Texture Atlas Tutorial
Not which category this should be under!
But after repeatedly hitting my head on my desk and pulling out of my hair! I finally figured out how to use Texture Atlas and made up a tutorial on how to turn it on and the basics of use! I could use someone to check it and make sure I am not missing anything and see if I actually am making sense!
Setup tutorial can be found here
Thanks!
Amy
I'll check try this out when I get to my desk top tomorrow. Thank you for this.
Thanks. Just followed your tut. Now got the toolbar and Texture atlas on Hollywood Blvd.
Did the tutorial make sense to you?
Amy
Yep, no problem. But what I tend to do is scan and pick out the obvious, which was well signposted with pics and menu selections.
Thanks again.
your tutorial was helpful ,thank you.
i always wanted to merge textures into one but didn't know textureatlas until late ,that too accidentally , i asked how to perform such a task many times in forums but never got the solution , but with texture-atlas i am near to my goal.
I am glad you found it helpful!
Amy
