Texture Atlas Tutorial
SassanikSassanik Posts: 340
edited December 1969 in Freebies
Not which category this should be under!
But after repeatedly hitting my head on my desk and pulling out of my hair! I finally figured out how to use Texture Atlas and made up a tutorial on how to turn it on and the basics of use! I could use someone to check it and make sure I am not missing anything and see if I actually am making sense!
Setup tutorial can be found here
Thanks!
Amy
  • ladyofmanyfacesladyofmanyfaces Posts: 83
    I'll check try this out when I get to my desk top tomorrow. Thank you for this.
  • none01ohonenone01ohone Posts: 862
    Thanks. Just followed your tut. Now got the toolbar and Texture atlas on Hollywood Blvd.
  • SassanikSassanik Posts: 340
    Did the tutorial make sense to you?
    Amy
    Yep, no problem. But what I tend to do is scan and pick out the obvious, which was well signposted with pics and menu selections.
    Thanks again.
  • madmadmad2040madmadmad2040 Posts: 44
    Thanks!
    Amy
    your tutorial was helpful ,thank you.
    i always wanted to merge textures into one but didn't know textureatlas until late ,that too accidentally , i asked how to perform such a task many times in forums but never got the solution , but with texture-atlas i am near to my goal.
    I am glad you found it helpful!
    Amy
