Anybody still use the older Genesis figures?
2»
  • IvyIvy Posts: 7,165
    Yes I use Genesis still
  • GreybroGreybro Posts: 2,690
    edited January 2019
    I do occasionaly still use all of the Genesis figures from time to time wit G3 qnd G8 being my main stay.
    Post edited by Greybro on
  • Matt_CastleMatt_Castle Posts: 3,206
    From time to time - although I got started with Daz in the G8 era, I've picked up a few G2 characters. A particular favourite is a retextured/slightly dial spun blend of Girl 6 and Ysabeau 6 that's my go to when I want a slightly stylised character.
  • cathan01_wwg1wgacathan01_wwg1wga Posts: 381
    edited January 2019
    Though im concentrating on animal and nature renders at the moment, i still use and purchase characters from generations 3 and 4 and genesis 1 and 2. Only genesis 3 charas i purchased were anime based (star 2 and scifi anime character morphs) and ball joint doll bundle; for gen 8, only grabbed sakura and chimpanzee. I dont care about ultra realism for my characters since i do a lot of artsy postwork and they're easier to render on my low tech laptop and older mac. Purchased a few of raiya's v4 and m4 characters, silver and countesses v4 characters and two aiko 3 characters from rendo in 2018. Still good figures IMO.
    Post edited by cathan01_wwg1wga on
  • tkdroberttkdrobert Posts: 3,636
    I still use M4, V4, G1...it all depends on the render.  I have a lot of clones that allow me to swap cloths and IRAY scripts to convert the older models.  Sometimes M4 and V4 look better than G8.
  • I still use V4-G2, nothing higher, and only one male G2 at that.  Having invested in clothes and morphs they do what I need.  I still use 3Delight as well, never iRay.  I do have a few monsters for one-shots in the G3/8 category, but I find them very frustrating because unless I start buying more morph sets, there isn't much I can do to tweak them, so they are very 'out-of-the-box', which bugs me.  I do character work, so there really isn't much incentive to change generations once a character is designed - redesigning in a different generation can be painful.  I did move a V4 character to Genesis... but it isn't perfect, and I can see the difference and it drives me nuts!  Wouldn't have bothered except there were certain outfits I wanted to be able to access without too much pain, so now I switch her back and forth depending on the clothing for the scene.  Genesis seems to have had a lot of support when it happened, so there is very little I can't accomplish with Genesis and its add-ons, and now it is even cheaper to pick up bits, so I continue to expand its possibilities even now.  New V4 skins are still being made, which gives a lot more potential variety than the current generations.  When you're doing characters, variety is everything (eyebrows... it all comes down to the eyebrows!)
    edited January 2019
    Lots of older gen charas, textures, and clothing available as Daz3d freebies and discounted on a regular basis and numerous free outfits created for generation 3 and 4. I can save my money for dinosaurs and animals and gen8 animal morphs.
  • sapatsapat Posts: 1,735
    edited January 2019
    I still like using the older figures because i love the Creature Creator packs. Turn a dial and you can go from a hag to a cat.  Big downer that those were dumped for newer figures.
    This is the cat morph for V.2.. Done in Poser in 2008.
    521 x 545 - 54K
    Post edited by sapat on
  • DustRiderDustRider Posts: 2,908
    Depends on what I'm doing,and what I need. But yes, I do still use Genesis and G2, but seldom use V4 anymore (though I do use bits and pieces her cloths and accesories quite a bit). With Carrara I typically use Genesis or G2. I definitely use G3F and G8F more now, but I still find the older models useful, but they do tend to need more shader work to look good in Iray.
  • N-RArtsN-RArts Posts: 1,609
    I prefer the older models over G8. My main Daz couple are G3, but I still use G2 and Aiko 3. In fact, I did a Reality render of Lilith 6 about a week ago. It was just a test, but I intend to do more renders of her in the future.
  • vrba79vrba79 Posts: 1,548
    I use Genesis 1 almost exclusively. You can't beat it for male and female stylized figure parity.
    Wow I really thought I was the last man standing, using G1, nice to know I'm not alonelaugh
  • pwiecekpwiecek Posts: 1,598
    edited January 2019
    I used to base my character use on the clothing. I had clothing for V2, MGPT and otheres that just wouldn't convert well. That problem has mostly gone away since Crossdresser 4 came along. Now, I will hang on to a character if there is a morph that I can't move to something else. (For instance Bucky for Toon Generations 2 over at Rendo. I also have a very pretty character for the original Sara that doesn't work with version 2).
    Oh yeah, I still use poser a fair amount, so Genesis 2 is the limit on that.
    Post edited by pwiecek on
  • Still use G1 occasionally, especially for monsters or distant shots. I use 2/3/8 about evenly. I sometimes use V4, though I am building an upconvert library with some V4 stuff converted to G2.
  • JOdelJOdel Posts: 6,322
    I use G8/G3 for Toons and semi-Toons. But for regular stylized illustrations I'm still with G1.
  • PsychoNautPsychoNaut Posts: 63
    edited February 2019
    Mostly Genesis 3 for my main OC "Candy Lan:"
    1333 x 2000 - 1021K
    Post edited by Chohole on
  • Noah LGPNoah LGP Posts: 2,617
    I only use the maps of the old Millennium/Genesis generations.
  • I use everything back to Generation 2 (Michael 2 era, not just Genesis 2 [though I use that too]). Here's a render I did just a bit ago of Hiro 3 as Stratus, in Wildheart and the Hiro Hair.
    Hiro 3 as Stratus McCleod in Hiro Hair and Wildheart
