I just tried it. With the smoothing, I get some bulging from the smoothing but no broken seams. Perhaps try converting again with the foot placed differently?
Would you be able to post a screenshot of the settings you used so I can try to get as close to same settings, so far nothing I am trying is working. I either get the seams separating or the shoe totally doesn't fit when the foot pose is applied.
this is the first clothiing item I have had trouble converting so far, the other footwear I converted worked fine this time with the exception of the lingerie set I tried to do when this converter first came out.
I used 31, -31 on the Foot Poser dialog. This looks WAY above the shoes but when the pose for the Abigail shoes are applied, it is almost perfect even without smoothing (probably 32, -32 would be even better).
ok thanks I will try those numbers and see what I end up with
thanks so much for the help @RiverSoftArt I used 31.28 , -32.28 and adding a smoothing modifier and it worked perfect! Now I see how you don't always need to put the foot right into the shoe, before I was dialing it until the toes were right inside the toe of the shoe. I am sure I will have much better success with problematic shoes going forward.
Great! I was having problems with Abigail shoes too - now I've gone back and reconverted and they look so much better.
We should share settings for difficult shoes. I think it could help a lot of people.
Great idea - I'll try to note what settings I use next time I do some shoes so that if they turn out well I could "publish" them.
Me too, that's a great idea. One I am having issues converting now is Diamand and stud boots by chungdan - if anyone has had luck converting these i would appreciate some help on them.
So with the diamond and stud boots, they did convert ok but when I use a pose I have to pose v8 and then use the same pose on the boots. The boot are parented to G8
Is there a question?
Just stating how I got it to work, but I am wondering why I have to use the pose on the character and then on the boots , instead of the pose setting both objects at the same time like posing usually work.
Now I am trying to convert Country girl boots and I asked the script to use the foot dialogue box and it didn't even come up, it just said the boots converted in 4 sec. It seems that after I converted a few thing quit working correctly as the first few outfits and shoes converted ok.
This is what my log file said
21:15:24 GMT-0600 (Canada Central Standard Time): Executing Script
21:15:25 GMT-0600 (Canada Central Standard Time): Selecting Preset: E:/My Daz Library/People/Genesis 3 Female/Clothing/Country Girl/Country Girl Boots.duf
21:15:25 GMT-0600 (Canada Central Standard Time): Converting clothing from E:/My Daz Library/People/Genesis 3 Female/Clothing/Country Girl/Country Girl Boots.duf to E:/My Daz Library/People/Genesis 8 Female/Clothing Converted G3F/Country Girl/Country Girl Boots.duf
21:15:27 GMT-0600 (Canada Central Standard Time): Country Girl Boots is of type Follower/Wardrobe/Shoe
21:15:28 GMT-0600 (Canada Central Standard Time): Copy Icons from E:/My Daz Library/People/Genesis 3 Female/Clothing/Country Girl/Country Girl Boots.duf to E:/My Daz Library/People/Genesis 8 Female/Clothing Converted G3F/Country Girl/Country Girl Boots.duf
21:15:28 GMT-0600 (Canada Central Standard Time): Copy Categories from E:/My Daz Library/People/Genesis 3 Female/Clothing/Country Girl/Country Girl Boots.duf to E:/My Daz Library/People/Genesis 8 Female/Clothing Converted G3F/Country Girl/Country Girl Boots.duf
21:15:31 GMT-0600 (Canada Central Standard Time): Execution Complete.
The problem is that the type is not footwear, it is Follower/Wardrobe/Shoe. You need to use the Force Convert Footwear button.
Stupid question maybe but: what decides if the script will use the available foot pose in a product or not?
First, the item must be identified as footwear (or use Force Convert Footwear button). Then, it gets all the products that file/footwear is contained in, and searches for an asset with "foot" and "pose" in the name.
I was wondering becuse with a few sets it won't use the existing foot pose, but I just figured out why.
