My Renders, Now I can go to bed
2456717
  • XaatXuunXaatXuun Posts: 874
    getting closer with the lighting I'm searching for
    1000 x 1165 - 423K
    new model Pirya
    and
    a Opps, for some reason Auto fit just would not fit , I have used this before on other models, and didn't have this problem.
    no matter,, kinda like the unique look of how it is, just wish I knew how to make clothing, I would try for something close to that
    1000 x 1165 - 298K
    forgot to finish this one, I was crashing trying to render with the uber lighting. I was looking through my saves saw it, removed the uber lights and used a preset i created a while back, and render just fine
    Agnes and a new friend
    1200 x 1542 - 677K
    keep forgetting to try that Cartoon shader, so while I had the Agnes and friend still up I thought I give it a try .. I see I need to read how to use it ;)
    1200 x 1542 - 347K
    something I was trying out, some mish-mashing, giving this model some dragon wings from the sub dragon
    seeing I can do it, I may attempt some more
    for now the first attempt
    1000 x 1165 - 574K
    new
    Alice
    wanted a little darker skin, but it came out kinda dull .. it was late, so not done yet
    1000 x 1231 - 530K
    was listening to some Trentemøller, decided to create a new model, only have the head done, so I'm sure I can call this WiP
    Toni
    no lighting was used, just a render from DS 4.5
    1200 x 1077 - 363K
    decided to stay up a lil longer, this time with Explosions in the sky playing, and get some more work done on Toni
    Thought I as basically done on the shaping, but I didn't notice, till after the render, Toni has more of a sixpack then I wanted, I was looking for tone, . . oh well, I'll adjust later, going to bed after I press Submit
    Added lights I have save for preset. I still would like to adjust the skin tone a bit, and see what it'll look like using UE2
    for now this is where I be at
    1200 x 1077 - 650K
    yesterday I went ahead and updated to 4.6 and added Genesis 2 male and female
    seems 4.6 is friendlier to my machine .. I didn't try with the UE lights, but I did use the "Surfer Guy Beach Lights"
    need to see about fixing that jacket
    my bad for over seeing that before doing the render
    1200 x 1487 - 1M
    looks like I need to find what I had done with the render settings.
    Hyon and Toni
    1200 x 1487 - 723K
    edited February 2014
    Waiting for the night
    Toni again
    I should start learning Post work :smirk:
    1200 x 1487 - 529K
    Post edited by XaatXuun on
    well, I gave it a try, using Gimp
    just some random filters, it was just .. oh what does this do . . so I really could not say what I did, . . I do recall going Photocopy, but the other stuff I forgot
    1200 x 1487 - 742K
    one thing led to another
    Basic Genesis Female a couple dials , was just to be a test model I can adjust every time I want to test something , like creating poses.
    in this case a freebie clothing, and using some different shaders
    then I added the back drop . . then the Sampan, kinda like it, so thought I share, might see what more I could do with it
    651 x 745 - 251K
    took a break from gaming
    something new
    Niya
    took me longer then I thought it would getting the skin tone, still not totally satisfy with it
    I used the beach and lights that came with Genesis 2
    1400 x 1642 - 1M
    been a while again, hasn't it ..
    well here is something I just did
    Piper
    1200 x 1407 - 534K
    1200 x 1407 - 696K
    1200 x 1407 - 672K
    while waiting on a download I played with some dials
    now I have a
    Eloise
    1200 x 1407 - 701K
    Verna
    1200 x 1649 - 695K
    1200 x 1318 - 638K
    I should had went to bed, but I wanted to try a couple things
    1250 x 1677 - 678K
    1200 x 1414 - 595K
    just realized, I don't have any guns
    so just practicing poses, after I discovered that .. DOH!!!
    1200 x 1510 - 745K
    1200 x 1510 - 796K
    couple others before I go to bed
    1300 x 1635 - 836K
    1400 x 1761 - 1M
    1300 x 1635 - 896K
    edited September 2014
    wanted to see if I can render using Dreamlights Perfect-Escapes . . just could not get it, had to remove some Obj. so it's just the lights and skydome .. I tried
    My machine is just too old out dated, still have to keep things basic
    1200 x 1510 - 590K
    something happened to Verna . . just like the other models I dial in . . the save is not the save . . like some one turned off my D-forms or settings, and they have this more default look.
    So for something to do .
    I started Frigg
    still WiP .. see if she can last as long as Verna did
    using a preset lighting that came with DAZ
    1400 x 1458 - 746K
  • Richard HaseltineRichard Haseltine Posts: 108,437
    If you are using DFormers, how are you saving - as a scene/scene subset or as presets?
    As scene
    but it was from a scene subset I loaded last (if I understand it correctly )
    before I created the d-forms, I was just rescaling, and those would not stay. this was the first time I saw a d-form not load from the save, only part of it.
    I have the d-form saved as a preset to use on other models (it's not perfect but better then trying to rescale)
    I'll survive, and go back to Verna and see if I can correct the bad . .. just a frustrated night to load up one's favorite dialed in Model, to find the work that was done a week earlier, was not there anymore.
    The d-form preset still works, used it on Frigg
    I think it is in the scaling dials that changed on me, I may had blurted out D-form outta frustration
    I should check Verna's other saves . . I have in saved in 2 others . .or was it 3 others
  • starionwolfstarionwolf Posts: 3,670
    Nice renders of women in skimpy outfits. I like the lighting.
    used an earlier save of Verna
    different skin, this one I have to play with the colors to make her more alive
    I'm going to see if I can do any post work. need the practice, I'll post that later after tinkering with it in GIMP, Still don't know how , but if I don't at least try every once in a while I probably will not improve
    1200 x 1326 - 687K
    I could had sworn I replied to this a few days ago . .. weird
    well what I said last time was not all the lighting I use is mine, before I had to replace my HDD and re-add files, I wasn't able to get the presets I created before, only have just the one I saved. I sometimes mix mine with someone else lighting.
    Still learning lighting myself.
    just about 90+ % of what I have to use is just free, and not that much on top of that . . so bit limited to what I can use. If it wasn't for some free shaders out there, I would have even a smaller wardrobe to play with.
    and thank you
  • bighbigh Posts: 8,147
    like her face
    like her face
    thank you
    should had already been in bed asleep, but I found a couple zips I had not yet installed, not the one's I was looking for, but were some that I used to use, so grabbed the Verna Base reskinned, did some shaders on the clothing, and ended up with this
    I see I need to work on that one side, it's casting a black shadow where there should not be
    1200 x 1326 - 646K
