts from a double conversion.
  • inspired_designerinspired_designer Posts: 63
    I have a question for Sickle Rigging And Morphing System
    Can you make .obj customised clothes and shoes on another program and use your system to fit the clothes on Genesis 2?
    edited September 2013
    No, the product is for G1.
    Post edited by SickleYield on
    The more I learn about your products the more I am amazed by all you can do with them.
    I have a lot to learn......
    Thank you for your purchase!
  • JayfeatherJayfeather Posts: 70
    I'm wondering how well this system works on loin-cloths and skirts with slits going up the sides. I've noticed anything that's meant to hang in the front and/or back has some bad stretching when converted to Genesis. I would be VERY interested in Loin-cloth preset for Genesis conversion.
    Badly, unless it's an item moved only with morphs. Front/back slit items normally require special rigging which can't be retained.
    The way to cope with that would be to have a native genesis item that has such a rig, and add transferring from it as an extra step AFTER the item is converted AND saved. That way it hopefully keeps its own morphs.
  • barbultbarbult Posts: 27,444
    I'm using the new Genesis 2 Female Clone for Genesis with SRMS to autofit G2F clothes to Genesis. I'm having problems. I don't have many G2F clothes, but I tried the Paige Dress from the DAZ store. I am using DS 4.6.0.18. The result was terrible. Please help! I must be doing something wrong.
    Image 4 is what Paige Dress looks like on Genesis 2 Female.
    Image 3 shows the settings I used to autofit it to Genesis Basic Female
    Image 2 shows the result I got using SRMDressBase.
    Image 1 shows the result I got selecting None.
    Edit: DAZ reversed the order of the images, so I changed the text above.
    817 x 995 - 190K
    806 x 966 - 196K
    1208 x 984 - 467K
    857 x 1010 - 180K
    Post edited by barbult on
    Does it do the same thing if you follow standard SRMS procedure using Transfer Utility, save it to library, and reload it?
    I tried the transfer utility method, selecting SRMDressBase for the template. After saving the dress asset, deleting the dress and reloading the dress, the results look different than the autofit, but still not good. The result looks pretty much like what I got when selecting none for the projection template. (Neither one looks good.) I will attach images of the settings I used and the result. Thanks for help.
    1056 x 1272 - 89K
    1344 x 1323 - 143K
    Here is another image of the Transfer Utility result with the SRMDressBase projection template. This shows the bump between the breasts and on the skirt that poke out to the front.
    625 x 661 - 35K
    586 x 1264 - 61K
    Oh wait.
    It looks like you're doing this on a morphed Genesis? That's probably not going to work well, either.
    Oh wait.
    ARGGGGGG!! You are right! I am doing Transfer Utility on Basic Female. I know better. Thanks for catching that. I'll try again with the base Genesis.
    But shouldn't autofit have worked on a morphed Genesis?
    barbult said:
    Oh wait.
    Not with SRMS. Morphed templates change a lot of the rules.
  • vwranglervwrangler Posts: 5,042
    For what it's worth, I think Paige Dress may just be one of those things that doesn't take transfer well. I tried it on an unmorphed Genesis using SRMS, and while it didn't look quite that bad, the skirt was a lumpy, and all of the motion morphs were dead.
    EDIT: I thought the OBJ export method would work, but you'd need a V6 shape for Genesis for that to work, and that's not available.
    Post edited by vwrangler on
    Thanks for checking it, vwrangler. I tried again with the base Genesis and the transfer utility. The final result after saving the asset and reloading it onto the Basic Female looks about the same. I still have the lump in the skirt and between the breasts.
    Have you had success with the Genesis 2 Female Clone for Genesis with other garments? I just don't have much to test, because I haven't really bought into the G2 scheme yet. I thought that if I could use the clothes on Genesis, I would have a reason to buy G2 clothes. I'll see what else I have that I can try. I have a couple freebies.
    Oh, and you are right - all the skirt motion "Pose Controls" are dead on the Genesis version. I hadn't even gotten as far as trying that.
    Pose controls in general won't transfer because TU doesn't register them as "morphs," has been my experience.
    Some minor breast distortion is indeed normal, but not to the extent you're getting - it's so slight as not to be visible on the garments I used for testing and to make the promos for the product.
    I have now tried the Japanese Sailor Uniform freebie available here: http://amarijun.wordpress.com/2013/07/13/daz-studio-genesis2-female-sailor-uniform-recte/
    I used the transfer utility with the base Genesis. I used SRMDressBase for the skirt and SRMBodysuitBase for the jacket. After saving the asset, I reloaded it on the Base Genesis and also on Basic Female. In both cases I have the lump in the crotch area and distortion around the breast area. SickleYield, can you try this freebie and see if you get better results, to confirm that I am either doing something wrong still or have some other problem in my DS environment?
    1041 x 1257 - 275K
    1073 x 1269 - 260K
    1319 x 1315 - 348K
    1218 x 1290 - 353K
    I haven't had that much to transfer from G2F to Genesis. It worked fine on Frivolous Forties, except for the shoes, but that's not a dress. Other than that, most of my transfers have been from Genesis to G2F or V4 to G2F. I can try it on the G2F Evening Gown and see what happens.
    Here's what mine looks like autofitted (autofitted, mind you) with Basic Female on and the SRMDressBase and SRMBodySuitBase templates chosen (and G2F clone, of course).
    I turned up smoothing a little and it pretty much takes care of the distortion, but the crotch thing otherwise does happen. It's just minor in most outfits and goes away with smoothing samples up to 8+.
    707 x 924 - 175K
    SickleYield, thanks for trying the Sailor outfit. I tried and can get similar results with autofit, SRMS, and smoothing 8, so I guess I don't have anything wrong with my system. Some clothes must just not convert well.
    What do you think causes the crotch bump in skirts and dresses? Is it a template weight mapping issue or a morph issue? Is there something that can be improved in the clone to eliminate that?
    630 x 883 - 44K
    I suspect it's a function of the difference in crotch height between default Genesis and default G2F, and as such, probably an artifact of the base conversion. If it can be improved at all, it'd be the clone. I will faff about with it in the next week and see if I can do any better, but I wouldn't hold my breath. Sometimes you run into something like the G1/V4 foot difference and it just can't be optimal.
    Thank you very much for looking into it. I wish you good luck in finding something simple to improve.
    I tried the Evening Gown G2F. I tried three conversions, one Transfer Utility and two Autofits. What's going on can best be seen with the underdress. All three transfers had the crotch issue to some degree. Transfer Utility sticks a fairly large lump between the breasts, for some reason. Autofit does better, but it is still there to some degree. It's best with the MFD as the autofit donor, but then, of course, we get ultra stretchy cling wrap. Didn't do anything with additional smoothing on any of them, since I wanted to see how the default worked. (Also, Evening Gown G2F starts with 10 smoothing iterations as its default anyway.)
    After trying various things, I think it's safe to say that Transfer Utility is not overfond of G2F. What does TU do that's so different from Autofit?
    1958 x 896 - 254K
    If I knew, I would tell you. I found by experiment that it's possible to sometimes get different results with one than the other, but knowing why would probably require knowledge of the function of the actual code, which I do not have.