I noticed that sometimes the vendor just copied the foot pose from another of their sets and just renamed it without resaving it, like Minx outfit for example where the foot pose duf file has a different id inside the duf file (ID in Minx foot pose duf file is Bra and panty lingerie set foot pose but should be Minx outfit zfoot pose). Resaving the foot pose or just edit the id in the foot pose duf file fixes this
Oh awesome! Yup that would do it. The CMS doesn't match the file and misreports it.
Hi! Love the product but I'm still having a problem with the Firebride Dress. I was hoping the converter would solve it. Dang!
Is there an extra step I can take to make it handle height changes with G8F? It did the same with the standard auto-fit.
Thank you! :)
Strange, it works for me. You should try to convert it again. Just in case, restart DS, delete the My Library/Data/Arki/Firebride directory, and reconvert.
(Edit: Make sure you use plain, vanilla, Genesis 8 Female for the conversion)
My bad. I re-read your post. You said height, not scaling. Yes, I have the same issue. Sorry.
Thank you! :)
All good! I noticed it does it with Hunter Gear for G3M too. Again, a height thing. Not a major issue - was just curious to see if there was an easy fix! :)
Thank you! :)
I had that problem with a few items, Changing Fit to Mode to Auto Follow Transformation sorted it :)
Thank you! :)
This will be amazing once I get the converted clothing to show up in DS. That is where I'm having trouble: the files are created in the location you recommended, but they don't appear in Smart Content or the G8F Clothing directory in Content Library.
This is also the case for the G2M to G8M converter. I started with this process on the Royal Guard product. The converted files are there in "D:\Documents\DAZ 3D\Studio\My Library\People\Genesis 8 Male\Clothing\Royal Guard", and I tried everything from refreshing DS, updating metadata, closing/opening DS, and restarting my computer, but nothing appears in DS.
So I thought I'd try the G3F to G8F converter on the Alicia Armor Outfit. The converted files are in "D:\Documents\DAZ 3D\Studio\My Library\People\Genesis 8 Female\Clothing\Alicia Armor Outfit", but don't show up in Smart Content or Content Library.
Any help you can provide would be great. Here is the log for the Alicia Armor conversion:
12:39:55 GMT-0800 (Pacific Standard Time): Executing Script
12:39:55 GMT-0800 (Pacific Standard Time): Selecting Preset: D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Gauntlet.duf
12:39:55 GMT-0800 (Pacific Standard Time): Converting clothing from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Gauntlet.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Gauntlet.duf
12:39:56 GMT-0800 (Pacific Standard Time): Alicia Armor Gauntlet is of type Follower/Wardrobe/Gloves
12:39:56 GMT-0800 (Pacific Standard Time): Directory does not exist: D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit
12:39:59 GMT-0800 (Pacific Standard Time): Copy Icons from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Gauntlet.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Gauntlet.duf
12:39:59 GMT-0800 (Pacific Standard Time): Copy Categories from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Gauntlet.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Gauntlet.duf
12:39:59 GMT-0800 (Pacific Standard Time): Cannot find assets for new preset D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Gauntlet.duf
12:40:00 GMT-0800 (Pacific Standard Time): Selecting Preset: D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Belt.duf
12:40:00 GMT-0800 (Pacific Standard Time): Converting clothing from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Belt.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Belt.duf
12:40:01 GMT-0800 (Pacific Standard Time): Alicia Armor Belt is of type Follower/Wardrobe/Full-Body
12:40:03 GMT-0800 (Pacific Standard Time): Copy Icons from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Belt.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Belt.duf
12:40:03 GMT-0800 (Pacific Standard Time): Copy Categories from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Belt.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Belt.duf
12:40:03 GMT-0800 (Pacific Standard Time): Cannot find assets for new preset D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Belt.duf
12:40:03 GMT-0800 (Pacific Standard Time): Selecting Preset: D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Boots.duf
12:40:03 GMT-0800 (Pacific Standard Time): Converting clothing from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Boots.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Boots.duf
12:40:03 GMT-0800 (Pacific Standard Time): Alicia Armor Boots is of type Follower/Wardrobe/Footwear
