Marvelous Designer 7 Released
12345679»
  • N-RArtsN-RArts Posts: 1,606
    I've got five days left on my trial. I've been trying to convert a few obj's to garments, but they keep exploding or dissolving on simulation. I'm going to miss using Marvelous Designer. It's such a wonderful program.
  • tikiman-3dtikiman-3d Posts: 42
    edited August 2018
    Has anyone using MD 7.5 been able to dforce-ify a garment with topstitch added? I've tried:
    1) Importing the garment without topstitch added and it works great with dforce in a little over 30 seconds to simulate.
    2) Importing with topstich and it runs the "Springs" menu forever then immediately explodes whe trying to simulate.  SO I tried....
    3) Exporting the Garment from MD with the Topstich as a separate .OBJ Imported both to DAZ. Decimated the topstitch down to 7%. Exported both to a single OBJ then re- imported.
        dforce runs the "Springs" in half the time, but still explodes.
    I have tried to tweak the settings too but to no avail.
    crying
    Post edited by tikiman-3d on
  • nonesuch00nonesuch00 Posts: 18,790
    It would be nice if something like topstitch was instead relegated to a material zone and a displacement, normal, or bump map, something along those lines, used instead. The stitch being located there in a seperate material zone would also allow a different set of paramers to be used for dForce since the stitching would stiffen the fabric along the stitch.
  • Has anyone using MD 7.5 been able to dforce-ify a garment with topstitch added? I've tried:
    crying
    I guess the springs messags are telling you that the spring length is less than the offset value - not entirely surprisingly if you are trying to model stitching. You could try lowering the offset in the surface settings for the item, though that may cause poke-through or other issues. You could also/instead try adding more iterations in Simulation Settings to give the "energy" a chance to get away from the very tight stitch mesh.
  • marblemarble Posts: 7,500
    Just to update this thread as I started it at a time when MD7 was the latest version: I finally scraped the means together, helped by a significant discount at the moment, and bought MD8 today. Rather belatedly (almost a year since I had the trial version) I can't wait to get started on some projects.
    By the way, thanks for all the informative input to this thread - much appreciated by all, I'm sure.