12:40:06 GMT-0800 (Pacific Standard Time): Copy Icons from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Boots.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Boots.duf
12:40:06 GMT-0800 (Pacific Standard Time): Copy Categories from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Boots.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Boots.duf
12:40:06 GMT-0800 (Pacific Standard Time): Cannot find assets for new preset D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Boots.duf
12:40:07 GMT-0800 (Pacific Standard Time): Selecting Preset: D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Pants.duf
12:40:07 GMT-0800 (Pacific Standard Time): Converting clothing from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Pants.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Pants.duf
12:40:07 GMT-0800 (Pacific Standard Time): Alica Armor Pants is of type Follower/Wardrobe/Pant
12:40:07 GMT-0800 (Pacific Standard Time): Copy Icons from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Pants.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Pants.duf
12:40:07 GMT-0800 (Pacific Standard Time): Copy Categories from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Pants.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Pants.duf
12:40:07 GMT-0800 (Pacific Standard Time): Cannot find assets for new preset D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Pants.duf
12:40:08 GMT-0800 (Pacific Standard Time): Selecting Preset: D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style01.duf
12:40:08 GMT-0800 (Pacific Standard Time): Converting clothing from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style01.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style01.duf
12:40:08 GMT-0800 (Pacific Standard Time): Alicia Armor top_Style01 is of type Follower/Wardrobe/Shirt
12:40:14 GMT-0800 (Pacific Standard Time): Copy Icons from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style01.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style01.duf
12:40:14 GMT-0800 (Pacific Standard Time): Copy Categories from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style01.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style01.duf
12:40:14 GMT-0800 (Pacific Standard Time): Cannot find assets for new preset D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style01.duf
12:40:15 GMT-0800 (Pacific Standard Time): Selecting Preset: D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style02.duf
12:40:15 GMT-0800 (Pacific Standard Time): Converting clothing from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style02.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style02.duf
12:40:15 GMT-0800 (Pacific Standard Time): Alicia Armor top_Style02 is of type Follower/Wardrobe/Shirt
12:40:20 GMT-0800 (Pacific Standard Time): Copy Icons from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style02.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style02.duf
12:40:20 GMT-0800 (Pacific Standard Time): Copy Categories from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style02.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style02.duf
12:40:20 GMT-0800 (Pacific Standard Time): Cannot find assets for new preset D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Top Style02.duf
12:40:21 GMT-0800 (Pacific Standard Time): Selecting Preset: D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Short.duf
12:40:21 GMT-0800 (Pacific Standard Time): Converting clothing from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Short.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Short.duf
12:40:21 GMT-0800 (Pacific Standard Time): Alicia Armor Short is of type Follower/Wardrobe/Pant
12:40:22 GMT-0800 (Pacific Standard Time): Copy Icons from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Short.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Short.duf
12:40:22 GMT-0800 (Pacific Standard Time): Copy Categories from D:/My DAZ 3D Library/People/Genesis 3 Female/Clothing/Alicia Armor Outfit/Alicia Armor Short.duf to D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Short.duf
12:40:22 GMT-0800 (Pacific Standard Time): Cannot find assets for new preset D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 8 Female/Clothing/Alicia Armor Outfit/Alicia Armor Short.duf
12:40:22 GMT-0800 (Pacific Standard Time): Execution Complete.
Edited to add that I'm on the latest version of DS, 4.10.0.123 Pro 64-bit for Win 10 Pro, and I use DIM to install product.
They should be in Smart Content->Files (the converted files are part of Local User product).
@RiverSoftArt which conversion method did you use, I tried all 3 methods and got the same result
I used the Foot Poser dialog, but I probably set it up slightly different than you.
Excellent! I am glad it worked for you.
That is not one I have.
Yeah, that is weird if I understand you.
Thank you! :)
That did not work for me.
